[tabs]
[tab=“YABS”]
Yet-Another-Bench-Script
v2024-06-09
GitHub - masonr/yet-another-bench-script: YABS - a simple bash script to estimate Linux server performance using fio, iperf3, & Geekbench · GitHub
Thu Aug 22 03:12:44 PM EDT 2024
Basic System Information:
Uptime : 0 days, 0 hours, 1 minutes
Processor : Intel(R) Xeon(R) CPU E5-2682 v4 @ 2.50GHz
CPU cores : 2 @ 2499.996 MHz
AES-NI :
Enabled
VM-x/AMD-V :
Enabled
RAM : 973.0 MiB
Swap : 0.0 KiB
Disk : 19.6 GiB
Distro : Debian GNU/Linux 12 (bookworm)
Kernel : 6.1.0-23-cloud-amd64
VM Type : KVM
IPv4/IPv6 :
Online /
Offline
IPv4 Network Information:
ISP : Ipxo LLC
ASN : AS979 NetLab Global
Country : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
Read | 85.32 MB/s (21.3k) | 845.11 MB/s (13.2k)
Write | 85.54 MB/s (21.3k) | 849.55 MB/s (13.2k)
Total | 170.86 MB/s (42.7k) | 1.69 GB/s (26.4k)
Read | 1.40 GB/s (2.7k) | 1.33 GB/s (1.3k)
Write | 1.48 GB/s (2.8k) | 1.42 GB/s (1.3k)
Total | 2.89 GB/s (5.6k) | 2.76 GB/s (2.7k)
cue elevator music
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 2 min 41 sec
</e></CODE> <e>[/tab]</e></TAB> <TAB name="融合怪"><s>[tab="融合怪"]</s> <CODE><s>
VPS融合怪版本:2024.08.14
Shell项目地址:GitHub - spiritLHLS/ecs: VPS 融合怪服务器测评项目 更推荐使用无环境依赖的Go版本 VPS Fusion Monster Server Test Script – More recommended to use the Go version with no environment dependencies: https://github.com/oneclickvirt/ecs · GitHub
Go项目地址:GitHub - oneclickvirt/ecs: VPS Fusion Monster Server Test GO Version Aiming to be the most comprehensive server testing project, implemented in Go with zero environment dependencies. VPS融合怪服务器测评项目 GO版本 尽量成为最全能的服务器测评项目,使用 Go 实现,无需任何环境依赖。 · GitHub
CPU 型号 : Intel(R) Xeon(R) CPU E5-2682 v4 @ 2.50GHz
CPU 核心数 : 2
CPU 频率 : 2499.996 MHz
CPU 缓存 : L1: 32.00 KB / L2: 256.00 KB / L3: 40.00 MB
AES-NI指令集 :
Enabled
VM-x/AMD-V支持 :
Enabled
内存 : 131.42 MiB / 973.04 MiB
硬盘空间 : 988.08 MiB / 20122.45 MiB
启动盘路径 : /dev/vda1
系统在线时间 : 0 days, 0 hour 4 min
负载 : 0.92, 0.44, 0.17
架构 : x86_64 (64 Bit)
内核 : 6.1.0-23-cloud-amd64
TCP加速方式 : bbr
虚拟化架构 : KVM
NAT类型 : Full Cone
IPV4 ASN : AS979 NetLab Global
IPV4 位置 : Los Angeles / California / US
1 线程测试(单核)得分: 1/1
1 线程测试(单核)得分: 870 Scores
2 线程测试(多核)得分: 1/1
2 线程测试(多核)得分: 1766 Scores
单线程读测试: 1/1
单线程读测试: 17494.99 MB/s
单线程写测试: 1/1
单线程写测试: 13996.04 MB/s
测试操作 写速度 读速度
100MB-4K Block ->
100MB-4K Block 27.0 MB/s (6589 IOPS, 3.89s) ->
100MB-4K Block 27.0 MB/s (6589 IOPS, 3.89s) 41.8 MB/s (10203 IOPS, 2.51s)
1GB-1M Block ->
1GB-1M Block 533 MB/s (509 IOPS, 1.97s) ->
