The leading phone manufacturer has pulled out
I’ve tried sending money several times, but it hasn’t been accepted. Looks like they’ve disappeared. Please quickly check whether the data can be transferred to a new server before the VPS expires on September 28.
The one that disappeared was called xinyun, and it was run by someone I knew before.
Forum rules: Provide specific details and the manufacturer’s name.
hyw?
Is the vendor name required?
Right, otherwise it would be hard to tell them apart. You can cover part of it.
What does “遮挡” refer to?
Can you provide both the old and new versions together?
For the former vendor, if it’s really inconvenient, you can obscure it with something like abc**.
Posted.
Did this person also set up a relay server?
Me?
No, no, no—is this the one that ran off? Is it the new cloud?
It wasn’t turned on
It may not be the same person, but someone with the same name ran a relay server and disappeared a while ago.
How much balance is left in the account?
:xhj005:
It’s fine if they don’t charge anything—it’s better than taking the money and disappearing.
Which one is this?
