有没有项目能够实现像Openai, deepseek 等通过api或者其他方式聚合起来,并且搭建在服务器端的。今天尝试了lobechat,它无法达到多端同步,电脑上配置好了,手机上却啥都没有
有的,兄弟有的,这样的项目有两个
GitHub - songquanpeng/one-api: LLM API 管理 & 分发系统,支持 OpenAI、Azure、Anthropic Claude、Google Gemini、DeepSeek、字节豆包、ChatGLM、文心一言、讯飞星火、通义千问、360 智脑、腾讯混元等主流模型,统一 API 适配,可用于 key 管理与二次分发。单可执行文件,提供 Docker 镜像,一键部署,开箱即用。LLM API management & key redistribution system, unifying multiple providers under a single API. Single binary, Docker-ready, with an English UI. · GitHub
GitHub - QuantumNous/new-api: A unified AI model hub for aggregation & distribution. It supports cross-converting various LLMs into OpenAI-compatible, Claude-compatible, or Gemini-compatible formats. A centralized gateway for personal and enterprise model management. 🍥 · GitHub
然后再接一个
GitHub - labring/FastGPT: FastGPT is a knowledge-based platform built on the LLMs, offers a comprehensive suite of out-of-the-box capabilities such as data processing, RAG retrieval, and visual AI workflow orchestration, letting you easily develop and deploy complex question-answering systems without the need for extensive setup or configuration. · GitHub
@"Keggin "#p231126
试试这个,我在用的
GitHub - nick-tonjum/open-webui-artifacts-overhaul: User-friendly AI Interface (Supports Ollama, OpenAI API, ...) · GitHub
是 @“Drift”#7952 分享的 https://www.nodeloc.com/d/22285
跑在服务端,python写的,可以用pip安装
用openai的sdk聚合多个ai,所有支持openai sdk的ai模型都支持添加
@“Xnoob”#p231143 我还以为有求助可以蹭一下,蹭不到咯
