Both are run by the same admin—we usually call him
Lao Deng, because he’s always telling us to hammer his relay stations.
First, the Public Benefit Relay Station
Completely free—just check in daily and you can get dozens of bucks worth. Domestic models are free to use, with super low rates, good enough for running some small crawlers without a problem.
Next, the Paid Relay Station <— This link has an aff code; hope you guys can support a bit! Registration comes with a free balance so you can give it a quick try.
Claude model limited-time deal: 0.2 rate until the evening of May 6, hurry up!
Honestly, it’s really handy. Regular accounts are free accounts registered by the admin with a script, and Pro are purchased paid accounts. You can compare tokens and consumption for yourself, and overall the rates are great. It even supports relaying for Claude models—image generation is just 0.5 per use.
Top-up rate is 1:10, 1 RMB = 10 dollars
This is my first topic post; if there are any issues, please let me know—thanks!
