Hi everyone, for those domains I got previously that can’t be hosted on CF, I want to use them for domain-based email addresses. Do you know of any projects I could use for this?
It seems like there’s no good solution. CF can provide free email services, but if it can’t do hosting, then it’s pretty much useless. If you really want to use this domain, just go with something like secer00 or CT8.
Try and see if Zoho Mail works, but you need to be able to change the NS.
Alright, thanks a lot!
xigege has a project, which is about setting up your own mail server.
Thanks a lot, I’ll give it a try.
If you have serv00 on hand, you can give it a try—it’s actually pretty handy. You can send and receive with it.
Thanks a lot! I’ve already used this project, but it can only be used with domains hosted on CF. I wanted to see if there’s a project that works with domains that can’t be hosted on CF.
mailu
Thanks, boss!
You could give tinkmail a try.
If it’s for personal use, I don’t recommend running your own mail server, because your outgoing emails will go straight to the spam folder. I recommend ByteDance’s international version of Feishu, Lark Suite, which seems to offer 100 GB of mailbox storage for 50 accounts.
The international version of Feishu no longer allows individuals to register, and it even asked me to delete my old account.
Host it on vps8, using mailrouting.
Serv00 can be used to host email.
That can’t be right—mine have always been fine, all five of my accounts.
I tested it, and it works.
Which region did you choose?