1GB-1M Block 533 MB/s (509 IOPS, 1.97s) 1.1 GB/s (1054 IOPS, 0.95s)
Running fio test…
Read | 82.72 MB/s (20.6k) | 935.86 MB/s (14.6k)
Write | 82.94 MB/s (20.7k) | 940.78 MB/s (14.6k)
Total | 165.66 MB/s (41.4k) | 1.87 GB/s (29.3k)
Read | 1.34 GB/s (2.6k) | 1.37 GB/s (1.3k)
Write | 1.41 GB/s (2.7k) | 1.47 GB/s (1.4k)
Total | 2.75 GB/s (5.3k) | 2.84 GB/s (2.7k)
[IPV4]
您的出口IP完整解锁Netflix,支持非自制剧的观看
NF所识别的IP地域信息:美国
[IPV6]
您的网络可能没有正常配置IPv6,或者没有IPv6网络接入
[IPV4]
连接方式: Youtube Video Server
视频缓存节点地域: 美国 洛杉机(LAX31S13)
[IPV6]
Youtube在您的出口IP所在的国家不提供服务
[IPV4]
当前出口所在地区解锁DisneyPlus
区域:US 区
[IPV6]
DisneyPlus在您的出口IP所在的国家不提供服务
以下为IPV4网络测试,若无IPV4网络则无输出
Dazn: Yes (Region: US)
Disney+: No (IP Banned By Disney+ 1)
Netflix: Yes (Region: US)
YouTube Premium: No
Amazon Prime Video: Yes (Region: US)
TVBAnywhere+: Yes
Spotify Registration: Yes (Region: US)
Instagram Licensed Audio: No
OneTrust Region: US [California]
iQyi Oversea Region: US
Bing Region: US
YouTube CDN: Los Angeles, CA
Netflix Preferred CDN: Los Angeles, CA
ChatGPT: Yes
Google Gemini: No
Wikipedia Editability: No
Steam Currency: USD
—Forum—
Reddit: No
以下为IPV6网络测试,若无IPV6网络则无输出
Tiktok Region: 【US】
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
IPV4:
安全得分:
声誉(越高越好): 0 [2]
信任得分(越高越好): 0 [8]
VPN得分(越低越好): 100 [8]
代理得分(越低越好): 100 [8]
社区投票-无害: 0 [2]
社区投票-恶意: 0 [2]
威胁得分(越低越好): 100 [8]
欺诈得分(越低越好): 65 [E]
滥用得分(越低越好): 0 [3]
ASN滥用得分(越低越好): 0.001 (Low) [A]
公司滥用得分(越低越好): 0.0014 (Low) [A]
威胁级别: low [9 B]
黑名单记录统计:(有多少黑名单网站有记录):
安全信息:
使用类型: hosting [A] corporate [9] hosting ASN [C] DataCenter/WebHosting/Transit [3] business [0 7 8]
公司类型: hosting [0 7] isp [A]
是否云提供商: Yes [7 D]
是否数据中心: Yes [0 A C] No [5 6 8]
是否移动设备: Yes [E] No [5 A C]
是否代理: No [0 4 5 6 7 8 9 A B C D] Yes [E]
是否VPN: No [0 6 7 A C D] Yes [E]
是否TorExit: No [7 D]
是否Tor出口: No [7 D]
是否网络爬虫: No [9 A B E]
是否匿名: No [6 7 8 D]
是否攻击者: No [7 8 D]
是否滥用者: No [7 8 A C D E]
是否威胁: No [7 8 C D]
是否中继: No [0 7 8 C D]
是否Bogon: No [7 8 A C D]
是否机器人: No [E]
DNS-黑名单: 312(Total_Check) 0(Clean) 6(Blacklisted) 17(Other)
Google搜索可行性:YES
LocalPort
QQ ✘
163 ✘
Sohu ✘
Yandex ✘
Gmail ✘
Outlook ✘ ✘ ✘ ✘ ✘ ✘
Office365 ✘ ✘ ✘ ✘ ✘ ✘
Yahoo ✘
MailCOM ✘
MailRU ✘
AOL ✘
GMX ✘ ✘ ✘ ✘ ✘ ✘
Sina ✘ ✘ ✘ ✘ ✘ ✘
北京电信 219.141.140.10 联通9929 [优质线路] 电信163 [普通线路]
北京联通 202.106.195.68 联通9929 [优质线路] 联通4837 [普通线路]
北京移动 221.179.155.161 联通9929 [优质线路] 联通4837 [普通线路]
上海电信 202.96.209.133 联通9929 [优质线路] 电信163 [普通线路]
上海联通 210.22.97.1 联通9929 [优质线路] 联通4837 [普通线路]
上海移动 211.136.112.200 联通9929 [优质线路] 联通4837 [普通线路]
广州电信 58.60.188.222 联通9929 [优质线路]
