New site launched. GPT series at 0.1x rate. gpt-image-2 free
New site launch. GPT series at 0.1x rate. gpt-image-2 is free
gpt-image-2 distribution is prohibited. If distribution is detected, speed will be limited to 5 times per minute. Since it’s a free server, it uses a lot of bandwidth—free access is only for regular users.
The codex-gpt-image-2 in the site has the same name.
The site supports online generation of codex-gpt-image-2, but this does not support reference images; you can call the API to use reference images. Image generation on the site hasn’t been made compatible yet.
Remember to use the GPT Benefits Zone!
Thanks for sharing—hope to be able to use GPT-IMAGE2.
Thanks for sharing. Let’s see if img2 works.
I tried it—img2 works, but it only lets you use it once. After that, it says you’re out of credits…
GPT Benefits Section
Oh, it’s the benefits section! I went with the GTP Codex suite, so now I’ll try switching to a different section.
Thanks for sharing, boss!
www.uocode.com
QQ Group: 1074257787
codex-gpt-image-2 Limited Time Offer: 0.000? Yuan per image. There is actually a charge, but it’s sufficient for use. The price I set on the backend is 0.001*multiplier. New registrations get $0.2. Redistribution is prohibited. codex-gpt-image-2 is available in the GPT Benefits section.
GPT has a 0.1x multiplier, which may increase at any time!
This topic was automatically closed 7 days after the last reply. No new replies are allowed.
