Use seedance2.5 for free
Use seedance2.5 for free, no card required
After registering and passing verification, you’ll receive 300 credits. In theory, you can get unlimited credits if you have enough accounts, but it seems to support only Google registration.
Channel
[upvote]https://toonkit.io/[/upvote]
I have nothing more to say.
Good stuff
Offers 300 free credits, but only supports 4 seconds—might as well use Doubao.
You chose the most powerful model and the highest resolution, so of course it supports shorter durations.
Not much use—only 2.0 mini can reach 15 seconds; the others can’t.
Then I’ll pedal as hard as I can.
Each account can only generate one video, which feels a bit restrictive.
I’m having trouble using the school’s Wi‑Fi.
Thanks, I’ll give it a try.
I just tried toonkit.io. The 300 credits promised for signing up were indeed credited, but it currently only supports Google login. Without other login options, maintaining enough accounts could become difficult. In practice, when using the highest-end model with the resolution maxed out, the duration gets compressed to around 4 seconds; if you want 15 seconds, you basically have to use 2.0 mini, with noticeably worse image quality—consistent with the feedback from several people in this thread. Also, each account seems to have a limit on the number of generations, so rotating between multiple accounts would be more convenient. Overall, it’s decent as a free trial and for experimenting with prompts, but the available computing power and duration are currently too limited for producing professional assets. Thanks for sharing.
好东西
Good stuff
让我看看让我看看!!!
支持一下!
感谢分享我记得土区官网也有赠送积分,好像价格也优惠
时长这边我另外试过 MiniMax-H3 图生视频,15 秒、9:16、带声音是能出的,不过别按「丢一张图就行」来接:
  • 只传 first_frame,不要再叠 reference_image,否则会报 frame and reference roles cannot be mixed
  • 原图太大容易 prompt optimization failed,竖图我先压到大约 720×1280 再传
给同样在抠时长的人留个参考:MiniMax-H3 图生视频踩坑:不能混首帧与参考图,以及 prompt optimization failed
