测试时间为1天
官网:https://www.twnwd.com/tw/about.php
价格:900RMB/月
Yet-Another-Bench-Script
v2024-06-09
GitHub - masonr/yet-another-bench-script: YABS - a simple bash script to estimate Linux server performance using fio, iperf3, & Geekbench · GitHub
Wed 11 Sep 2024 06:25:47 PM CST
Basic System Information:
Uptime : 0 days, 0 hours, 16 minutes
Processor : Intel(R) Core™ i3-4160 CPU @ 3.60GHz
CPU cores : 4 @ 3601.330 MHz
AES-NI :
Enabled
VM-x/AMD-V :
Enabled
RAM : 3.8 GiB
Swap : 0.0 KiB
Disk : 915.8 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-32-amd64
VM Type : NONE
IPv4/IPv6 :
Online /
Offline
IPv4 Network Information:
ISP : DDOS
ASN : AS59371 Dimension Network \u0026 Communication Limited
Host : DDoS Capsula Solution Limited
Country : Hong Kong
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
Read | 768.00 KB/s (192) | 10.81 MB/s (168)
Write | 804.00 KB/s (201) | 11.33 MB/s (177)
Total | 1.57 MB/s (393) | 22.15 MB/s (345)
Read | 47.03 MB/s (91) | 58.81 MB/s (57)
Write | 49.49 MB/s (96) | 63.49 MB/s (62)
Total | 96.52 MB/s (187) | 122.30 MB/s (119)
cue elevator music
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 930
Multi Core | 1868
Full Test | https://browser.geekbench.com/v5/cpu/22857317
YABS completed in 5 min 58 sec
</e></CODE> <e>[/tab]</e></TAB> <TAB name="融合怪"><s>[tab="融合怪"]</s> <CODE><s>
VPS融合怪版本:2024.08.29
Shell项目地址:GitHub - spiritLHLS/ecs: VPS 融合怪服务器测评项目 更推荐使用无环境依赖的Go版本 VPS Fusion Monster Server Test Script – More recommended to use the Go version with no environment dependencies: https://github.com/oneclickvirt/ecs · GitHub
Go项目地址:GitHub - oneclickvirt/ecs: VPS Fusion Monster Server Test GO Version Aiming to be the most comprehensive server testing project, implemented in Go with zero environment dependencies. VPS融合怪服务器测评项目 GO版本 尽量成为最全能的服务器测评项目,使用 Go 实现,无需任何环境依赖。 · GitHub
CPU 型号 : Intel(R) Core™ i3-4160 CPU @ 3.60GHz
CPU 核心数 : 1 物理核心, 2 总核心, 4 总线程数
CPU 频率 : 3600.010 MHz
CPU 缓存 : L1: 128.00 KB / L2: 512.00 KB / L3: 3.00 MB
AES-NI指令集 :
Enabled
VM-x/AMD-V支持 :
Enabled
内存 : 113.42 MiB / 3.79 GiB
硬盘空间 : 908.42 MiB / 937795.02 MiB
启动盘路径 : /dev/sda1
系统在线时间 : 0 days, 0 hour 23 min
负载 : 1.02, 1.33, 1.10
系统 : Debian GNU/Linux 11 (bullseye) (x86_64)
架构 : x86_64 (64 Bit)
内核 : 5.10.0-32-amd64
TCP加速方式 : cubic
虚拟化架构 : Dedicated
NAT类型 : Full Cone
IPV4 ASN : AS59371 Dimension Network & Communication Limited
IPV4 位置 : Hong Kong / Hong Kong / HK
1 线程测试(单核)得分: 1/1
1 线程测试(单核)得分: 1037 Scores
4 线程测试(多核)得分: 1/1
4 线程测试(多核)得分: 3741 Scores
单线程读测试: 1/1
单线程读测试: 25068.33 MB/s
单线程写测试: 1/1
单线程写测试: 17322.71 MB/s
测试操作 写速度 读速度
100MB-4K Block ->
