My custom-built blog is basically ready—this is the first post published using the built-in admin panel, just recording the moment
If you’re interested, check it out—it’s an introduction to man-in-the-middle attacks.
Not bad, support for `Mermaid` gets a thumbs up!
Let’s go check it out!
Both the blog and the articles are great. What does the admin panel look like? I’m curious to take a look.
This blog is really technical—nice!
Something like this.
It’s pretty minimalistic—if you add some simple custom styles, like the background color for the logo, it’d be even better.
That’s amazing—developing a new type!
Having a backend management system really makes things a lot more convenient.
Will it be open-sourced on GitHub?
It is, but you’ll need to make some tweaks yourself.
