搭建订阅转换和短链服务
用的这个项目https://github.com/stilleshan/subweb
预览https://sub.ops.ci
下面的是docker-compose
```bash
version: “3”
services:
subconverter:
image: stilleshan/sub
container_name: sub
ports:
- 18080:80
volumes:
- ./conf:/usr/share/nginx/html/conf
restart: always
myurls:
image: stilleshan/myurls:latest
container_name: myurls
environment:
- MYURLS_DOMAIN=s.ops.ci
- MYURLS_PROTO=https
volumes:
- ./data/myurls/logs:/app/logs
ports:
- “8080:8080”
depends_on:
- redis
restart: always
redis:
image: redis:latest
container_name: myurls-redis
volumes:
- ./data/redis:/data
restart: always
改为自己的域名
映射的conf目录里的config.js里有注释需要更改后端api为网站地址前面需要带https://
下面是短链的反代,自行更改ip和域名
```bash server { listen 80; server_name s.ops.ci; return 301 https://s.ops.ci$request_uri; }
server {
listen 443 ssl;
index index.php index.html index.htm;
gzip on;
ssl_certificate /usr/local/nginx/conf/ssl/ops.ci.cer;
ssl_certificate_key /usr/local/nginx/conf/ssl/ops.ci.key;
ssl_trusted_certificate /usr/local/nginx/conf/ssl/ops.ci.cer;
ssl_stapling on;
ssl_stapling_verify on;
ssl_protocols TLSv1.1 TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers on;
ssl_ciphers ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4;
ssl_ecdh_curve secp384r1;
ssl_session_timeout  10m;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_session_tickets off;
resolver 8.8.8.8 8.8.4.4 valid=60s ipv6=off;
resolver_timeout 5s;
add_header Strict-Transport-Security "max-age=63072000" always;
location / {
    proxy_redirect off;
    proxy_pass http://127.0.0.1:8080;
    add_header 'Access-Control-Allow-Origin' '*';
    proxy_set_header  Host                $http_host;
    proxy_set_header  X-Real-IP           $remote_addr;
    proxy_set_header  X-Forwarded-Ssl     on;
    proxy_set_header  X-Forwarded-For     $proxy_add_x_forwarded_for;
    proxy_set_header  X-Forwarded-Proto   $scheme;
    proxy_set_header  X-Frame-Options     SAMEORIGIN;
    client_max_body_size        100m;
    client_body_buffer_size     128k;
access_log /home/wwwlogs/s.ops.ci.access.log  main;
error_log  /home/wwwlogs/s.ops.ci.error.log  warn;
我自己搭建发现转换clash后reality节点没了不显示了不知道什么原因
好多转换的站里边加料
感谢分享 我以前用另一个项目搭建了一个 没有研究改短链接的 这个有空看看
@“James”#p36917 这个就是怕偷订阅才自建,前后端都是部署在自己机器上的,不过代码加没加料就不知道了,不会审查:huaji08:
@“QAQ555”#p36926 试过,我弄的不好,感觉还是不太完美
我大概看了一下 好像都是大佬 但真的没人帮你解答问题 。。。不说审查代码 说最简单的 你这个内核是什么?知道么。。 正常现在开源的sub不都是vmess ss ssr这种么 连vless都没有 也就是你这个转换根本不支持vless的节点 当然你做好的节点 转换后 会是空白的。 要找一个支持vless hy1 hy2的订阅转换 看一下就可以了 还有就是 现在hy2的内核是clash.meta和singbox 需要换个app了 原版的clash也不支持这个内核 也会变空白!楼主设置个最佳 谢谢!附加一个例子 不保证安全性 不建议用
https://sub.v1.mk/
附:即便这个开源的sub支持vless 你原版的clash也不行。。也看不到节点
@“AAAAA”#p37002 这个不是求助帖,无法设置最佳回复的。 有 求助 标签的才可能设置最佳回复。
我现在的方式是链接生成后导入 V2Ray,然后V2Ray再分享出来的二维码,手机扫一下就Okay了。
@“James”#p37014 win端v2ray支持的内核最全面 肯定没话说 怎么弄都行。。 但mac端大部分都还在用clash 只有xray内核小白又不会写入新的内核 所以还是用singbox吧 开源没问题 用习惯就好了
