[UlziX TG Auto-Forwarding] US Zone 27 IPs blocked and AI compliance review launched
US Zone 27 IPs Blocked; AI Compliance Review to Begin
At present, the IPs in US Zone 27 (the premium CN2-CMIN2 route, high-bandwidth zone) have been blocked, preventing normal connections from within China. We are urgently replacing the IPs to resolve the issue.
:pushpin: Suspected reason for the IP blocks, consistent with US Zone 22:
We suspect that some users are still using “simple fingerprintable protocols” such as Shadowsocks and OpenVPN. This can result in the IPs of the entire physical host being blocked, severely affecting all legitimate users in the same region.
To prevent this kind of “one bad apple spoils the whole barrel” situation from happening again, and to avoid disputes, we are introducing the following rules:
:alarm_clock: Grace period: From now until this Friday (October 23, 2026)
During this period, if you are currently using a simple proxy protocol, please switch protocols or take other appropriate action as soon as possible. Once the new IPs have been deployed, do not use any simple, unencrypted protocols again.
:shield: Starting this Friday, AI audits of all machines will begin
Starting Friday (October 23), the AI system will conduct an in-depth scan of the entire platform.
We will only target high-risk, easily blocked simple protocols with obvious fingerprints (such as pure SS and OpenVPN) for removal.
After the inspection is complete, compliant machines will have their IPs replaced, while non-compliant machines will be removed directly.
:warning: Stern warning:
Once the AI audit begins on Friday, if we find you using a simple protocol that is easily blocked, your service will be removed immediately, with no appeals accepted! We have provided a grace period, so please do not blame us for taking action.
We understand that everyone has different needs, but your usage is not sufficiently discreet, and we cannot make all users bear the cost. Thank you for your understanding and cooperation. Please be sure to use the service properly.
Synchronized from the Telegram channel UlziX Cloud Services Official Notifications Channel
Official notification channel: @UlziX_NOTICE Please follow the channel announcements.
No wonder I can’t connect to Zone 27 tonight.
