Saw a hahasim SIM card on 奶昔 for ¥65; it’s ¥75 on JD.com. Is the ¥65 one worth getting?
Is it worth paying 65 for a Hahasim now? Is this kind of third-party resale reliable? Does anyone know?
Update: The SIM card I bought has arrived. After activation, it had HK$50 in credit. After spending a few days testing the number with accounts on various platforms, I found that it’s a recycled number that has been reassigned. Telegram couldn’t receive verification codes—the codes were sent to the device originally used to register and log in. Most other platforms worked fine. I registered accounts on Facebook, Instagram, WhatsApp, and WeChat, bought a 10-yuan data package, and used mobile data to register a Google account. Overall, it’s pretty good. The only hassle is that, since this is a recycled number, I keep receiving all kinds of scam calls and text messages from Hong Kong. I also can’t tap to hang up the calls, or I’ll be charged; I can only wait for them to hang up automatically.
Just buy it on Xianyu—there are tons of cheap ones.
Keywords are currently blocked on Xianyu, so I can’t search for anything. JD.com works, though.
Prices are transparent now—if there’s demand, it’s worth it.
You can find it by searching with a different keyword:
[login](Fortress Hong Kong/Haha Card/haha travel)[/login]
It doesn’t look cheap either.
I’d like to know too.
I bought the eSIM directly from the official website.
Can I buy an eSIM on the Hahasim official website?
I misspoke—it’s Club eSIM that can be activated on the official website.
I want to know
I placed an order to give it a try. It should arrive in a few days, and I’ll let you know how it goes.
Thanks :04-zan:
The card has arrived and is now being used. The details are in the edited post.
What is a milkshake?
A forum dedicated solely to discussing SIM cards
Take a look
There’s a way.
How much
