2026-01-02
Refactored Version Update Detection System
Refactored the version update detection system to support the new remote API format
Update popup now displays current version, latest version, and release time
Supports rendering update logs in HTML format
Added forced update functionality; management backend operations are blocked during forced updates
Forced updates display a fullscreen overlay; users must update before continuing
Non-forced updates support “Remind Me Later” to close the popup
Added multilingual support (Chinese/English) for version update features
2026-01-01
Coupon Product Type Selection
Coupons now have an “Applicable Product” option; can choose: All, Domain, or VPS Hosting
Coupon list in admin backend displays product type tags
Auto-validate coupon product type match when users use a promo code
Database migrates automatically to add
applicable_typefield
VPS Hosting Plan Server Binding
Plan management now supports server selection; can specify which server the plan is created on
If not specified, automatic load balancing is applied
Associated server names are displayed in plan list
Purchase page filters plans based on server settings
Batch Delete Feature in Admin Backend
Host instance management page now supports batch delete, including multi-selection
Orders management page now supports batch delete, including multi-selection
Added select all/deselect all functions
Shows progress indicator during deletion
Fixed issue where deleting hosts was only performing soft delete; now records are fully removed from the database
Domain bindings associated with a host are also cleaned when the host is deleted
VPS Hosting Run Directory, Rewrite, and SSL Management
Added run directory settings, supporting frameworks like Laravel/ThinkPHP to set public directory
Added rewrite rule management, supports popular templates for WordPress, ThinkPHP, Laravel, etc.
Added SSL deployment, supports manual certificate upload (private key and cert)
Added one-click Let’s Encrypt free certificate application
New force HTTPS toggle; easily enable/disable HTTP to HTTPS redirection
SSL info display (issuer, expiration date)
VPS Hosting PHP Version Management
Added PHP version switching; users can select PHP version on host details page
New hosts now use the server’s default PHP version (not pure static)
Fetches list of installed PHP versions on the server
Displays current and available PHP versions on host detail page
VPS Hosting Online File Management
Added online file manager; users can manage website files via the web client
Supports browsing directories and viewing file lists
Create files/folders
Edit text files online (html/css/js/php/txt etc.)
Rename/delete files and folders
Added batch selection: select all/multi-select files
Added batch copy/cut/paste
Added batch delete
New compression functionality; compress files/folders into zip packages
Decompression: supports zip/tar/gz etc.
Path safety check to ensure only user’s own website directory is accessible
Fixed parsing bug with Baota API file list format
Fixed incompatibility with paths between Windows dev environments and Linux servers
VPS Host Domain Binding Feature
Added VPS host domain binding management
Host detail page displays bound domain list
Supports add/delete domain bindings (limited by plan)
Domain bindings auto-sync to Baota Panel
New
vhost_domainstable to store binding info
2025-12-31
VPS Hosting Distribution Module
Added VPS hosting distribution features, automates creation and management via Baota Panel API
Admin backend has new VPS host management menu: servers, plans, hosts, orders
User side adds VPS features: buy host, my hosts, host details
Supports server load balancing, automatically selects server with lowest load
Supports renew, pause, resume, delete for hosts
Auto-generates FTP and database credentials
Host details page shows FTP & DB connection info
Added expiry check cron job script
scripts/check_vhost_expiry.py -
Supports expiration reminder emails (7, 3, and 1 day in advance)
Expired hosts are automatically paused and status updated
Alibaba Cloud DirectMail Support
Added Aliyun DirectMail email push support
Supports switching between SMTP and Aliyun API sending modes
System settings page in admin backend adds Aliyun mail config
Added test mail-sending API, allows testing current config
Admin Domain Record Lookup Fixes
Fixed 404 error when querying DNS records in admin domain management
Added
/api/admin/subdomains/<id>/recordsendpoint
Static Resource Localization
ECharts chart library switched from CDN to local
Downloaded echarts.min.js to static/js/
Project policy updated: remote CDN links not allowed
Hosting Reseller Plan Management Fixes
Fixed failure when adding plans for hosting resellers
Plan form now supports multi-select associated domains
Added min/max character limit config for plans
Plan list now displays associated domain tags
Optimized form validation: check required fields before submission
Managed Domain Tag Distinction
Distinguish between platform and reseller domains on user domain purchase page
Reseller domains show purple “Managed” tag
Homepage domain search results also show managed tag
Full domain query results show managed tag
Hosting Channel Deletion Fixes
Fixed issue where resellers couldn’t delete channels after adding domains
When deleting a channel, only check the reseller’s domains; does not affect others
Hosting Domain Deletion Optimization
When domain is deleted, all subdomains and plan associations are deleted
If plan is only associated with that domain, delete entire plan
If plan is associated with multiple domains, just remove that domain association
When deletion is done, show numbers of cleaned subdomains/plans
Hosting Channel Management Optimization
Hosting reseller channel management page refactored, now matches admin channel management features
Supports dynamic credential fields, shows items based on service provider type
Added channel credential validation: online test if config is correct
Sidebar for resellers adds “Channel Management” menu entry
Hosting Domain Management Optimization
Hosting domain management page refactored, now matches admin domain management
Supports auto-fetching domain list from channels, multi-select import
Can toggle domain “registrable” status
Added API for fetching channel domain list (/api/host/channels//zones)
User Sidebar Hosting Reseller Entry
“Apply to Be a Reseller” link added in user center sidebar
Shows different tags depending on user’s reseller status (under review/certified)
Link takes user to reseller console or application page
Separate sidebar for reseller console: Home, Channel Management, Domain Management, Plan Management, Transaction Records
Non-reseller users see simplified sidebar on application page
Fixed user API not returning reseller status
Admin backend sidebar adds “Hosting Management” menu: applications, reseller list, system settings
Domain Hosting Feature
New domain hosting system, users can apply to be resellers
Resellers can add their own DNS channels, domains, and plans
When other users buy reseller domains, profit is automatically shared to reseller
Platform can set commission rate, resellers get profit share after commission
Reseller panel: view earnings stats, manage channels/domains/plans, view transactions
Admin functions: approve reseller applications, manage resellers, set system params
Supports suspend/resume/revoke reseller privileges
APP Client Captcha Support
When requesting from APP client, use image captcha to bypass Cloudflare Turnstile
APP client must add
X-Client-Type: appheader in requests -
Supports all captcha scenarios: login, register, password recovery, change password/email
App Update Log
2026-01-02
Homepage Style Fixes
- Fixed missing
<style>inpages/index/index.vue - Added complete homepage styles: navbar, hero section, announcement bar, stats area, product cards, domain suffix, my assets, quick services, features area, footer, etc.
