明明安装了 但是就是显示没有 这是什么鬼
Nginx也重启重载了 php也重启重载了
@“[已注销]”#1
看看日志呢?是不是安转失败了
宝塔经常有这种奇奇怪怪的bug
@“[未知用户]”#p26053 [07-May-2024 13:43:41] NOTICE: fpm is running, pid 266912
[07-May-2024 13:43:41] NOTICE: ready to handle connections
[07-May-2024 14:01:28] NOTICE: Reloading in progress …
[07-May-2024 14:01:28] NOTICE: reloading: execvp(“/www/server/php/82/sbin/php-fpm”, {“/www/server/php/82/sbin/php-fpm”, “–daemonize”, “–fpm-config”, “/www/server/php/82/etc/php-fpm.conf”, “–pid”, “/www/server/php/82/var/run/php-fpm.pid”})
[07-May-2024 14:01:28] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/exif.so’ in Unknown on line 0
[07-May-2024 14:01:28] NOTICE: using inherited socket fd=7, “/tmp/php-cgi-82.sock”
[07-May-2024 14:01:28] NOTICE: fpm is running, pid 269557
[07-May-2024 14:01:28] NOTICE: ready to handle connections
[07-May-2024 14:02:15] NOTICE: Reloading in progress …
[07-May-2024 14:02:15] NOTICE: reloading: execvp(“/www/server/php/82/sbin/php-fpm”, {“/www/server/php/82/sbin/php-fpm”, “–daemonize”, “–fpm-config”, “/www/server/php/82/etc/php-fpm.conf”, “–pid”, “/www/server/php/82/var/run/php-fpm.pid”})
[07-May-2024 14:02:15] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/exif.so’ in Unknown on line 0
[07-May-2024 14:02:15] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/fileinfo.so’ in Unknown on line 0
[07-May-2024 14:02:15] NOTICE: using inherited socket fd=7, “/tmp/php-cgi-82.sock”
[07-May-2024 14:02:15] NOTICE: fpm is running, pid 273965
[07-May-2024 14:02:15] NOTICE: ready to handle connections
[07-May-2024 14:05:20] NOTICE: Reloading in progress …
[07-May-2024 14:05:20] NOTICE: reloading: execvp(“/www/server/php/82/sbin/php-fpm”, {“/www/server/php/82/sbin/php-fpm”, “–daemonize”, “–fpm-config”, “/www/server/php/82/etc/php-fpm.conf”, “–pid”, “/www/server/php/82/var/run/php-fpm.pid”})
[07-May-2024 14:05:20] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/exif.so’ in Unknown on line 0
[07-May-2024 14:05:20] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/fileinfo.so’ in Unknown on line 0
[07-May-2024 14:05:20] NOTICE: using inherited socket fd=7, “/tmp/php-cgi-82.sock”
[07-May-2024 14:05:20] NOTICE: fpm is running, pid 274117
[07-May-2024 14:05:20] NOTICE: ready to handle connections
[07-May-2024 14:06:53] NOTICE: Finishing …
[07-May-2024 14:06:53] NOTICE: exiting, bye-bye!
[07-May-2024 14:06:54] NOTICE: fpm is running, pid 274240
[07-May-2024 14:06:54] NOTICE: ready to handle connections
[07-May-2024 14:08:52] NOTICE: Reloading in progress …
[07-May-2024 14:08:52] NOTICE: reloading: execvp(“/www/server/php/82/sbin/php-fpm”, {“/www/server/php/82/sbin/php-fpm”, “–daemonize”, “–fpm-config”, “/www/server/php/82/etc/php-fpm.conf”, “–pid”, “/www/server/php/82/var/run/php-fpm.pid”})
[07-May-2024 14:08:52] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/fileinfo.so’ in Unknown on line 0
[07-May-2024 14:08:52] NOTICE: using inherited socket fd=7, “/tmp/php-cgi-82.sock”
[07-May-2024 14:08:52] NOTICE: fpm is running, pid 274435
[07-May-2024 14:08:52] NOTICE: ready to handle connections
[07-May-2024 14:09:00] NOTICE: Reloading in progress …
[07-May-2024 14:09:00] NOTICE: reloading: execvp(“/www/server/php/82/sbin/php-fpm”, {“/www/server/php/82/sbin/php-fpm”, “–daemonize”, “–fpm-config”, “/www/server/php/82/etc/php-fpm.conf”, “–pid”, “/www/server/php/82/var/run/php-fpm.pid”})
[07-May-2024 14:09:00] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/fileinfo.so’ in Unknown on line 0
[07-May-2024 14:09:00] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/exif.so’ in Unknown on line 0
[07-May-2024 14:09:00] NOTICE: using inherited socket fd=7, “/tmp/php-cgi-82.sock”
[07-May-2024 14:09:00] NOTICE: fpm is running, pid 274589
[07-May-2024 14:09:00] NOTICE: ready to handle connections
[07-May-2024 14:10:13] NOTICE: Reloading in progress …
[07-May-2024 14:10:13] NOTICE: reloading: execvp(“/www/server/php/82/sbin/php-fpm”, {“/www/server/php/82/sbin/php-fpm”, “–daemonize”, “–fpm-config”, “/www/server/php/82/etc/php-fpm.conf”, “–pid”, “/www/server/php/82/var/run/php-fpm.pid”})
[07-May-2024 14:10:13] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/fileinfo.so’ in Unknown on line 0
[07-May-2024 14:10:13] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/exif.so’ in Unknown on line 0
[07-May-2024 14:10:13] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘imagick.so’ in Unknown on line 0
[07-May-2024 14:10:13] NOTICE: using inherited socket fd=7, “/tmp/php-cgi-82.sock”
[07-May-2024 14:10:13] NOTICE: fpm is running, pid 296754
[07-May-2024 14:10:13] NOTICE: ready to handle connections
[07-May-2024 14:11:02] NOTICE: Finishing …
[07-May-2024 14:11:02] NOTICE: exiting, bye-bye!
