I hadn’t been using Chrome before because the service kept getting blocked, but now that I’ve switched to Chromium with all the Google services removed, it’s much better.
I am a combination of both
I’ve always used Chrome.
Edge is really getting worse and worse—it’s so bloated, they stuff everything into it! I’d like to switch too, but I just can’t get used to the other browsers.
Google has been removed, so what about syncing?
In China, if you’re using Google Kernel, you can just use Quark Netdisk’s browser directly.
Brave, the Web3 browser, is pretty good too. We’re all seasoned pros here—a little firewall like that isn’t going to stop us…
Even if Google Chrome gets blocked, it’s still usable, right? Personally, I can’t get used to Chromium, and there’s nothing much to say about Edge. On Linux, it’s so laggy it makes me question my life choices. I only use Google Chrome.
I can only use Edge to access the forum.
Haven’t really used it much
Edge is my main browser.
Edge really isn’t that user-friendly.
At school, I use the Cheetah Browser, and at home I use Via.
The only reason I use Edge is because you can pin your history entries. According to the official Chrome screenshots, you can pin them there too, but I haven’t been able to find where to do it.
How did you delete it?
Different people have different needs, but Google is still pretty good.
I mainly use Edge and keep Chrome as a backup—Edge paired with its built-in Copilot is really nice.
Copilot also can’t be used without a VPN…
Everyone has their own likes and dislikes; there’s no right or wrong.
Go to Google, start a new journey!
Use iron