100MB-4K Block 56.7 MB/s (13.85K IOPS, 1.85s) ->
100MB-4K Block 56.7 MB/s (13.85 IOPS, 1.85s) 64.2 MB/s (15679 IOPS, 1.63s)
1GB-1M Block ->
1GB-1M Block 169 MB/s (161 IOPS, 6.22s) ->
1GB-1M Block 169 MB/s (161 IOPS, 6.22s) 170 MB/s (162 IOPS, 6.16s)
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
IPV4:
安全得分:
声誉(越高越好): 0 [2]
信任得分(越高越好): 10 [8]
VPN得分(越低越好): 86 [8]
代理得分(越低越好): 87 [8]
社区投票-无害: 0 [2]
社区投票-恶意: 0 [2]
威胁得分(越低越好): 98 [8]
欺诈得分(越低越好): 0 [1 E]
滥用得分(越低越好): 0 [3]
ASN滥用得分(越低越好): 0.0001 (Very Low) [A]
威胁级别: low [9 B]
黑名单记录统计:(有多少黑名单网站有记录):
安全信息:
使用类型: hosting [0 7] corporate [9] DataCenter/WebHosting/Transit [3] business [8] isp [A] hosting - high probability [C]
公司类型: hosting [0 7 A]
是否云提供商: Yes [7 D]
是否数据中心: No [8] Yes [0 1 5 6 A C]
是否移动设备: Yes [E] No [5 A C]
是否代理: No [0 1 4 5 6 7 8 9 A B C D E]
是否VPN: No [0 1 6 7 A C D E]
是否Tor: No [0 1 3 6 7 8 A B C D E]
是否Tor出口: No [1 7 D]
是否网络爬虫: No [9 A B E]
是否匿名: No [1 6 7 8 D]
是否攻击者: No [7 8 D]
是否滥用者: No [7 8 A C D E]
是否威胁: No [7 8 C D]
是否中继: No [0 7 8 C D]
是否Bogon: No [7 8 A C D]
是否机器人: No [E]
DNS-黑名单: 313(Total_Check) 0(Clean) 6(Blacklisted) 21(Other)
Google搜索可行性:YES
LocalPort
QQ
163
Sohu
Yandex
Gmail
Outlook
Office365
Yahoo
MailCOM
MailRU
AOL
GMX
Sina
-----------------------全国延迟检测–本脚本原创-------------------------
联通上海 31 | 联通福州 38 | 联通天津 47 |
联通南充 54 | 联通太原 58 | 联通大连 60 |
联通WuXi 41 | 电信武汉 36 | 电信宁波 39 |
电信杭州 43 | 电信长沙 42 | 电信苏州 52 |
电信南京 56 | 电信兰州 56 | 电信新乡 55 |
电信Zhenjiang 57 |
位置 上传速度 下载速度 延迟
Speedtest.net 94.92Mbps 4.27Mbps 1.42ms
日本东京 71.41Mbps 79.14Mbps 50.22ms
联通上海5G 66.54Mbps 86.46Mbps 33.17ms
联通WuXi 37.48Mbps 75.00Mbps 36.84ms
电信浙江 30.50Mbps 30.56Mbps 32.19ms
电信浙江 36.35Mbps 26.78Mbps 44.61ms
该运营商.net的节点列表为空,正在替换为.cn的节点列表。。。
总共花费 : 4 分 34 秒
时间 : Wed Sep 11 18:36:31 CST 2024
[?25h 短链:
http://hpaste.spiritlhl.net/u/yOj6jp.txt
IP质量体检报告:103.93.*.*
bash <(curl -sL IP.Check.Place)
报告时间:2024-09-11 18:36:40 CST 脚本版本:v2024-07-29
一、基础信息(Maxmind 数据库)
自治系统号: AS59371
组织: Dimension Network & Communication Limited
坐标: 114°9′57″E, 22°15′28″N
地图: https://check.place/22.2578,114.1657,13,cn
城市: N/A
使用地: [HK]香港, [AS]亚洲
注册地: [HK]香港
时区: Asia/Hong_Kong
IP类型: 原生IP
二、IP类型属性
使用类型: 机房 机房 家宽 机房 机房
公司类型: 机房 机房 家宽
三、风险评分
风险等级: 极低 低 中等 高 极高
SCAMALYTICS: 0|低风险
ipapi: 0.00%|极低风险
AbuseIPDB: 0|低风险
IPQS: 0|低风险
DB-IP: |低风险
四、风险因子
地区: [HK] [HK] [HK] [HK] [HK] [HK] [HK] [HK]
代理: 否 否 否 否 否 否 否 否
Tor: 否 否 否 否 否 否 否 否
VPN: 否 否 否 否 否 无 否 否
服务器: 是 是 是 无 否 否 是 是
滥用: 否 否 否 否 无 否 无 无
机器人: 否 否 无 否 否 无 无 无
五、流媒体及AI服务解锁检测
状态: 失败 解锁 解锁 解锁 解锁 屏蔽 仅APP
方式: 原生 原生 原生 原生 原生
六、邮局连通性及黑名单检测
本地25端口:阻断
IP地址黑名单数据库: 有效 439 正常 434 已标记 5 黑名单 0
今日IP检测量:470;总检测量:101409。感谢使用xy系列脚本!