[07-May-2024 14:11:03] NOTICE: fpm is running, pid 316053
[07-May-2024 14:11:03] NOTICE: ready to handle connections
[07-May-2024 14:12:17] NOTICE: Reloading in progress …
[07-May-2024 14:12:17] NOTICE: reloading: execvp(“/www/server/php/82/sbin/php-fpm”, {“/www/server/php/82/sbin/php-fpm”, “–daemonize”, “–fpm-config”, “/www/server/php/82/etc/php-fpm.conf”, “–pid”, “/www/server/php/82/var/run/php-fpm.pid”})
[07-May-2024 14:12:17] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/fileinfo.so’ in Unknown on line 0
[07-May-2024 14:12:17] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/exif.so’ in Unknown on line 0
[07-May-2024 14:12:17] NOTICE: PHP message: PHP Warning: PHP Startup: Invalid library (maybe not a PHP library) ‘imagick.so’ in Unknown on line 0
[07-May-2024 14:12:17] NOTICE: using inherited socket fd=7, “/tmp/php-cgi-82.sock”
[07-May-2024 14:12:17] NOTICE: fpm is running, pid 316194
[07-May-2024 14:12:17] NOTICE: ready to handle connections
[07-May-2024 14:12:19] NOTICE: Finishing …
[07-May-2024 14:12:19] NOTICE: exiting, bye-bye!
[07-May-2024 14:12:20] NOTICE: fpm is running, pid 316209
[07-May-2024 14:12:20] NOTICE: ready to handle connections
@“Bigbug”#p26054 imagick.so、fileinfo.so、exif.so文件丢失了,要再装一遍PHP
@“[未知用户]”#p26057 8.3安装失败 8.2安装了拓展不生效 我又安装了一个8.1 还是安装拓展不生效 我现在把8.1 8.2都删除重装下试试
任务列表 (0)
消息列表 (18)
执行日志
174 | extern wchar_t *wcsrchr (const wchar_t *__wcs, wchar_t __wc)
/usr/include/wchar.h:164:17: error: declaration for parameter ‘wcschr’ but no such parameter
164 | extern wchar_t *wcschr (const wchar_t *__wcs, wchar_t __wc)
/usr/include/wchar.h:154:17: error: declaration for parameter ‘wcsdup’ but no such parameter
154 | extern wchar_t *wcsdup (const wchar_t *__s) __THROW __attribute_malloc__;
/usr/include/wchar.h:150:15: error: declaration for parameter ‘wcsxfrm_l’ but no such parameter
150 | extern size_t wcsxfrm_l (wchar_t *__s1, const wchar_t *__s2,
/usr/include/wchar.h:144:12: error: declaration for parameter ‘wcscoll_l’ but no such parameter
144 | extern int wcscoll_l (const wchar_t *__s1, const wchar_t *__s2,
/usr/include/wchar.h:135:15: error: declaration for parameter ‘wcsxfrm’ but no such parameter
135 | extern size_t wcsxfrm (wchar_t *__restrict __s1,
/usr/include/wchar.h:131:12: error: declaration for parameter ‘wcscoll’ but no such parameter
131 | extern int wcscoll (const wchar_t *__s1, const wchar_t *__s2) __THROW;
/usr/include/wchar.h:125:12: error: declaration for parameter ‘wcsncasecmp_l’ but no such parameter
125 | extern int wcsncasecmp_l (const wchar_t *__s1, const wchar_t *__s2,
/usr/include/wchar.h:122:12: error: declaration for parameter ‘wcscasecmp_l’ but no such parameter
122 | extern int wcscasecmp_l (const wchar_t *__s1, const wchar_t *__s2,
/usr/include/wchar.h:117:12: error: declaration for parameter ‘wcsncasecmp’ but no such parameter
117 | extern int wcsncasecmp (const wchar_t *__s1, const wchar_t *__s2,
/usr/include/wchar.h:114:12: error: declaration for parameter ‘wcscasecmp’ but no such parameter
114 | extern int wcscasecmp (const wchar_t *__s1, const wchar_t *__s2) __THROW;
/usr/include/wchar.h:109:12: error: declaration for parameter ‘wcsncmp’ but no such parameter
109 | extern int wcsncmp (const wchar_t *__s1, const wchar_t *__s2, size_t __n)
/usr/include/wchar.h:106:12: error: declaration for parameter ‘wcscmp’ but no such parameter
106 | extern int wcscmp (const wchar_t *__s1, const wchar_t *__s2)