广州联通 210.21.196.6 联通9929 [优质线路] 联通4837 [普通线路]
广州移动 120.196.165.24 联通9929 [优质线路] 联通4837 [普通线路]
成都电信 61.139.2.69 联通9929 [优质线路] 电信163 [普通线路]
成都联通 119.6.6.6 联通4837 [普通线路]
成都移动 211.137.96.205 联通9929 [优质线路] 联通4837 [普通线路]
准确线路自行查看详细路由,本测试结果仅作参考
广州电信 58.60.188.222
21.21 ms AS979 美国, 加利福尼亚州, 洛杉矶, acedatacenters.com
7.39 ms * 局域网
10.05 ms * 局域网
149.56 ms AS10099 美国, chinaunicom.com, 联通
226.21 ms AS10099 中国, 上海, chinaunicom.com, 联通
228.94 ms * 中国, chinaunicom.com, 联通
244.20 ms AS9929 中国, 广东, 广州, chinaunicom.com, 联通
245.17 ms * 中国, 广东, 广州, chinaunicom.com, 联通
162.79 ms AS4134 中国, 广东, 广州, chinatelecom.com.cn, 电信
168.92 ms AS4134 中国, 广东, 深圳, chinatelecom.com.cn, 电信
164.25 ms AS4134 中国, 广东, 深圳, chinatelecom.com.cn, 电信
广州联通 210.21.196.6
16.83 ms AS979 美国, 加利福尼亚州, 洛杉矶, acedatacenters.com
6.70 ms * 局域网
0.62 ms * 局域网
149.78 ms AS10099 美国, chinaunicom.com, 联通
226.37 ms AS10099 中国, 上海, chinaunicom.com, 联通
231.37 ms AS9929 中国, 上海, chinaunicom.com, 联通
244.67 ms AS9929 中国, 广东, 广州, chinaunicom.com, 联通
250.33 ms * 中国, 广东, 广州, chinaunicom.com, 联通
189.34 ms AS4837 中国, 广东, 广州, chinaunicom.com, 联通
164.60 ms AS4837 中国, 广东, 广州, chinaunicom.com, 联通
176.68 ms AS17816 中国, 广东, 深圳, chinaunicom.com, 联通
205.73 ms AS17623 中国, 广东, 深圳, chinaunicom.com, 联通
166.98 ms AS17623 中国, 广东, 深圳, chinaunicom.com, 联通
广州移动 120.196.165.24
15.29 ms AS40676 美国 加利福尼亚 洛杉矶 psychz.net
3.92 ms * RFC1918
0.60 ms * RFC1918
149.66 ms AS10099 [CUG-BACKBONE] 美国 加利福尼亚 洛杉矶 chinaunicomglobal.com 联通
226.29 ms AS10099 [CUG-BACKBONE] 美国 加利福尼亚 洛杉矶 chinaunicomglobal.com 联通
228.63 ms AS9929 [CNC-BACKBONE] 中国 上海 chinaunicom.cn 联通 CUII
244.69 ms AS9929 [CNC-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通 CUII
245.52 ms * [APNIC-AP] 中国 广东 广州
168.84 ms AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
190.95 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
190.71 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
192.57 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
189.01 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
196.17 ms AS56040 [APNIC-AP] 中国 广东 深圳 gd.10086.cn 移动
位置 上传速度 下载速度 延迟 丢包率
Speedtest.net 288.24 Mbps 287.97 Mbps 0.75 0.0%
洛杉矶 287.26 Mbps 285.81 Mbps 25.07 0.0%
日本东京 189.79 Mbps 294.45 Mbps 104.24 69.6%
联通WuXi 282.88 Mbps 293.88 Mbps 159.35 0.0%
电信浙江 255.15 Mbps 298.37 Mbps 165.68 NULL
电信浙江 250.66 Mbps 302.95 Mbps 179.21 NULL
该运营商.net的节点列表为空,正在替换为.cn的节点列表。。。
总共花费 : 6 分 13 秒
时间 : Thu Aug 22 15:22:00 EDT 2024
短链:
PasteBin - VPS测评平台
IP质量体检报告:23.26.*.*
bash <(curl -sL IP.Check.Place)
