六六云 666clouds London, UK VPS Review
Brief review: China Unicom had an average latency of about 164 ms in this test, better than China Telecom and China Mobile, but packet loss was detected on all three networks. Download speed was about 673 Mbps and upload speed about 434 Mbps. The 1 vCPU and less than 1 GB of memory are more suitable for lightweight services. Its strengths are that multiple UK streaming and AI services were detected as available. Its drawbacks are limited memory headroom, limited random-write performance, and an IP cleanliness score of 66%, with disagreements among blacklist and risk databases. Suitability should be judged according to the specific intended use.
Return Routes
| Carrier | Route identified in this test | Main path characteristics |
| China Telecom | China Telecom 163 (AS4134) | Connected to the China Telecom backbone via GTT and Amsterdam |
| China Unicom | China Unicom 4837 | Connected to China Unicom via GTT and Frankfurt; the sample route passed through Beijing |
| China Mobile | CMI (AS58453) | The Beijing sample detoured through Los Angeles; the Shanghai and Guangzhou samples connected to CMI via Arelion |
Among the nine return-route samples, several received no response from the destination. The above summarizes only the paths displayed. China Unicom had relatively low latency, while China Mobile showed significant differences among destination routes.
Nationwide Three-Carrier Results (Latency and Packet Loss)
There were 34 provincial-level nodes for each carrier, 102 in total, and latency was recorded for all of them. The average latency in the table is the arithmetic mean of the average latency at each node. The range runs from the minimum to the maximum of those node averages; packet loss is aggregated with equal weighting for each node.
| Carrier | Average latency | Latency range | Average packet loss | Node packet-loss range |
| China Telecom | 256.1 ms | 230.0–305.3 ms | 14.71% | 0–66.67% |
| China Unicom | 163.6 ms | 141.0–244.0 ms | 5.88% | 0–33.33% |
| China Mobile | 239.2 ms | 167.0–307.0 ms | 9.80% | 0–66.67% |
In this round, China Unicom performed relatively well in both latency and packet loss, while China Telecom had the most noticeable packet loss. Short-term probes may be affected by factors such as destination rate limiting and probing methods, so continued retesting is needed to assess service stability.
IP Quality
- Located in London, UK, with network ownership attributed to GTT (AS3257); the probe marked it as residential broadband and native.
- IPinfo and other databases identified it as an ISP in both the type and company-type fields. This can serve as a reference for identifying a “dual-ISP attribute,” but the available data cannot prove actual residential-broadband access or dual-carrier redundancy.
- The probe gave it an overall cleanliness score of 66%; of 110 valid DNSBL queries, 4 were flagged.
- Scamalytics assigned a risk score of 11 and labeled it low risk, but also gave it Server and Tor flags. Other databases reached different conclusions, so there is disagreement over the IP’s reputation.
It has advantages for UK-region identification, but this alone should not be taken to mean that it is suitable for email sending or all risk-sensitive services.
Streaming Unblocking
Of the 18 services tested, 17 were available. The results are as follows.
| Service | Detection result |
| YouTube Premium, TikTok, Paramount+, BBC iPlayer, DAZN | Available, region set to the UK |
| Netflix | Available, region set to the US |
| Disney+, Spotify, Prime Video, Max, Hulu, Apple TV+, Abema | Detected as available; region not provided |
| ChatGPT, Claude | Detected as available, region set to the UK |
| Microsoft Copilot | Detected as available; region not provided |
| Gemini | Blocked |
| Available, marked as DNS-unblocked |
The results come from API or media-source probing and cannot replace verification through actual account login, playback, subscription, and long-term availability testing. The Netflix region differs from the basic geolocation and is recorded separately according to the results of this test.
I/O Performance
| Key metric | Result in this test |
| Sequential read/write | 315.4/156.0 MiB/s |
| 4K random read/write | Approximately 298,900/3,476 IOPS |
| fsync P99 | 2.779 ms |
| Total/available disk space | 14.35/10.17 GiB |
The random read and write results differed considerably. Random-write performance and capacity are limitations that require attention. The report lacks verification under sustained load and of cache effects, so a single random-read result should not be used to infer physical-disk performance.
Overselling
This machine uses KVM, with 1 logical core and a processor identified as a Xeon Gold 6230. The CPU steal rate was 0.0% in this test, and the current cgroup showed no CPU, memory hard limit, or I/O limit. SHA-256 was approximately 273.9 MiB/s and gzip approximately 175.7 MiB/s; these are results from this brief test.
Memory ballooning was enabled and KSM was disabled. Total memory was 955 MB, with 329 MB available; 85 MB of Swap was in use. Combined with the random-write result of 3,476 IOPS, this test found no clear evidence of CPU contention. However, the balloon configuration and single CPU and I/O test results are insufficient to determine whether overselling is present; continued observation at different times is required.
Notes
- The test took place from 21:15 to 21:16 on November 5, 2026 (Beijing Time). The conclusions apply only to this sample.
- The regional and unblocking results from this test may be used as a reference for lightweight UK-based services. For access from mainland China, the three-carrier packet loss should be retested first; memory-intensive applications require a larger configuration.
- Measured download speed was 673.1 Mbps and upload speed was 434.4 Mbps. These figures do not represent guaranteed bandwidth under the plan. Plan pricing, traffic allowances, and renewal rules were not provided in the JSON.
- The network module gave conflicting NAT results: one check reported no NAT, while the UDP probe reported symmetric NAT. Related inbound or UDP services require separate verification.
Probe test: GSNode One-Click Cleanliness Review Script 3.0 Era UI Beautified Edition
