大陆:Oracle Cloud 免费套餐 | Oracle 中国 {一定要使用手机浏览器直接注册,不要使用代理}
台湾:Cloud Free Tier | Oracle 台灣
美国:Oracle Cloud Free Tier | Oracle
### 日本:https://www.oracle.com/jp/cloud/free/
更多地区,稍后补充……
1.WindTerm 远程终端连接器:https://github.com/kingToolbox/WindTerm/releases/tag/2.5.0
2.开放端口:sudo iptables -P INPUT ACCEPT
sudo iptables -P FORWARD ACCEPT
sudo iptables -P OUTPUT ACCEPT
sudo iptables -F
3.部署代理节点
比如一键安装SSR:wget -N --no-check-certificate https://raw.githubusercontent.com/teddysun/shadowsocks_install/master/shadowsocksR.sh
chmod +x shadowsocksR.sh
./shadowsocksR.sh
一键安装OpenVPN:wget https://git.io/vpn -O openvpn-install.sh && bash openvpn-install.sh
或者一键安装V2ray等:apt update
apt install -y git ### 安装 git 环境
wget -N --no-check-certificate -q -O install.sh "https://raw.githubusercontent.com/wulabing/V2Ray_ws-tls_bash_onekey/dev/install.sh" && chmod +x install.sh && bash install.sh
4.如果你担心网站使用率不高被回收,可以配合保活脚本:bash <(wget -qO- --no-check-certificate https://gitlab.com/spiritysdx/Oracle-server-keep-alive-script/-/raw/main/oalive.sh)
