Another free API is here, supporting GLM-5.2 and 20,000+ other models
Another Free API
Featherless.ai.
100,000 credits upon registration.
Google sign-in.
No credit card.
No phone number.
That’s it—three steps. I tried it and got a key in 30 seconds.
22,267 Models
Yes, more than 22,000.
I clicked “Get Model List” and a green box popped up.
I counted them. The models listed on the page include:
GLM-5.2
Qwen3-9B
DeepSeek-V4-Flash
MiniMax-M3
Ornith-1.0-9B
VibeThinker-3B
Qwen3.6-27B-A3B
DeepSeek-V4-Pro
These are the ones currently at the top. There are more than 20,000 below them—browse through them yourself.
Authentication Method
ANTHROPIC_AUTH_TOKEN.
It uses Anthropic’s format for authentication, but the models actually come from Featherless’s own model pool.
Enter this token and call /v1/messages directly.
Claude Code users, take note:
export ANTHROPIC_BASE_URL=https://api.featherless.ai/v1
export ANTHROPIC_API_KEY=your-key
Just change the base URL. Replace the model name with the ID used by Featherless.
API key management is in the left sidebar, under “API Keys.”
What to Watch Out For
100,000 tokens looks like a lot.
It’s quick to use.
I tried a few models. GLM-5.2 and DeepSeek-V4-Flash were decent. Response speeds were about the same as calling Zhipu / DeepSeek directly from China.
But Qwen3-9B is slow sometimes. The free quota may be queued.
The trial is valid until July 4. Grab as much as you can during the three-day trial.
After it expires, Feather Lite will still be available, but it will use the standard free tier, with a much smaller quota.
So, hurry.
Check out featherless.ai
Sure, thanks, bro.
Supporting this free giveaway post—thanks for your hard work, OP.
To be honest, 10 million tokens doesn’t seem like that much to me.
Thanks for sharing!
100,000 GLM 5.2 = 0.44$ :ac54:
The more accounts you have, the more you can let your imagination run wild.
Thanks for sharing — one conversation just finished off 2001 :ac01:
:xhj005:
So many models
100,000 tokens? One “hello” and they’re gone.
So there are more than 20,000 models worldwide?
Even 100,000 tokens aren’t enough to answer a single question.
This is no different — you can use 90MB a day for just 5.5.
thanks
此话题已在最后回复的 7 天后被自动关闭。不再允许新回复。