报告时间:2024-08-23 03:22:02 CST 脚本版本:v2024-07-29
一、基础信息(Maxmind 数据库)
自治系统号: AS979
组织: NETLAB-SDN
坐标: 118°14′39″W, 34°3′16″N
地图: https://check.place/34.0544,-118.2441,15,cn
城市: 加州, 洛杉矶, 90060
使用地: [US]美国, [NA]北美洲
注册地: [US]美国
时区: America/Los_Angeles
IP类型: 原生IP
二、IP类型属性
使用类型: 商业 商业 机房 机房 机房
公司类型: 机房 商业 机房
三、风险评分
风险等级: 极低 低 中等 高 极高
ipapi: 0.14%|低风险
AbuseIPDB: 0|低风险
IPQS: 75|可疑IP
DB-IP: |低风险
四、风险因子
地区: [US] [US] [US] [US] 无 [US] [US] [US]
代理: 否 否 否 是 无 否 否 否
Tor: 否 否 否 否 无 否 否 否
VPN: 否 否 否 是 无 无 否 否
服务器: 是 是 是 无 无 否 是 否
滥用: 否 否 否 否 无 否 无 无
机器人: 否 否 无 否 无 无 无 无
五、流媒体及AI服务解锁检测
状态: 解锁 屏蔽 解锁 中国 解锁 解锁 解锁
地区: [US] [US] [CN] [US] [US] [US]
方式: 原生 原生 原生 原生 原生
六、邮局连通性及黑名单检测
本地25端口:阻断
IP地址黑名单数据库: 有效 439 正常 428 已标记 11 黑名单 0
今日IP检测量:943;总检测量:82014。感谢使用xy系列脚本!
报告链接:https://Report.Check.Place/IP/38MV1WAUM.svg
改版地址 GitHub - xykt/RegionRestrictionCheck: A bash script to check the status of your IP on various geo-restricted services. · GitHub
** 测试时间: Thu Aug 22 03:22:38 PM EDT 2024
** 正在测试IPv4解锁情况
** 您的网络为: Netlab-sdn (23.26..)
Dazn: 原生解锁 Yes (Region: US)
TikTok: 原生解锁 Yes (Region: US)
Disney+: No
Netflix: 原生解锁 Yes (Region: US)
YouTube Premium: 原生解锁 No (Region: CN)
Amazon Prime Video: 原生解锁 Yes (Region: US)
TVBAnywhere+: 原生解锁 Yes
iQyi Oversea Region: 原生解锁 US
Spotify Registration: 原生解锁 Yes (Region: US)
Steam Currency: USD
ChatGPT: 原生解锁 Yes (Region: US)
Google Gemini: No
Bing Region: US
Instagram Licensed Audio: ->
—Forum—
Reddit: No
===========[ North America ]===========
FOX: Yes
Hulu: No
NFL+: Yes
ESPN+:[Sponsored by Jam] No
MGM+: Failed (Network Connection)
MGM+: Failed
Starz: No
Philo: Yes
FXNOW: Yes
TLC GO: Yes
HBO Max: Yes
Shudder: Yes
BritBox: Yes
Crackle: Failed
CW TV: Yes
A&E TV: Yes
NBA TV: Yes
NBC TV: Yes
Fubo TV: No
Tubi TV: Yes
Sling TV: Yes
Pluto TV: Yes
Acorn TV: Yes
SHOWTIME: Yes
encoreTVB: Yes
Discovery+: Yes (Region: US)
Paramount+: Yes
Peacock TV: Yes
Popcornflix: Failed (Network Connection)
Crunchyroll: Yes
KOCOWA: Yes
SonyLiv: Failed (Network Connection)
AMC+: Yes (Region: USA)
—CA—
HotStar: No
CBC Gem: No
Crave: Yes
当前主机不支持IPv6,跳过…
本次测试已结束,感谢使用此脚本
检测脚本当天运行次数: 15; 共计运行次数: 129730
正在测试 https://www.google.com
尝试 1: 84.705000 ms
尝试 2: 81.446000 ms
尝试 3: 85.198000 ms
尝试 4: 81.597000 ms
尝试 5: 753.887000 ms
平均时间: 217.36 ms for https://www.google.com
正在测试 https://www.facebook.com
尝试 1: 113.639000 ms
尝试 2: 104.089000 ms
尝试 3: 132.626000 ms
尝试 4: 105.963000 ms
尝试 5: 108.483000 ms
平均时间: 112.96 ms for https://www.facebook.com
正在测试 https://www.twitter.com