报告链接:https://Report.Check.Place/IP/3RFW5LPB6.svg
改版地址 GitHub - xykt/RegionRestrictionCheck: A bash script to check the status of your IP on various geo-restricted services. · GitHub
** 测试时间: Wed 11 Sep 2024 06:37:34 PM CST
** 正在测试IPv4解锁情况
** 您的网络为: Dimension Network & Communication (103.93..)
Dazn: 原生解锁 Yes (Region: HK)
TikTok: Failed
Disney+: 原生解锁 Yes (Region: HK)
Netflix: 原生解锁 Yes (Region: HK)
YouTube Premium: 原生解锁 Yes (Region: HK)
Amazon Prime Video: 原生解锁 Yes (Region: HK)
TVBAnywhere+: No
iQyi Oversea Region: 原生解锁 HK
YouTube CDN: Los Angeles, CA
Netflix Preferred CDN: Hong Kong
Spotify Registration: No
Steam Currency: HKD
ChatGPT: 原生解锁 APP Only (Region: HK)
Google Gemini: No
Bing Region: HK
Wikipedia Editability: No
Instagram Licensed Audio: ->
—Forum—
Reddit: Yes
=============[ Hong Kong ]=============
Now E: Yes
Viu.com: 原生解锁 Yes (Region: HK)
Viu.TV: Yes
MyTVSuper: 原生解锁 Yes
HBO GO Asia: Yes (Region: HK)
SonyLiv: Failed (Network Connection)
BiliBili Hongkong/Macau/Taiwan: Yes
Bahamut Anime: No
当前主机不支持IPv6,跳过…
本次测试已结束,感谢使用此脚本
检测脚本当天运行次数: 7; 共计运行次数: 130052
正在测试 https://www.google.com
尝试 1: 75.806000 ms
尝试 2: 84.254000 ms
尝试 3: 92.825000 ms
尝试 4: 81.091000 ms
尝试 5: 80.656000 ms
平均时间: 82.92 ms for https://www.google.com
正在测试 https://www.facebook.com
尝试 1: 360.128000 ms
尝试 2: 281.777000 ms
尝试 3: 331.025000 ms
尝试 4: 324.977000 ms
尝试 5: 275.258000 ms
平均时间: 314.63 ms for https://www.facebook.com
正在测试 https://www.twitter.com
尝试 1: 336.036000 ms
尝试 2: 325.133000 ms
尝试 3: 359.801000 ms
尝试 4: 356.154000 ms
尝试 5: 335.375000 ms
平均时间: 342.49 ms for https://www.twitter.com
正在测试 https://www.youtube.com
尝试 1: 135.414000 ms
尝试 2: 127.505000 ms
尝试 3: 128.658000 ms
尝试 4: 170.572000 ms
尝试 5: 121.766000 ms
平均时间: 136.78 ms for https://www.youtube.com
正在测试 https://www.netflix.com
尝试 1: 558.281000 ms
尝试 2: 648.429000 ms
尝试 3: 551.011000 ms
尝试 4: 498.567000 ms
尝试 5: 529.746000 ms
平均时间: 557.20 ms for https://www.netflix.com
正在测试 https://chat.openai.com
尝试 1: 44.319000 ms
尝试 2: 28.648000 ms
尝试 3: 50.759000 ms
尝试 4: 42.461000 ms
尝试 5: 26.566000 ms
平均时间: 38.55 ms for https://chat.openai.com
正在测试 https://www.github.com
尝试 1: 113.542000 ms
尝试 2: 120.758000 ms
尝试 3: 122.053000 ms
尝试 4: 113.487000 ms
尝试 5: 112.109000 ms
平均时间: 116.38 ms for https://www.github.com
网站 平均时间(ms)
https://www.google.com 82.92 ms
https://www.facebook.com 314.63 ms
https://www.twitter.com 342.49 ms
https://www.youtube.com 136.78 ms
https://www.netflix.com 557.20 ms
