[Absolutely Free] Resvrl offers 0.75 months of free Hong Kong VPS—multiple accounts allowed.
Thanks to the bro for the info: 免费薅香港小鸡
As everyone knows, using an AFF link gets you a ¥20 balance + a 30% off coupon. You can use the AFF link from the bro above​:backhand_index_pointing_up:, or you can use mine.
Resvrl AFF
Currently, the 1c1g VPS is out of stock, so you can’t get one for a whole free month with 20 RMB. If you pay by usage per hour, you can only use it for 10 days, and you can’t use the 30% off coupon.
You can use a custom config to change the default 1 month to 0.75 months. Note that you need to copy and paste 0.75 in.
:xhj15::xhj15::xhj15::xhj15:
This is a scam for affiliate (aff). When you go through the link, it says you’ve registered before. Forget it—can’t play this game, probably going out of business soon anyway!
Are there any reviews of their products?
You need a fingerprint browser :xhj001:
Damn, 0.75
Too lazy to bother with this—it’s so crappy, might as well just shut down.
You can also try it out for 10 days.
23 days :xhj001:
0.75 months Interesting, thanks for sharing, boss!
Bro, you’re way too smart, such a little genius :xhj19:
Even a value like 0.75 can be discovered—it really shows someone dove pretty deep into the research.
Looks like everything’s out of stock.
Totally! :xhj005:
You can get it for 18 yuan without needing a public network card.
此话题已在最后回复的 7 天后被自动关闭。不再允许新回复。
