教你用 LA 9929 搭建临时文件管理系统
首先感谢大佬分享 https://www.nodeloc.com/d/18760
看看配置 ,我估摸着用来 临时存储分享些文本内容,问题不大
</s><i> </i>美西9929线路 1C 256M 5G SSD 10M带宽 200G流量<i> </i><e>
**废话不多说,下面开整**
### 1、搭建Nginx + Php 环境
``` apk update apk add nginx apk add php php-fpm ```
### 2、修改php配置文件为如下内容
  • - 路径 **/etc/php82/php.ini** ```ini [PHP]
    ; 基础设置
    engine = On
    short_open_tag = Off
    precision = 14
    output_buffering = 4096
    zlib.output_compression = Off
    implicit_flush = Off
    serialize_precision = -1
    ; 错误处理和日志记录
    display_errors = Off
    display_startup_errors = Off
    log_errors = On
    error_log = /var/log/php_errors.log
    ignore_repeated_errors = Off
    report_memleaks = On
    track_errors = Off
    ; 文件上传
    file_uploads = On
    upload_max_filesize = 10M
    max_file_uploads = 20
    ; 资源限制
    max_execution_time = 30
    max_input_time = 60
    memory_limit = 96M
    post_max_size = 10M
    ; 数据处理
    default_mimetype = “text/html”
    default_charset = “UTF-8”
    always_populate_raw_post_data = -1
    ; 时区设置
    date.timezone = “Asia/Shanghai”
    ; 会话设置
    session.save_handler = files
    session.save_path = “/var/lib/php/sessions”
    session.use_strict_mode = 0
    session.use_cookies = 1
    session.cookie_secure = 0
    session.use_only_cookies = 1
    ; 其他设置
    cgi.fix_pathinfo = 1
    upload_tmp_dir = /tmp
    realpath_cache_size = 4096k
    realpath_cache_ttl = 120
    ; 禁用危险函数
    disable_functions = exec,passthru,shell_exec,system,proc_open,popen,curl_exec,curl_multi_exec,parse_ini_file,show_source
  • - 路径 **/etc/php82/php-fpm.d/www.conf** ```ini [www] user = nginx group = nginx
    listen = /var/run/php82-fpm.sock
    listen.owner = nginx
    listen.group = nginx
    listen.mode = 0660
    pm = dynamic
    pm.max_children = 50
    pm.start_servers = 5
    pm.min_spare_servers = 5
    pm.max_spare_servers = 35
    pm.max_requests = 500
    ; Status page
    pm.status_path = /status
    ping.path = /ping
    ping.response = pong
    ; Security settings
    security.limit_extensions = .php .phar
    ; Set the PHP environment
    env[HOSTNAME] = $HOSTNAME
    env[PATH] = /usr/local/bin:/usr/bin:/bin
    env[TMP] = /tmp
    env[TEMP] = /tmp
    env[TMPDIR] = /tmp
    ; PHP settings
    php_admin_flag[log_errors] = on
    php_admin_value[error_log] = /var/log/php82-fpm/error.log
    php_admin_value[memory_limit] = 128M
    php_admin_value[upload_max_filesize] = 50M
    php_admin_value[post_max_size] = 50M
  • ### 3、修改Nginx配置文件为如下内容,监听端口随便写,这里以 "52451" 为例
  • - 路径 /etc/nginx/http.d/default.conf
    server {
    listen 52451;
    root /var/www/html;
    index index.php index.html;
    location / {
        try_files $uri $uri/ =404;
        add_header Content-Type "text/plain; charset=utf-8" always;
    location ~ \.php$ {
        include fastcgi_params;
        fastcgi_pass unix:/var/run/php82-fpm.sock;
        fastcgi_index index.php;
        fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
    location ~ /\.ht {
        deny all;
  • ### 4、创建静态文件所需目录
    ```sh mkdir -p /var/www/html/nl chmod -R 777 /var/www/html mkdir -p /var/run ```
    ### 5、将以下文件解压上传到目录 /var/www/html
    [upl-file uuid=1a012347-6fc7-49d9-a987-d4671987e734 size=5kB]html.zip[/upl-file]
    ### 6、启动php和nginx
    ``` rc-service nginx start rc-service php-fpm82 start ```
    ### 7、在 LA 9929后台配置映射端口,在第3步我用的是 “52451”,在网络那里填 52451 ,然后点击更新
    ![配置端口](https://www.nodeloc.com/uploads/default/2024-12-21/1734763978-218670-2024-12-21-145132.png)
    ### 8、打开浏览器访问 >!http://23.224.216.90:52451/!<
    ![主页](https://www.nodeloc.com/uploads/default/2024-12-21/1734764155-298444-2024-12-21-145416.png)
    ![上传文本](https://www.nodeloc.com/uploads/default/2024-12-21/1734764182-23226-2024-12-21-145435.png)
    ### 9、密码修改,打开 upload.php 、file_manager.php 修改保存即可
    `$correct_password = 'your_password_here'; // 设置你的密码`
    :xhj28:**完活儿**,**都看到这儿了,不点个赞再走**?
    可以可以。
    建议使用 GitHub - prasathmani/tinyfilemanager: Single-file PHP file manager, browser and manage your files efficiently and easily with tinyfilemanager · GitHub ,功能更完善
    @“Yucho”#p187406 一个例子,不需要太复杂的功能:xhj15:
    感谢大佬分享。
    谢谢大佬分享
    貌似可以用域名吧,带端口太麻烦
    @“alay”#p187508 我研究研究,看看能不能再写一贴
    @“1panel”#p187401 没什么文化,只能大喊一声我艹
    学到了,感谢