尝试 1: 105.542000 ms
尝试 2: 100.593000 ms
尝试 3: 114.786000 ms
尝试 4: 110.218000 ms
尝试 5: 107.589000 ms
平均时间: 107.74 ms for https://www.twitter.com
正在测试 https://www.youtube.com
尝试 1: 293.380000 ms
尝试 2: 241.535000 ms
尝试 3: 294.829000 ms
尝试 4: 310.560000 ms
尝试 5: 298.368000 ms
平均时间: 287.73 ms for https://www.youtube.com
正在测试 https://www.netflix.com
尝试 1: 1389.517000 ms
尝试 2: 802.016000 ms
尝试 3: 930.848000 ms
尝试 4: 1005.826000 ms
尝试 5: 1050.009000 ms
平均时间: 1035.64 ms for https://www.netflix.com
正在测试 https://chat.openai.com
尝试 1: 86.706000 ms
尝试 2: 86.872000 ms
尝试 3: 81.484000 ms
尝试 4: 78.716000 ms
尝试 5: 99.447000 ms
平均时间: 86.64 ms for https://chat.openai.com
正在测试 https://www.github.com
尝试 1: 132.982000 ms
尝试 2: 114.327000 ms
尝试 3: 115.120000 ms
尝试 4: 135.861000 ms
尝试 5: 140.358000 ms
平均时间: 127.72 ms for https://www.github.com
网站 平均时间(ms)
https://www.google.com 217.36 ms
https://www.facebook.com 112.96 ms
https://www.twitter.com 107.74 ms
https://www.youtube.com 287.73 ms
https://www.netflix.com 1035.64 ms
https://chat.openai.com 86.64 ms
https://www.github.com 127.72 ms
Total Avg 282.25 ms
Version : v2024-04-25
Usage : bash <(curl -sL bash.icu/speedtest)
GitHub : GitHub - i-abc/Speedtest: 多功能测速脚本 | Multi-functional speedtest script · GitHub
测速节点 下载/Mbps 上传/Mbps 延迟/ms 抖动/ms
最近的测速点 285.93 Mbps 285.51 Mbps 0.80 ms 0.06 ms
电信 江苏苏州 274.20 Mbps 246.35 Mbps 161.20 ms 0.19 ms
电信 浙江杭州 301.68 Mbps 257.14 Mbps 164.82 ms 0.50 ms
电信 浙江宁波 5G 303.27 Mbps 266.78 Mbps 182.75 ms 0.38 ms
电信 江苏镇江 5G 104.36 Mbps 259.64 Mbps 171.34 ms 5.16 ms
电信 江苏南京 5G 284.59 Mbps 4.20 Mbps 161.50 ms 0.09 ms
联通 江苏无锡 287.14 Mbps 261.34 Mbps 162.94 ms 0.06 ms
测速次数过多,暂时被限制,请过一段时间后再进行测试
教育网 上海 1 0.09 Mbps 7.83 Mbps 964.64 ms 52.35 ms
教育网 上海 2 20.10 Mbps 25.87 Mbps 181.55 ms 0.22 ms
教育网 辽宁沈阳 0.02 Mbps 6.25 Mbps 205.00 ms 2.87 ms
教育网 江苏南京 1 63.92 Mbps 242.92 Mbps 221.09 ms 0.03 ms
教育网 江苏南京 2 27.91 Mbps 14.63 Mbps 268.91 ms 102.51 ms
系统时间:2024-08-22 15:37:18 EDT
北京时间: 2024-08-23 03:37:18 CST
电信 江苏苏州 失败 20.70 Mbps 160.60 ms 6.90 ms
电信 浙江杭州 8.70 Mbps 146.40 Mbps 161.00 ms 6.10 ms
电信 浙江宁波 5G 55.50 Mbps 154.60 Mbps 166.40 ms 6.60 ms
电信 江苏镇江 5G 41.10 Mbps 118.50 Mbps 160.10 ms 7.90 ms
电信 江苏南京 5G 64.80 Mbps 0.20 Mbps 159.80 ms 2.40 ms
电信 湖南长沙 5G 57.90 Mbps 127.80 Mbps 161.30 ms 6.50 ms
</e></CODE> <e>[/tab]</e></TAB> <TAB name="iperf3"><s>[tab="iperf3"]</s> <CODE><s>
No:1/9 Traceroute to 中国 深圳 电信 (TCP Mode, Max 30 Hop, IPv4)
NextTrace v1.3.2 2024-07-28T10:50:28Z ea2a6b5
