I applied for a permanent one during the event. At first, everything worked fine with the loc.cc domain, but although the rr.kg domain appears normal in the control panel, visiting it shows: Kangle is OK!!
Has anyone else encountered this? I’d appreciate any advice! Thank you.
The IP address I configured for the domain in the control panel appears correct, but when I look up the domain’s resolved IP, it shows a different address, so the site obviously can’t be accessed.
I found the original DNS record and linked it back to the original virtual host. It works now, but it seems that subsequent changes can’t resolve properly.
