Wouldn’t this result in a login from another location?
Doesn’t Tencent have any fraud prevention? Getting your account banned just to exploit promotions seems a bit counterproductive.
You can see how to use it.
Awesome, 666!
WorkBuddy_青龙签到_干净分享版.zip (9.6 KB)
Qinglong’s
I haven’t used either of them, but I added check-ins for Trae. Currently, only Trae and WorkBuddy have check-ins. I just tested it, and the check-in worked successfully. I’ll upload it to GitHub when I have time.
Nice, nice. I’ve been looking into WorkBuddy these past couple of days.
Added check-ins for Trae. Check-ins for both Trae and WorkBuddy are now supported. I just tested them, and they worked successfully. I’ll upload them to GitHub when I have time.
All set, thanks.
Have a look
It would be even better if JSON import and export were supported.
Learn a bit…
Still can’t see it…![]()
Awesome, I support it—let’s add qoder.
Take a look.
Not bad
I’ll give it a try, thanks.
You’re awesome! Thanks for sharing!
Nice! Show some support.
Lettuce, this is incredibly useful. Thanks for sharing.