[NextTrace API] preferred API IP - 172.67.155.192 - 72.48ms - Misaka.LAX
traceroute to 59.36.216.1, 30 hops max, 52 bytes payload
1 *
2 *
3 10.52.3.1 * RFC1918
1.29 ms
4 *
5 162.219.85.77 AS10099 [CUG-BACKBONE] 美国 加利福尼亚 洛杉矶 chinaunicomglobal.com 联通
149.90 ms
6 162.219.85.9 AS10099 [CUG-BACKBONE] 美国 加利福尼亚 洛杉矶 chinaunicomglobal.com 联通
226.35 ms
7 210.14.165.37 * [APNIC-AP] 中国 上海 联通
228.45 ms
8 218.105.131.197 AS9929 [CNC-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通 CUII
244.68 ms
9 210.14.161.66 * [APNIC-AP] 中国 广东 广州
253.82 ms
10 *
11 *
12 *
13 119.147.61.50 AS4134 [CHINANET-GD] 中国 广东 深圳 www.chinatelecom.com.cn
173.15 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 57.33ms - Misaka.LAX
traceroute to 101.226.41.65, 30 hops max, 52 bytes payload
1 *
2 *
3 10.52.5.1 * RFC1918
0.54 ms
4 *
149.87 ms
226.29 ms
7 218.105.2.89 AS9929 [CNC-BACKBONE] 中国 上海 chinaunicom.cn 联通 CUII
230.48 ms
8 218.105.2.150 AS9929 [CNC-BACKBONE] 中国 上海 chinaunicom.cn 联通 CUII
226.84 ms
9 202.97.16.65 AS4134 [CHINANET-BB] 中国 上海 www.chinatelecom.com.cn 电信
158.79 ms
10 202.97.87.129 AS4134 [CHINANET-BB] 中国 上海 www.chinatelecom.com.cn 电信
158.05 ms
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 87.24ms - Misaka.LAX
traceroute to 220.181.53.1, 30 hops max, 52 bytes payload
1 *
2 *
0.88 ms
4 *
149.29 ms
226.33 ms
7 218.105.2.93 AS9929 [CNC-BACKBONE] 中国 上海 chinaunicom.cn 联通 CUII
226.24 ms
8 218.105.131.101 AS9929 [CNC-BACKBONE] 中国 北京 chinaunicom.cn 联通 CUII
226.10 ms
9 210.78.30.158 * [CNC-BACKBONE] 中国 北京 chinaunicom.cn 联通 CUII
228.56 ms
10 *
11 202.97.17.89 AS4134 [CHINANET-BB] 中国 北京 www.chinatelecom.com.cn 电信
160.03 ms
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
No:4/9 Traceroute to 中国 广州 联通 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 104.21.40.176 - 62.09ms - Misaka.LAX
traceroute to 210.21.4.130, 30 hops max, 52 bytes payload
1 *
2 *
0.73 ms
4 *
149.56 ms
226.08 ms
226.32 ms
8 218.105.131.181 AS9929 [CNC-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通 CUII
250.11 ms
250.88 ms
10 219.158.32.21 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
194.69 ms
11 219.158.22.113 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn
196.27 ms
12 120.82.0.158 AS17816 [APNIC-AP] 中国 广东 广州 chinaunicom.cn 联通
195.86 ms
13 120.80.175.78 AS17622 [APNIC-AP] 中国 广东 广州 chinaunicom.cn 联通
169.89 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 63.37ms - Misaka.LAX
traceroute to 112.65.95.129, 30 hops max, 52 bytes payload
1 *
2 *
3 10.52.4.1 * RFC1918
2.74 ms
4 *
149.43 ms
