VPS Recommendation: RN (You can also use others), see my previous post: Link Cheap (Some areas during the day work fine, you can buy San Jose instead of Los Angeles), ticket service is good.
Is it about Aliyun 68? Why buy Aliyun? Isn’t it better to buy RN’s or other foreign machines? But you can’t even make them query certain sites when buying Aliyun.
This approach works. I’ll add a more stable deployment order for later reference:
Run the minimal viable version on a cheap VPS (only start core services)
Connect to Coding Plan next, first implement API connectivity + rate limiting
Finally add monitoring (CPU/memory/disk + process health)
Many people fail not because of misconfiguration, but by adding too many components at once. Deploying first, then adding features, greatly increases success rates.
