Get a free 1GB eSIM card
Get a free 1GB eSIM in just a few steps:
Summary
Go to: Next-gen eSIM
Select your country/region and enter your email address. Check your inbox and confirm your email. Download the Kolet app:
Next-gen eSIM
Log in using the same email address, then activate your free eSIM on your device. Channel
Update: It is valid for 48 hours.
Thanks for sharing! It would be even better if you could also mention the validity period.
Thanks for sharing! Can it be added to the Xiaobai Card?
Can I get it for free if my phone doesn’t support eSIM?
Thank you. Can you receive text messages?
Looks like it won’t work.
I haven’t even tried it myself yet, but I’ve already served it up for you guys, hahaha. I haven’t had time to test it yet.
I’m not sure.
I haven’t tested it yet.
Seems like about a month or so.
By the way, may I ask: after downloading the app on your phone and logging in, will it install it directly on the phone, or give you a QR code or something?
Then can I still keep my account after seven days have passed?
Can it be written?
Wow, 1g is enough for me.
Post the link, bro.
Check if it works.
Enter it first, but you can also choose the QR code. The phone number is currently not visible.
Okay, thank you.
Thanks, legend!
Thank you