226.16 ms
7 210.14.165.41 * [APNIC-AP] 中国 上海 联通
225.33 ms
8 218.105.2.174 AS9929 [CNC-BACKBONE] 中国 上海 chinaunicom.cn 联通 CUII
226.67 ms
9 219.158.32.1 AS4837 [CU169-BACKBONE] 中国 上海 chinaunicom.cn 联通
165.14 ms
10 *
11 *
12 210.22.66.174 AS17621 [APNIC-AP] 中国 上海 chinaunicom.cn 联通
155.54 ms
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 55.79ms - Misaka.LAX
traceroute to 61.49.140.217, 30 hops max, 52 bytes payload
1 *
2 *
3 10.52.1.1 * RFC1918
0.59 ms
4 *
149.61 ms
226.37 ms
7 218.105.2.201 AS9929 [CNC-BACKBONE] 中国 上海 chinaunicom.cn 联通 CUII
239.64 ms
8 218.105.131.125 AS9929 [CNC-BACKBONE] 中国 北京 chinaunicom.cn 联通 CUII
231.58 ms
9 210.78.30.142 * [CNC-BACKBONE] 中国 北京 CUI-CNC-Peer chinaunicom.cn 联通 CUII
230.40 ms
10 219.158.32.189 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
195.12 ms
11 *
12 *
13 *
14 *
15 61.49.140.217 AS4808 中国 北京 中国联通 联通
176.20 ms
No:7/9 Traceroute to 中国 深圳 移动 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 104.21.40.176 - 52.89ms - Misaka.LAX
traceroute to 120.233.53.1, 30 hops max, 52 bytes payload
1 *
2 *
0.68 ms
4 *
149.74 ms
226.20 ms
228.87 ms
250.01 ms
9 210.14.161.154 * [APNIC-AP] 中国 广东 广州
247.64 ms
194.19 ms
11 219.158.33.166 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
195.92 ms
12 221.183.94.173 AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
191.25 ms
13 *
14 211.136.208.217 AS56040 [CMNET] 中国 广东 广州 gd.10086.cn 移动
193.60 ms
15 211.136.242.174 AS56040 [CMNET] 中国 广东 广州 gd.10086.cn 移动
194.96 ms
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 61.15ms - Misaka.LAX
traceroute to 183.194.216.129, 30 hops max, 52 bytes payload
1 *
2 *
2.80 ms
4 *
149.86 ms
226.40 ms
226.31 ms
226.66 ms
166.91 ms
10 *
11 221.183.94.1 AS9808 [CMNET] 中国 上海 chinamobileltd.com 移动
164.35 ms
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 62.58ms - Misaka.LAX
traceroute to 211.136.25.153, 30 hops max, 52 bytes payload
1 *
2 *
0.60 ms
4 *
149.69 ms
226.48 ms
226.33 ms
230.69 ms
228.96 ms
10 219.158.32.45 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
181.92 ms
11 221.183.68.193 AS9808 [CMNET] 中国 北京 chinamobileltd.com 移动
186.51 ms
12 *
13 *
14 *
15 *
16 211.136.67.166 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
187.27 ms
17 211.136.95.226 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
184.44 ms
18 *
19 *
20 211.136.25.153 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
191.40 ms
[/tab]
[tab=“去程路由”]
[/tab]
[tab=“Ping.pe”]
[/tab]
[tab=“哪吒 ICMP”]
[/tab]
[tab=“其他”]
[/tab]
[/tabs]
