晚上运气不错,新开到了个az100。前段时间听说az学生订阅内容新增了两个机型,于是折腾了一下,开了台arm机器,依旧使用论坛佬的一键测试脚本。供各位大佬参考。
# Yet-Another-Bench-Script #
# v2024-06-09 #
# https://github.com/masonr/yet-another-bench-script #
Wed Jul 31 13:03:14 UTC 2024
ARM compatibility is considered *experimental*
Basic System Information:
Uptime : 0 days, 3 hours, 3 minutes
Processor : Neoverse-N1
BIOS Ampere(R) Altra(R) Processor None CPU @ 3.0GHz
CPU cores : 2 @ ??? MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 981.4 MiB
Swap : 1.9 GiB
Disk : 62.8 GiB
Distro : Debian GNU/Linux 12 (bookworm)
Kernel : 6.1.0-23-cloud-arm64
VM Type : MICROSOFT
IPv4/IPv6 : ✔ Online / ❌ Offline
IPv4 Network Information:
ISP : Microsoft
ASN : AS8075 Microsoft Corporation
Host : Microsoft Azure Cloud (uksouth)
Country : United Kingdom
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
Read | 7.54 MB/s (1.8k) | 46.27 MB/s (723)
Write | 7.57 MB/s (1.8k) | 47.65 MB/s (744)
Total | 15.12 MB/s (3.7k) | 93.92 MB/s (1.4k)
Read | 44.90 MB/s (87) | 44.61 MB/s (43)
Write | 48.74 MB/s (95) | 49.77 MB/s (48)
Total | 93.64 MB/s (182) | 94.38 MB/s (91)
cue elevator music
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 856
Multi Core | 1637
Full Test | https://browser.geekbench.com/v5/cpu/22731691
YABS completed in 3 min 44 sec
</e></CODE> <e>[/tab]</e></TAB> <TAB name="Geekbench5"><s>[tab="Geekbench5"]</s> <CODE><s>
当前时间:2024-07-31 13:09:24 UTC
净测试时长:2分15秒
Geekbench 5 测试结果
系统信息
Operating System Debian GNU/Linux 12 (bookworm)
Kernel Linux 6.1.0-23-cloud-arm64 aarch64
Model Microsoft Corporation Virtual Machine
Motherboard Microsoft Corporation Virtual Machine
处理器信息
Name ARM ARMv8
Topology 1 Processor, 1 Core, 2 Threads
Identifier ARM implementer 65 architecture 8 variant 3 part 3340 revision 1
Base Frequency 0.00 Hz
内存信息
Size 981 MB
单核测试分数:854
多核测试分数:1623
详细结果链接:https://browser.geekbench.com/v5/cpu/22731698
可供参考链接:https://browser.geekbench.com/search?k=v5_cpu&q=ARM%20ARMv8
个人保存链接:https://browser.geekbench.com/v5/cpu/22731698/claim?key=495688
</e></CODE> <e>[/tab]</e></TAB> <TAB name="融合怪"><s>[tab="融合怪"]</s> <CODE><s>
VPS融合怪版本:2024.07.26
Shell项目地址:GitHub - spiritLHLS/ecs: VPS 融合怪服务器测评项目 更推荐使用无环境依赖的Go版本 VPS Fusion Monster Server Test Script – More recommended to use the Go version with no environment dependencies: https://github.com/oneclickvirt/ecs · GitHub
Go项目地址:GitHub - oneclickvirt/ecs: VPS Fusion Monster Server Test GO Version Aiming to be the most comprehensive server testing project, implemented in Go with zero environment dependencies. VPS融合怪服务器测评项目 GO版本 尽量成为最全能的服务器测评项目,使用 Go 实现,无需任何环境依赖。 · GitHub
CPU 型号 : Neoverse-N1 BIOS Ampere(R) Altra(R) Processor None CPU @ 3.0GHz
