Some reverse engineering skills? The results are pretty good ( ̄y▽, ̄)
:light_bulb: Note: The following is a curated list of reverse engineering related skills and repositories. If you can’t find the resource you’re looking for, feel free to leave a comment below and join the discussion~
### :package: Repository / Skill List
  1. android-reverse-engineering
  2. ghidra_idareverseengineeringskill
  3. ghidra-rpc-main
  4. protocol-reverse-engineering
  5. reverse-api-engineer-main
  6. reverse-engineering-android-malware-with-jadx
  7. reverse-engineering-tools
### :bar_chart: Quick Category Overview
No. Skill / Repository Name Main Application Area
01 android-reverse-engineering Android reverse analysis / engineering
02 ghidra_idareverseengineeringskill IDA Pro / Ghidra reverse engineering workflow support
03 ghidra-rpc-main Ghidra RPC remote calls and integration
04 protocol-reverse-engineering Network protocol reverse engineering & packet decryption
05 reverse-api-engineer-main API reverse engineering and protocol extraction
06 reverse-engineering-android-malware-with-jadx JADX malicious samples & Android APK analysis
07 reverse-engineering-tools Reverse engineering toolset & environment setup
:pushpin: Note: If you know of any other powerful skills or tools, feel free to share and add to the list!
What agent are you using on your PC, OP?
Not bad—if only I had Firda’s skills, that would be great.
I’ve actually been needing to reverse engineer Android phone firmware recently. If it’s convenient for you, it would be even better if you could also include the links to these tools.
It would be even better if there were a skill that could automatically watch ads :smiling_face_with_tear:
Thanks for sharing. Bookmarking this for now—I’ll check it out later when I need it.
Bookmarked it :xhj003:
Thanks, mjj
Nice, nice.
Looks very high-end—I’ll add it to my favorites.
The summary is pretty good; it basically covers everything.
Thank you for sharing
Whatever, I’ll just hit it with ida-pro-mcp all at once—life and death are fate, and wealth is up to heaven.
Thanks for sharing
We really need good people like you!
Thanks for sharing
If you find it, give me a heads up :heart_eyes::heart_eyes:
Thanks for sharing, I’ll give it a try.
By the way, do these require armor penetration? :xhj001:
A few pretty comprehensive Ghidra and protocol reverse engineering repositories organized — just marking them for now.