/usr/include/wchar.h:101:17: error: declaration for parameter ‘wcsncat’ but no such parameter
101 | extern wchar_t *wcsncat (wchar_t *__restrict __dest,
/usr/include/wchar.h:97:17: error: declaration for parameter ‘wcscat’ but no such parameter
97 | extern wchar_t *wcscat (wchar_t *__restrict __dest,
/usr/include/wchar.h:92:17: error: declaration for parameter ‘wcsncpy’ but no such parameter
92 | extern wchar_t *wcsncpy (wchar_t *__restrict __dest,
/usr/include/wchar.h:87:17: error: declaration for parameter ‘wcscpy’ but no such parameter
87 | extern wchar_t *wcscpy (wchar_t *__restrict __dest,
In file included from /usr/include/wchar.h:42,
from /www/server/php/82/src/ext/standard/basic_functions.h:22,
from /www/server/php/82/src/ext/standard/md5.h:24,
from /www/server/php/82/src/ext/opcache/ZendAccelerator.c:50:
/usr/include/bits/types/mbstate_t.h:6:21: error: declaration for parameter ‘mbstate_t’ but no such parameter
6 | typedef __mbstate_t mbstate_t;
In file included from /usr/include/wchar.h:41,
/usr/include/bits/types/wint_t.h:20:23: error: declaration for parameter ‘wint_t’ but no such parameter
20 | typedef __WINT_TYPE__ wint_t;
In file included from /www/server/php/82/src/main/php.h:35,
from /www/server/php/82/src/ext/opcache/ZendAccelerator.c:22:
/www/server/php/82/src/Zend/zend_API.h:244:4: error: declaration for parameter ‘zend_pcre_globals’ but no such parameter
244 | } zend_##module_name##_globals;
/www/server/php/82/src/ext/pcre/php_pcre.h:89:1: note: in expansion of macro ‘ZEND_END_MODULE_GLOBALS’
89 | ZEND_END_MODULE_GLOBALS(pcre)
In file included from /www/server/php/82/src/ext/opcache/ZendAccelerator.c:49:
/www/server/php/82/src/ext/pcre/php_pcre.h:48:3: error: declaration for parameter ‘php_pcre_error_code’ but no such parameter
48 | } php_pcre_error_code;
/www/server/php/82/src/ext/pcre/php_pcre.h:38:34: error: parameter ‘pcre_cache_entry’ has incomplete type
38 | typedef struct _pcre_cache_entry pcre_cache_entry;
/www/server/php/82/src/ext/pcre/php_pcre.h:38:34: error: declaration for parameter ‘pcre_cache_entry’ but no such parameter
/www/server/php/82/src/ext/pcre/php_pcre.h:32:26: error: declaration for parameter ‘pcre_module_entry’ but no such parameter
32 | extern zend_module_entry pcre_module_entry;
/www/server/php/82/src/ext/opcache/ZendAccelerator.c:4817: error: expected ‘{’ at end of input
4817 | };
/www/server/php/82/src/ext/opcache/ZendAccelerator.c:4817: warning: control reaches end of non-void function [-Wreturn-type]
4817 | };
make: *** [Makefile:1725: ext/opcache/ZendAccelerator.lo] Error 1 ========================================================
Alibaba Cloud Linux release 3 (Soaring Falcon)
Bit:64 Mem:3583M Core:2 gcc:10.2.1 cmake:3.20.2
Linux 5.10.134-16.1.al8.x86_64 x86_64
ERROR: php-8.2.16 install failed.
安装失败,请截图以上报错信息发帖至论坛www.bt.cn/bbs求助
php.sh: line 78: 338558 Segmentation fault (core dumped) curl --request POST --url "http://api.bt.cn/bt_error/index.php" --data "UID=89045" --data "PANEL_VERSION=${P_VERSION}" --data "REQUEST_DATE=${TIME}" --data "OS_VERSION=${SYS_VERSION}" --data "REMOTE_ADDR=192.168.168.1641" --data "REQUEST_URI=php" --data "USER_AGENT=${SYS_INFO}" --data "ERROR_INFO=${ERR_MSG}" --data "PACK_TIME=${TIME}" --data "TYPE=3"
|-Successify --- 命令已执行! ---
8.1 8.2删除重装后 问题依旧。,。。。
@“[未知用户]”#p26059 ssh输入make distclean,再安装一遍php试试
@“[未知用户]”#p26060 最简单的,换个 Debian 试试,别用aliyun的稀奇古怪的系统了
@“[未知用户]”#p26061
@"[未知用户]"#p26062
大概率就是因为aliyun的这个古怪系统
aliyun这系统暂用确实小可是经常报错整不成还是不要浪费时间在这系统上
大bug发飙了,满屏大bug
看時間久了眼疼
