Woke up and found the nodes down, unable to log into the VPS. Does anyone know the reason?
My us3 is currently functioning normally
Is it the cf tunnel? If so! Change to preferred IP! If not! Check if the IP is blocked!
I said last year I would go to抢 one in the middle of the night then forgot about it
Preferred IP changed, still -1.主要是finalshell also failed to connect.
ip is probably blocked! check itdog.cn
This situation! Generally delete and抢again!
Log in to see if it’s shut down
No need to look! SSH is down! Not an optimal issue!
What should I do? Should I go to the official website and check vps-info or active?
Restart! Then see if SSH can log in! If it still cannot! Delete and grab again!
Log in using his official SSH
Isn’t that obvious? If you understand how to warp, then great! If not, post a thread and ask the forum experts to help you warp! Then use warp to play! I don’t know how to warp!
This thing is easy to forget to renew, and I have let it slip several times.
tg Submit the issue above
tcping ipv6:ssh on itdog
After restarting on the official site, I can connect via SSH and xray is working normally, but the node is still inaccessible. When the client tries to connect, there’s nothing in the logs at all.
root@8117816201hax:~# journalctl -u xray -f
– Journal begins at Sat 2026-02-14 10:25:00 CET. –
Feb 23 15:05:51 8117816201hax.localdomain systemd[1]: Stopping Xray Service…
Feb 23 15:05:51 8117816201hax.localdomain systemd[1]: xray.service: Succeeded.
Feb 23 15:05:51 8117816201hax.localdomain systemd[1]: Stopped Xray Service.
Feb 23 15:05:51 8117816201hax.localdomain systemd[1]: Started Xray Service.
Feb 23 15:05:51 8117816201hax.localdomain xray[7887]: Xray 26.2.6 (Xray, Penetrates Everything.) 12ee51e (go1.25.7 linux/amd64)
Feb 23 15:05:51 8117816201hax.localdomain xray[7887]: A unified platform for anti-censorship.
Feb 23 15:05:51 8117816201hax.localdomain xray[7887]: 2026/02/23 15:05:51.472210 [Info] infra/conf/serial: Reading config: &{Name:/usr/local/etc/xray/config.json Format:json}
Feb 23 15:05:51 8117816201hax.localdomain xray[7887]: 2026/02/23 15:05:51.508305 [Warning] common/errors: The feature WebSocket transport (with ALPN http/1.1, etc.) is deprecated, not recommended for using and might be removed. Please migrate to XHTTP H2 & H3 as soon as possible.
Feb 23 15:05:51 8117816201hax.localdomain xray[7887]: 2026/02/23 15:05:51.508519 [Warning] common/errors: The feature VLESS (with no Flow, etc.) is deprecated, not recommended for using and might be removed. Please migrate to VLESS with Flow & Seed as soon as possible.
Feb 23 15:05:51 8117816201hax.localdomain xray[7887]: 2026/02/23 15:05:51.594886 [Warning] core: Xray 26.2.6 started
My god, it’s turned off, need to power it on from the page
Solved, cat /etc/resolv.conf showed no output, adding it again fixed the issue. The client node is now connected. To prevent losing the configuration after a reboot, it’s recommended to fix the DNS configuration using the systemd solution.
