Connection info: key: sk-L2OPnhmrOjkUjDMauOggY6lq23Tp7h2BNRdjzlUJg88etTDu
As for the URL, check the post below (I can’t share the same link repeatedly, it’s a bit annoying for me too) ai.yuanown.com
The countdown has started! There’s only 0.5b quota left in this API. Once it’s used up, it’s going offline. If you want to keep using it, just register an account and subscribe under the special group to continue.
Keep an eye out—there will be more free APIs released in the future.
If you win a prize, please contact the QQ group mentioned in the site announcement and then DM the group owner, OK?
Thank you for your help. ai.yuanown.com is a high-protection URL. api.ai.yuanown.com has lower protection.
gai.fj.kg is used as a backup, and it’s also provided by Zerexa Domains (that should be the correct name).