https://chat.openai.com 38.55 ms
https://www.github.com 116.38 ms
Total Avg 226.99 ms
Version : v2024-04-25
Usage : bash <(curl -sL bash.icu/speedtest)
GitHub : GitHub - i-abc/Speedtest: 多功能测速脚本 | Multi-functional speedtest script · GitHub
测速节点 下载/Mbps 上传/Mbps 延迟/ms 抖动/ms
最近的测速点 4.23 Mbps 93.98 Mbps 1.28 ms 0.09 ms
电信 江苏苏州 34.82 Mbps 94.81 Mbps 55.42 ms 0.02 ms
电信 浙江杭州 35.49 Mbps 94.80 Mbps 44.35 ms 0.04 ms
电信 浙江宁波 5G 49.16 Mbps 23.99 Mbps 37.29 ms 0.24 ms
电信 江苏镇江 5G 34.62 Mbps 94.03 Mbps 56.53 ms 0.12 ms
电信 江苏南京 5G 35.68 Mbps 63.72 Mbps 50.87 ms 0.04 ms
联通 江苏无锡 75.06 Mbps 94.03 Mbps 43.09 ms 0.04 ms
测速次数过多,暂时被限制,请过一段时间后再进行测试
系统时间:2024-09-11 18:40:57 CST
北京时间: 2024-09-11 18:40:57 CST
No:1/9 Traceroute to 中国 深圳 电信 (TCP Mode, Max 30 Hop, IPv4)
NextTrace v1.3.4 2024-09-10T13:25:26Z 6a3ea6a
[NextTrace API] preferred API IP - 172.67.155.192 - 44.55ms - Misaka.HKG
traceroute to 59.36.216.1, 30 hops max, 52 bytes payload
1 45.126.181.1 AS59371 中国 香港 dimensionet.com
0.41 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 37.98ms - Misaka.HKG
traceroute to 101.226.41.65, 30 hops max, 52 bytes payload
0.39 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 47.31ms - Misaka.HKG
traceroute to 220.181.53.1, 30 hops max, 52 bytes payload
0.36 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
No:4/9 Traceroute to 中国 广州 联通 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 172.67.155.192 - 48.61ms - Misaka.HKG
traceroute to 210.21.4.130, 30 hops max, 52 bytes payload
0.37 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 38.56ms - Misaka.HKG
traceroute to 112.65.95.129, 30 hops max, 52 bytes payload
0.32 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 40.15ms - Misaka.HKG
traceroute to 61.49.140.217, 30 hops max, 52 bytes payload
0.33 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
No:7/9 Traceroute to 中国 深圳 移动 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 172.67.155.192 - 46.73ms - Misaka.HKG
traceroute to 120.233.53.1, 30 hops max, 52 bytes payload
0.34 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 41.56ms - Misaka.HKG
traceroute to 183.194.216.129, 30 hops max, 52 bytes payload
0.35 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 42.39ms - Misaka.HKG
traceroute to 211.136.25.153, 30 hops max, 52 bytes payload
0.36 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[/tab]
[tab=“去程路由”]
[/tab]
[tab=“Ping.pe”]
[/tab]
[tab=“哪吒 ICMP”]
[/tab]
[tab=“其他”]
[/tab]
[/tabs]
