Tinkering Notes
To make use of idle servers, and also as a way to learn and pass the time. I’m also learning on the fly, solving everything with AI. This server comes with a built-in database, so installation is relatively easy; the VPS method is a bit more troublesome—ask AI, look for tutorials, or consult experts. Here I only share the image installation package, which includes over 100 plugins, all downloaded from GitHub and Flarum. The zip is about 60 MB; check its safety yourself. Do not enable unwanted plugins or uninstall them via commands—it’s entirely up to you. It’s sufficient for a personal blog, and also works for a forum. Installing too many plugins may cause incompatibilities and bugs, leading to pages not loading, requiring you to pause or uninstall plugins via commands. The plugins gather the wisdom of dozens to over a hundred developers. Thanks to the platform for their hard work! If you have an idle server and want to tinker, give it a try. Only by learning and tinkering can you move forward.
Common Commands
composer create-project flarum forum “^1.8” Install the latest version of Flarum (compatible with ^1.8)
composer create-project flarum/flarum forum:^2.0 Series
composer update flarum-lang/chinese-simplified Update Chinese language pack
composer outdated Show available updates
composer update Update Flarum project
composer update -W Force update all dependencies
php flarum info List all plugins
composer require flarum/statistics Install plugin
php flarum extension:disable flarum/statistics Disable plugin
composer remove flarum/statistics Remove plugin
php flarum migrate Execute database migrations
php flarum cache:clear Clear cache
php flarum assets:compile Compile front‑end assets
Official Installation Requirements
Before installing Flarum, be sure to check that your server meets the requirements.
To run Flarum you need: Apache (with mod_rewrite enabled) or Nginx
PHP 7.3+ with the following extensions: curl, dom, fileinfo, gd, json, mbstring, openssl, pdo_mysql, tokenizer, zip
MySQL 5.6+/8.0.23+ or MariaDB 10.0.5+
My Installation Parameters, For Reference Only
Flarum image version: 1.8.11
PHP: 8.2.29
MySQL: 10.6.23-MariaD
First create a database name; username; password, and record them for later use. Upload the zip package and extract it to the root directory.
In the browser go to
http(s)://yourdomain:publicto start, enter the database information to install. Afterwards setpublicas the root directory; other operations can be solved by AI. -
Installation Example
Forum Title: mybbs
<choose any name> -
MySQL Host: localhost
<default> -
MySQL Database: flarum
<your database name> -
MySQL Username: root
<your database username> -
Table Prefix: fl_
<any prefix> -
Admin Username:
your_admin<your username> -
Admin Email:
[email protected]<your email> -
Admin Password:
yourPassword<your password> -
Confirm Password:
Flarum Image Download
[reply] 小飞机网盘
