3=1 codex 20x carpooling, 1628 per month, 4 people sharing, 407 per person. I also bought it through a channel—see below for details.
Provide an antidetect browser and an API key. You can use the Codex desktop app (I can help set it up if you don’t know how).
Buy on July 1
Bumping this for you.
This isn’t as good as just buying a GPT Pro 20x account—it’s only a little over 1,000 a month. Ideally, don’t buy Codex directly; at worst, go with a relay service—it might even be cheaper than this.
It’s just a separate account, the one I normally use.
I support this.
Then your channel is too expensive. There are cheaper ones.
Take a look
Couldn’t find another channel - -、
Isn’t there a 20X for 200 yuan now?
It’s meant for long-term, stable use.
In this case, is the plan’s quota shared? If one person uses a lot, does that mean there’s less available for everyone else?
Definitely. There’s no way to impose limits when exposing the account directly; one person could go wild and use it all up, leaving everyone else helplessly watching. So it’s better to route through an API intermediary, where some restrictions can be put in place.
It’s probably safer to carpool with someone you know—there’s a bit too much risk when neither of you knows the other.
I only need the web version of Pro—can I join?
Sure, everyone can share it, but the few of us basically won’t use the web version—we’re too lazy.
I’ll be driving on July 1. First, I’ll see whether I can drive myself. If I can, we’ll go with $200 total, or $50 per person. If I can’t, we’ll have to find another source and pay more :xhj30:
I feel like using sub2api might be better. We can just set a usage limit for each person.
Yesterday, all the low-price channels started getting wiped out~ I lost two Philippines-region Pro20Xs yesterday.
I’ve organized a shared-access setup before: five people total—one uses the web version of a fingerprint browser, while the other four access the account through sub2api and are given admin privileges. Since everyone paid for it, anyone who can’t see the account is assumed to be using a relay service. The four people then split the quota equally. You’ll have to calculate the price yourself based on the cost of creating the account.
