Found a free overseas SMS verification service—tested to work, messages received within 15 seconds (tested on the 22nd: 100% success rate with Chile, high success rate with Brazil, Argentina, UK, etc.; feel free to test other countries and share your results in the comments)
I found a free TG verification code bot. You get 30 points every day just for checking in, and getting a number costs around a dozen points (Tested on the 22nd: 100% success rate for Chile; Brazil, Argentina, and the UK also have pretty high success rates. For other countries, you can test and leave feedback in the comments for everyone.)
AFF https://t.me/lllIllIlIIlIlIlllIlllIlIlIlIIbot?start=PUVKF6RPQ2
Just verified it myself, it works
If you don’t know what to click, check here, this shows where:
Already done, thanks for sharing.
Is it completely free, or do you have to refer people to join?
Completely free, you just need to sign in yourself.
Thanks for sharing
6 ah
Let me give you a thumbs-up first.
No TG, so I’m just checking things out.
Thanks, I’ll give it a try.
Thanks for sharing, I’ll give it a try right away.
Thanks for sharing (is there one that works for China?)
Can you connect to ChatGPT’s authentication?
I just connected the Codex code.
Seems like there is. Take a look, but usually they just connect to foreign ones, right? :xhj001:
Thanks for sharing, I’ll try it right away.
Try it
Thanks for sharing! I’ll try it right away.
Thank you, kind person.
Thank you for sharing, I really need this.
So impressive! Let me give it a try myself.
