在huggingface上部署komari(webdav同步)
项目地址:
来个成品:
1.创建Dockerfile
FROM ghcr.io/komari-monitor/komari:latest
WORKDIR /app
RUN apk add --update --no-cache python3 py3-pip curl lsof
RUN python3 -m venv /app/venv
ENV PATH="/app/venv/bin:$PATH"
RUN pip install --no-cache-dir requests webdavclient3
RUN mkdir -p /app/data && chmod -R 775 /app/data
RUN chmod -R 775 /app
RUN mkdir -p /app/sync
COPY sync_data.sh /app/sync/
RUN chmod +x /app/sync/sync_data.sh
EXPOSE 25774
CMD ["/bin/sh", "-c", "/app/sync/sync_data.sh & sleep 10 && exec /app/komari server"]
在README.md 末尾添加
app_port: 25774
2.创建sync_data.sh文件
#!/bin/sh
VENV_PYTHON="/app/venv/bin/python"
if [ -z "$WEBDAV_URL" ] || [ -z "$WEBDAV_USERNAME" ] || [ -z "$WEBDAV_PASSWORD" ]; then
    echo "Starting without sync functionality - missing WEBDAV_URL, WEBDAV_USERNAME, or WEBDAV_PASSWORD"
    exit 0
fi
WEBDAV_BACKUP_PATH=${WEBDAV_BACKUP_PATH:-""}
FULL_WEBDAV_URL="${WEBDAV_URL}"
if [ -n "$WEBDAV_BACKUP_PATH" ]; then
    FULL_WEBDAV_URL="${WEBDAV_URL}/${WEBDAV_BACKUP_PATH}"
fi
restore_backup() {
    echo "开始从 WebDAV 下载最新备份..."
    $VENV_PYTHON -c "
import sys
import os
import tarfile
import requests
import shutil
import subprocess
from webdav3.client import Client
options = {
    'webdav_hostname': '${FULL_WEBDAV_URL}',
    'webdav_login': '${WEBDAV_USERNAME}',
    'webdav_password': '${WEBDAV_PASSWORD}'
client = Client(options)
try:
    backups = [file for file in client.list() if file.endswith('.tar.gz') and file.startswith('komari_backup_')]
except Exception as e:
    print(f'连接 WebDAV 服务器出错: {e}')
    sys.exit(1)
if not backups:
    print('没有找到备份文件,跳过恢复步骤。')
    sys.exit(0)
latest_backup = sorted(backups)[-1]
print(f'最新备份文件:{latest_backup}')
try:
    with requests.get(f'${FULL_WEBDAV_URL}/{latest_backup}', auth=('${WEBDAV_USERNAME}', '${WEBDAV_PASSWORD}'), stream=True) as r:
        if r.status_code == 200:
            with open(f'/tmp/{latest_backup}', 'wb') as f:
                for chunk in r.iter_content(chunk_size=8192):
                    f.write(chunk)
            print(f'成功下载备份文件到 /tmp/{latest_backup}')
            # 检查数据库文件是否被占用
            try:
                # 检查整个目录下的文件是否被占用(仅检测主要数据库文件,有需要可扩展)
                pids = subprocess.check_output(['lsof', '-t', '/app/data/komari.db']).decode().strip()
                if pids:
                    print('数据库文件被占用,无法恢复备份。')
                    sys.exit(1)
            except subprocess.CalledProcessError:
                pass
            # 解压整个目录
            with tarfile.open(f'/tmp/{latest_backup}', 'r:gz') as tar:
                tar.extractall('/app/')
            print(f'成功从 {latest_backup} 恢复备份到 /app/data')
        else:
            print(f'下载备份失败:{r.status_code}')
    print(f'恢复备份过程中出错: {e}')
echo "Downloading latest backup from WebDAV..."
restore_backup
sync_data() {
    while true; do
        echo "Starting sync process at $(date)"
        timestamp=$(date +%Y%m%d_%H%M%S)
        backup_file="komari_backup_${timestamp}.tar.gz"
        # 备份整个/app/data目录
        cd /app
        tar -czf "/tmp/${backup_file}" data
        curl -u "$WEBDAV_USERNAME:$WEBDAV_PASSWORD" -T "/tmp/${backup_file}" "$FULL_WEBDAV_URL/${backup_file}"
        if [ $? -eq 0 ]; then
            echo "Successfully uploaded ${backup_file} to WebDAV"
        else
            echo "Failed to upload ${backup_file} to WebDAV"
        fi
        $VENV_PYTHON -c "
options = {
backups.sort()
if len(backups) > 5:
    to_delete = len(backups) - 5
    for file in backups[:to_delete]:
        client.clean(file)
        print(f'Successfully deleted {file}.')
else:
    print('Only {} backups found, no need to clean.'.format(len(backups)))
" 2>&1
        rm -f "/tmp/${backup_file}"
        SYNC_INTERVAL=${SYNC_INTERVAL:-600}
        echo "Next sync in ${SYNC_INTERVAL} seconds..."
        sleep $SYNC_INTERVAL
    done
sync_data &
备份上限5份,同步时间默认600s
3.注册webdav并开启传输权限
4.填入相关变量
#面板变量
ADMIN_USERNAME  # 登录用户名
ADMIN_PASSWORD   # 登录密码
#备份变量
WEBDAV_URL # https://jike.teracloud.jp/dav
WEBDAV_BACKUP_PATH  # 备份文件夹名(备份文件夹,需要自行在网盘中创建,如komari)
WEBDAV_USERNAME # 用户名
WEBDAV_PASSWORD  # 连接密码,第3步获取到的
SYNC_INTERVAL # 同步时间,默认600
一定要是私人变量
5.在cloudflare进行反代
在cloudflare创建一个Workers,填入代码并修改将xxxx.hf.space替换为你的space域名
export default {
  async fetch(request, env) {
    const url = new URL(request.url);
    url.host = 'xxxx.hf.space';
    return fetch(new Request(url, request))
完成后添加自定义域名
6.设置github登录并禁用密码
新建一个 OAuth app
格式
# URL
https://example.com
# callback URL
https://example.com/api/oauth_callback
将获取到的Client ID和Client secrets进行保存
登录komari后台
开启跨域请求
填写获取到的Client ID和Client secrets
绑定github
关闭密码登录
7.更换主题
下载主题
https://github.com/Montia37/komari-theme-purcarte/archive/refs/tags/v1.1.6.zip
上传主题
13 个赞
好详细!谢谢佬
这个面板和哪吒比哪个好用
收藏收藏
大材小用了。
感谢教程 很详细
漂亮,收藏起来:heart_eyes:
太厉害了学习了
谢谢分享步骤教程
真的太厉害了
感谢大佬得的详细教程,学着搭下。
可以可以 等有空试试看
反代设置不错,学一下
感谢教程 很详细
学习一下
学习了,教程不错,
教程很好很详细,部署体验了五天了,一直在线
牛哇
一直提示STARTING
终于成功运行了,可是又卡在登录用户名了一直提示密码错误
