Use cases!!!:
Personal websites, blogs, test environments, and various lightweight Docker applications. The specifications are modest and cannot run large services; the free policy may change at any time, so use it while you can.
Sharing a free resource: Cloady(cloady.com). Register with an email address to claim the $0 free tier.
Specs: 0.5 vCPU / 1 GB RAM / 1 GB storage (when selecting the plan, you can adjust it; as long as it remains free, some options can go up to 3 GB), with the Tokyo jpn1 region recommended.
It is not a traditional VPS but a container platform with no SSH. Docker applications are deployed by uploading docker-compose files, and the platform automatically assigns a *.cloady.io HTTPS domain for access. In my tests, direct download speeds were around 90 Mbps, and deployment worked normally.
Getting started:
- Register with your email address at cloady.com;
- Create a workspace, select Tokyo jpn1 as the region, and choose the free tier when creating a new application;
- Upload a docker-compose file to deploy (official images and self-developed projects are both supported). I chose WordPress directly; it can be installed without configuring a database, but it’s best to use a lightweight theme. More complex themes can run, but may sometimes cause delays.
- Once deployment is complete, access the service using the assigned domain.
- Here is the interface from when I deployed it. I might use it for a small navigation page or testing later, but don’t put anything important on it!!
If you find this useful, please like or tip!
