Each Gmail account actually comes with two available email addresses
If your email is [email protected], then [email protected] belongs to you as well, and:
- Automatically activated, no setup required
- Can receive and send emails
- Points to the same inbox, emails won’t be split
This domain was initially used to solve trademark issues: in Germany, Russia, and Poland, the “Gmail” trademark was occupied (for example, in Poland it was registered by a group of poets called “GMAiL”), so Google used @googlemail.com in these countries.
Although the trademark issue has since been resolved, these two domains still work together! ![]()
How to Use
Receiving Emails
No setup required
- Send an email to yourself using another email
- Replace
@gmail.comwith@googlemail.com - The email will reach your inbox
Sending Emails
Want to use @googlemail.com to send emails?
Follow these steps:
Open Gmail Settings
- Click the gear icon in the top right corner
→ “See all settings”
Add a Sending Address
- Go to the “Accounts and Import” tab
- Find the “Send mail as” section
- Click “Add another email address”
Fill in Information
- Name: Enter the name you want to display
- Email address: Enter
[email protected] - Uncheck “treat as an alias” (if you want to track separately)
Verify
- Google will send a verification email to your email (it’s actually to yourself)
- Click the verification link
Switch When Writing Emails
- When writing a new email, click the “From” field
- Choose to send using
@googlemail.com
