Ukraine ESIM, sign up for 8 Chinese yuan, $0.25 per month for one year
My signal is there, but I’m not receiving the code
Thank the topic starter for sharing
Why receive a message if you don’t get a text message?
:xhj27:
:ac01: Ask the customer service if this 50 card fee is something that won’t be received, and if they need to receive it, they will need to buy a package.
What is the price of the cheapest plan?
Does it mean that you need to recharge at least 10 UAH per year to keep the number active for a year?
Good recommendation…
Thanks great contributor for sharing
Can 5esim/小白卡 work, or does it have to be natively supported esim?
This esim is for number preservation, which is just number porting. Domestic number porting has long been impossible, so it’s better to note this clearly when recommending.
8 bucks blood loss :ac01:
@myjun Professor, is this ESIM suitable for long-term code reception?
Minimum recharge 20 grivnas, tg does not receive SMS code (does not receive SMS or voice codes)
Need to purchase a package to receive SMS. Reminder for those who want to get on board later, you can activate with the 9esim 9.9 yuan card.
fear of running away
Now you won’t get roaming unless you buy a package, and if you use it domestically without logging in to the app in advance, going back to activate the package won’t help either
9th
How did you all pay?
Thanks for sharing!
This needs to stay on the always-on package, otherwise there’s no signal, this number is not worth it
