Short version: Ask a friend with an activated account to transfer 120 TRY to your account, and it will be activated. Note: it has to be a Wise-to-Wise transfer. Wise usernames start with @; tap your avatar in the top-left corner to find yours.
Long version:
I helped my partner register for Wise, but got stuck at the activation step.
I was supposed to deposit 170 RMB first. I tried every other option, but either the fees were ridiculously high or it required a foreign-currency card in the same name as the account, which was impossible.
After spending half the day looking into it with no luck, I checked Xianyu and, lo and behold, people were charging 200 RMB to activate accounts.
I pretended I wanted to buy the service and chatted with them for a bit. It turned out they seemed to be using an already activated Wise account to transfer money to the new account and activate it.
So I decided to try it myself.
First, I transferred 1 euro from my Wise account, but nothing happened.
Then I suddenly wondered: why did they specifically require a transfer of 120 TRY?
As a last-ditch attempt, I transferred 130 TRY.
And it actually activated the account…
That one simple step, and people on Xianyu charge 200 RMB for it.
I saved 200 RMB—and it really pays to have information others don’t.
A while back, Industrial Bank’s Boundless Card could generally be activated without any loss. Although lossless activation is no longer possible now, it can still be activated.
120 TRY This trick really works. I thought I had to top up 170 first, but it turns out I can just have a friend with an activated account transfer it for me. The 200 on Xianyu is a real rip-off.
