Ukraine ESIM, sign up for 8 Chinese yuan, $0.25 per month for one year
https://shop.lifecell.ua/en/product/starter-package-lifecell-esim/197/2941/?tab=description
This is a Ukrainian eSIM, you can go to the order page and fill in any Ukrainian phone number, no verification is required.
Recharge minimum is 10 via the app, equivalent to 1.6 RMB, opening fee is 50, equivalent to 8 RMB, after purchase, 50 RMB will be credited, you can buy a package or not, validity period is 180 days, recharge 10 RMB (approximately 1.6 RMB) to extend for 365 days.
It looks great!
This should be a honeybee
Thanks for sharing, support
This country is beaten up so badly, survive somehow~ :xhj001:
What are some low-cost methods to use these cards if I don’t have an esim phone?
Ha ha
What payment methods are supported
Now the software allows charging 20 at once
No eSIM phone Does this require a credit card Well I’ll try it directly, thanks
So good, thank you for sharing
thank you
I’ll check if I need to cut one.
go take a look afterwards
I can’t because my phone doesn’t support eSIM and I haven’t bought a physical eSIM card
look
Thanks for sharing, support the OP!
Did international roaming bans start from 10.21.25?
It looks very good.
