The title just says “new API”
The main headline on the homepage says something like “One key to manage countless large models”
Could it be some kind of open-source system?
Go look up the new API yourself.
Search for “new api”
There’s also another set of templates—the ones for sub2api.
It’s always the same few templates over and over.
Not exactly the same—it’s twice as alike.
New API is an open-source project, and similar ones include sub2api. Most relay services simply use ready-made templates, with very few developed in-house.
New API:GitHub - QuantumNous/new-api: Open-source AI gateway. Self-hosted LLM gateway with OpenAI-, Claude- and Gemini-compatible APIs, model routing, access control, usage tracking and cost accounting. · GitHub
Sub2API:GitHub - Wei-Shaw/sub2api: Sub2API 一站式开源中转服务,让 Claude、Openai 、Gemini、Grok订阅统一接入,支持拼车共享,更高效分摊成本,原生工具无缝使用。 · GitHub
It can be deployed locally with Docker; download it and try it out yourself.
There are open-source templates like this on GitHub—just deploy with one click. It’s very convenient, so they’re all pretty much the same.
Because there are basically only a few templates; at most, you can heavily customize one yourself.
Open source
As long as it works.
I’ve played both.
Looks like you’re really new to this, haha.
new-api is open source; basically, everyone uses it.
I came across several that had been modified beyond recognition through custom development.
Yes, there are two open-source projects, one called sub2api and the other newapi. Their functionality is fairly complete, but you’ll need to optimize the details and performance yourself. My relay site, cheapbuddy.cc, uses them too—standing on the shoulders of giants.
You really got that right, haha,
