搞了个deeplx测活脚本,佬们可以自己试一下
<!DOCTYPE html>
<html lang=“en”>
<head>
<meta charset=“UTF-8”>
<meta name=“viewport” content=“width=device-width, initial-scale=1.0”>
<title>DeepLX Endpoint Checker</title>
<style>
body {
font-family: Arial, sans-serif;
max-width: 800px;
margin: 0 auto;
padding: 20px;
background: linear-gradient(135deg, #6e8efb, #a777e3);
color: white;
h1, h2 {
color: #fff;
text-align: center;
text-shadow: 2px 2px 4px rgba(0,0,0,0.4);
.input-group {
margin-bottom: 15px;
label {
display: block;
margin-bottom: 5px;
font-weight: bold;
color: #fff;
text-shadow: 1px 1px 2px rgba(0,0,0,0.3);
textarea {
width: 100%;
height: 150px;
padding: 8px;
border: 1px solid #ddd;
border-radius: 4px;
box-sizing: border-box;
background-color: rgba(255, 255, 255, 0.8);
color: #333;
resize: vertical;
button {
display: block;
width: 100%;
padding: 10px;
background: linear-gradient(135deg, #43cea2, #185a9d);
color: white;
border: none;
border-radius: 4px;
cursor: pointer;
font-size: 16px;
transition: background 0.3s ease;
box-shadow: 2px 2px 8px rgba(0,0,0,0.2);
button:hover {
background: linear-gradient(135deg, #185a9d, #43cea2);
#results, #progress {
margin-top: 20px;
padding: 10px;
background-color: rgba(255, 255, 255, 0.9);
border-radius: 4px;
box-shadow: 0 2px 4px rgba(0,0,0,0.1);
color: #333;
.endpoint {
margin-bottom: 10px;
padding: 5px;
background-color: #f0f0f0;
border-radius: 4px;
.divider {
border-top: 1px solid #ccc;
margin: 20px 0;
.copyable {
cursor: pointer;
color: blue;
text-decoration: underline;
</style>
</head>
<body>
<h1>DeepLX Endpoint Checker</h1>
<div class=“input-group”>
<label for=“endpoints”>Endpoints (one per line):</label>
<textarea id=“endpoints”>https://translates.me/v2/translate
https://deeplx.2077000.xyz:2087/translate
https://deeplx.papercar.top/translate
https://dlx.bitjss.com/translate
https://deeplx.ychinfo.com/translate
https://free-deepl.speedcow.top/translate
https://deepl.coloo.org/translate
https://deeplx.keyrotate.com/translate
https://dx-api.nosec.link/translate
https://deepx.dumpit.top/translate
http://deepl.wuyongx.uk/translate
https://deepl.wuyongx.uk/translate
https://ghhosa.zzaning.com/translate
https://deepl.zhaosaipo.com/translate
https://api.deeplx.org/translate
https://deeplx.he-sb.top/translate
https://deepl.aimoyu.tech/translate
https://deepl.tr1ck.cn/translate
https://translate.dftianyi.com/translate&lt;/textarea&gt;
<button onclick=“checkEndpoints()”>Check Endpoints</button>
<div id=“progress”></div>
<div id=“results”></div>
&lt;script&gt;
    const test_data = {
        "text": "Hello, world!",
        "source_lang": "EN",
        "target_lang": "ZH"
    async function checkEndpoint(url) {
        const start_time = Date.now();
        try {
            const response = await fetch(url, {
                method: 'POST',
                headers: {
                    'Content-Type': 'application/json',
                body: JSON.stringify(test_data),
            const data = await response.json();
            const latency = (Date.now() - start_time) / 1000;
            if (response.ok &amp;&amp; data.data &amp;&amp; data.data.length &gt; 0) {
                return { url, latency };
        } catch (error) {
            console.error(`Error checking ${url}:`, error);
        return null;
    async function checkEndpoints() {
        const endpointsTextarea = document.getElementById('endpoints');
        const resultsDiv = document.getElementById('results');
        const progressDiv = document.getElementById('progress');
        const deepl_urls = endpointsTextarea.value.split('\n').filter(url =&gt; url.trim() !== '');
        progressDiv.innerHTML = 'Checking endpoints...';
        resultsDiv.innerHTML = '';
        const availableEndpoints = [];
        for (const url of deepl_urls) {
            progressDiv.innerHTML = `Checking: ${url}`;
            const result = await checkEndpoint(url);
            if (result) {
                availableEndpoints.push(result);
        availableEndpoints.sort((a, b) =&gt; a.latency - b.latency);
        let html = '&lt;h2&gt;Available DeepLX Endpoints with Latencies:&lt;/h2&gt;';
        html += '&lt;div class="divider"&gt;&lt;/div&gt;';
        for (const { url, latency } of availableEndpoints) {
            html += `&lt;div class="endpoint"&gt;&#128640; (${latency.toFixed(2)}s) &lt;span class="copyable" onclick="copyToClipboard('${url}')"&gt;${url}&lt;/span&gt;&lt;/div&gt;`;
        if (availableEndpoints.length &gt; 0) {
            const formattedEndpoints = availableEndpoints.map(e =&gt; e.url).join(', ');
            html += `&lt;p&gt;DeepLX&#128076;:(${availableEndpoints.length}) ${formattedEndpoints}&lt;/p&gt;`;
        } else {
            html += '&lt;p&gt;No available endpoints found.&lt;/p&gt;';
        progressDiv.innerHTML = 'Check completed!';
        resultsDiv.innerHTML = html;
    function copyToClipboard(text) {
        navigator.clipboard.writeText(text).then(() =&gt; {
            alert('URL copied to clipboard');
        }).catch(err =&gt; {
            console.error('Failed to copy URL: ', err);
&lt;/script&gt;
</body>
</html>
主逻辑采自L站,UI和代码流畅度是我自己拿GPT-4-ALL重新优化的,已打包成HTML格式,可以简便运行。
格式再调整一下就更好了
[redacted by DiscourseRedactor · 5b5f3d5c]
@“0x24a”#p69602 好像还没有标记
@“0x24a”#p69602 已优化
您应当添加转载标签
@“削除禁止”#p69684
二次编辑优化过我觉得不算搬运了。
@“James”#p69685 和我一样,爱用gpt:huaji08:
