Use Gpt6 and Fable5 for free
Usage Instructions
  • Supported models: GPT-6 and Fable5 are available.
  • Error handling: If an issue occurs during registration or use, try disabling the browser translation feature first, then try again.
  • Phone number: You need to enter a phone number when registering, but it does not appear to be verified at present.
  • New user credit: After registration, you apparently receive $1 in credit, without needing to link a bank card.
  • Exceeding the limit: The credit may allow a small amount of overdraft. I used it until the balance was approximately a little over -$2, after which I could no longer continue using it, so the overdraft limit is probably fairly small.
The above information is based on personal experience. The platform’s rules may change at any time, so please refer to the actual situation.
Channel
[upvote]Register: https://app.ashna.ai/[/upvote]
Let’s see what it is.
Let me see if I can use it.
So the free trial is gone after just $3–$5?
Good stuff
Have a look
Let me see what’s going on.
Since there was no need to link a card anyway, I made a pelican test and a browser-based single-player mini-game, and it only stopped working after that.
Let me inspect the goods.
Thanks for sharing
Check out the good stuff
Have a look
Let’s take a look first.
Have a look
Participation
Come take a look.
let’s see
A little awkward
