leaflow creates a VPS
You can very conveniently use leaflow to create a VPS. Unlike clawcloud, which has port restrictions, there are currently no restrictions on TCP ports, so you can create multiple instances, offering high playability.
Creating a VPS with leaflow is very simple; you can directly use the official website’s maintenance assistant, which is the built‑in Debian image. If you prefer, you can also use the Ubuntu image provided by the VCVC community: Package ubuntu · GitHub. Unlike the official one, this requires you to manually set two environment variables
SSH_USER=ubuntu
SSH_PASSWORD=‘ubuntu!23’
Create a 4C4G VPS; the monthly cost is roughly 90 CNY. You can first use a high‑spec server to set up a compilation service, then downgrade to 2C1G, which costs about 25 CNY per month, which should be enough with daily sign‑ins.
Create a load‑balancing service, map the SSH port 22 outward, and you’ll have a VPS. Using the system‑assigned
The cost is too high to play, only suitable for practice.
90 per month, the price is a bit high! When will this sign‑in be enough for a month?
Not very suitable for a lazy person like me
So strong, so amazing!
A bit expensive
Impressive, high specs
The cost is a bit high.
Thanks for sharing, I’m done messing around.
Signed in today for 0.14 yuan
I got 0.69, but several times it was over 1 yuan.
1c1g cheap
The configuration is a bit low and cheap, the minimum can be just a few yuan more.
The cost is too high, setting up a node just for fun is possible, containers are just for practice, Lunes Host and Waifly stopped allowing full nodes after only a few days.
Not bad, study a bit
The main thing about this container is that the monthly sign‑in quota has no guaranteed minimum.
The cost is too high; it will be very hard.
I can’t connect using that maintenance assistant I set up,
Check whether the maintenance assistant started successfully; it may have mounted another app’s storage, which could cause an error.
It’s a hassle, but as long as the sign‑in can be maintained, that’s fine.