VPS Hosting User Module
- Added
api/vhost.jsVPS user API:- Plans:
getVHostPlansget plan list - Orders:
purchaseVHostpurchase a VPS - Instance mgmt:
getVHostInstances,getVHostInstance,renewVHost - Order records:
getVHostOrders - Domain binding:
getInstanceDomains,addInstanceDomain,deleteInstanceDomain - File mgmt:
getFiles,readFile,saveFile,createFile,createDir,deleteFile,renameFile,copyFile,moveFile,zipFile,unzipFile - PHP version:
getPhpVersions,setPhpVersion - Run path:
getRunPath,setRunPath - Rewrite:
getRewrite,setRewrite,getRewriteTemplate - SSL certificate:
getSslStatus,deploySsl,closeSsl,setForceHttps
- Plans:
- Added
pages/vhost/purchase.vueVPS purchase page:- List plans (disk, bandwidth, domain count, DB, etc.)
- Highlight selected plan
- Domain input
- Promo code support
- On success, redirect to detail page
- Added
pages/vhost/list.vueVPS list page:- List hosts (domain, status, expiry, plan)
- Filter by status (all, normal, expiring, expired)
- Pull-to-refresh
- Click to view detail
- Added
pages/vhost/detail.vueVPS detail page:- Info tab: FTP/DB connection, plan config (with copy button)
- Domain tab: list, add/delete domain, check limits
- File mgmt tab: file list, breadcrumb navigation, new file/folder, edit/delete/rename, copy/move, zip/unzip
- Settings tab: PHP switch, run path setting, rewrite rules (template selection), SSL deploy/disable/force HTTPS
- Renewal function
- Added VPS hosting entry to personal center (quick actions & menu)
- Added VPS routes to
pages.json
VPS Hosting Admin Module
- Added VPS admin APIs in
api/admin.js:- Server mgmt:
getVHostServers,addVHostServer,updateVHostServer,deleteVHostServer,testVHostServer - Plan mgmt:
getAdminVHostPlans,createVHostPlan,updateVHostPlan,deleteVHostPlan - Instance mgmt:
getAdminVHostInstances,updateVHostInstance,deleteVHostInstance,batchDeleteVHostInstances - Order mgmt:
getAdminVHostOrders,deleteVHostOrder,batchDeleteVHostOrders - Stats:
getVHostStats
- Server mgmt:
- Added
pages/admin/vhost.vueVPS admin page:- Stats tab: total revenue, monthly revenue, host count, server count, etc.
- Servers tab: CRUD for Baota Panel servers, test connections
- Plans tab: CRUD for VPS plans, including disk, traffic, domains, etc.
- Hosts tab: host instance list, filter, pause/resume, change expiry, delete, batch delete
- Orders tab: order list, filter, delete, batch delete
- Added VPS management entry to admin backend homepage
OAuth Third-Party Login Binding
- Added OAuth-related APIs to
api/auth.js:getGithubStatus()- Get GitHub OAuth statusgetGoogleStatus()- Get Google OAuth statusgetNodelocStatus()- Get NodeLoc OAuth statusgetOAuthBindable()- Get which OAuth providers can be boundgetOAuthAuthUrl(provider)- Get OAuth auth URLbindOAuth(provider)- Bind OAuth accountunbindOAuth(provider)- Unbind OAuth account
- Added third-party account binding section to security settings (
pages/settings/security.vue):- Supports GitHub, Google, NodeLoc
- Shows provider enabled/disabled and binding status
- Supports bind/unbind actions
- Handles OAuth callback params
- Added third-party login to login page (
pages/login/login.vue):- Shows enabled OAuth login buttons
- Supports GitHub, Google, NodeLoc quick login
- Handles OAuth login callback
Alibaba Cloud Mail Push Settings
- Added
testAliyunDM()API inapi/admin.jsto test Aliyun mail - Added Aliyun mail push settings block to system settings page (
pages/admin/settings.vue):- Toggle on/off
- Access Key & Access Secret config
- Region select (East China 1 - Hangzhou, North China 2 - Beijing, East China 2 - Shanghai, Singapore)
- Sender email config
- Test sending
- Toggle and form field linkage