CPU 核心数 : 2
CPU 缓存 : L1: 128.00 KB / L2: 2.00 MB / L3: 32.00 MB
AES-NI指令集 :
Enabled
VM-x/AMD-V支持 :
Disabled
内存 : 194.48 MiB / 981.45 MiB
Swap : 133.35 MiB / 1.95 GiB
硬盘空间 : 3.61 GiB / 62.70 GiB
启动盘路径 : /dev/sda1
系统在线时间 : 0 days, 3 hour 10 min
负载 : 0.52, 0.61, 0.32
系统 : Debian GNU/Linux 12 (bookworm) (aarch64)
架构 : aarch64 (64 Bit)
内核 : 6.1.0-23-cloud-arm64
TCP加速方式 : bbr
虚拟化架构 : Microsoft Hyper-V
NAT类型 : Full Cone
IPV4 ASN : AS8075 Microsoft Corporation
IPV4 位置 : London / England / GB
1 线程测试(单核)得分: 1/1
1 线程测试(单核)得分: 3405 Scores
2 线程测试(多核)得分: 1/1
2 线程测试(多核)得分: 6635 Scores
单线程读测试: 1/1
单线程读测试: 28688.10 MB/s
单线程写测试: 1/1
单线程写测试: 14596.00 MB/s
测试操作 写速度 读速度
100MB-4K Block ->
100MB-4K Block 15.0 MB/s (3673 IOPS, 6.97s) ->
100MB-4K Block 15.0 MB/s (3673 IOPS, 6.97s) 16.3 MB/s (3991 IOPS, 6.41s)
1GB-1M Block ->
1GB-1M Block 93.8 MB/s (89 IOPS, 11.18s) ->
1GB-1M Block 93.8 MB/s (89 IOPS, 11.18s) 96.3 MB/s (91 IOPS, 10.89s)
Running fio test…
Preparing system for disk tests…
Generating fio test file…
Running fio random mixed R+W disk test with 4k block size…
Running fio random mixed R+W disk test with 64k block size…
Running fio random mixed R+W disk test with 512k block size…
Running fio random mixed R+W disk test with 1m block size…
Read | 7.55 MB/s (1.8k) | 46.46 MB/s (726)
Write | 7.58 MB/s (1.8k) | 47.84 MB/s (747)
Total | 15.14 MB/s (3.7k) | 94.31 MB/s (1.4k)
Read | 45.08 MB/s (88) | 44.53 MB/s (43)
Write | 48.94 MB/s (95) | 49.68 MB/s (48)
Total | 94.03 MB/s (183) | 94.21 MB/s (91)
[IPV4]
您的出口IP完整解锁Netflix,支持非自制剧的观看
NF所识别的IP地域信息:英国
[IPV6]
您的网络可能没有正常配置IPv6,或者没有IPv6网络接入
[IPV4]
连接方式: Youtube Video Server
视频缓存节点地域: 爱尔兰 都柏林 (DUB16S03)
[IPV6]
Youtube在您的出口IP所在的国家不提供服务
[IPV4]
当前出口所在地区解锁DisneyPlus
区域:GB 区
[IPV6]
DisneyPlus在您的出口IP所在的国家不提供服务
以下为IPV4网络测试,若无IPV4网络则无输出
Dazn: Yes (Region: GB)
Disney+: No (IP Banned By Disney+ 1)
Netflix: Yes (Region: GB)
YouTube Premium: Yes (Region: GB)
Amazon Prime Video: Yes (Region: GB)
TVBAnywhere+: Yes
Spotify Registration: No
Instagram Licensed Audio: No
OneTrust Region: GB [England]
iQyi Oversea Region: GB
Bing Region: GB
YouTube CDN: Dublin
Netflix Preferred CDN: [Telxius Cable Argentina S.A.] in [Fortaleza]
ChatGPT: Yes
Google Gemini: No
Wikipedia Editability: No
Steam Currency: GBP
—Forum—
Reddit: No
以下为IPV6网络测试,若无IPV6网络则无输出
Tiktok Region: 【GB】
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
IPV4:
安全得分:
声誉(越高越好): 0 [2]
信任得分(越高越好): 1 [8]
VPN得分(越低越好): 96 [8]
代理得分(越低越好): 100 [8]
社区投票-无害: 0 [2]
社区投票-恶意: 0 [2]
威胁得分(越低越好): 100 [8]
欺诈得分(越低越好): 20 [1]
滥用得分(越低越好): 0 [3]
ASN滥用得分(越低越好): 0.0001 (Very Low) [A]
公司滥用得分(越低越好): 0.0002 (Very Low) [A]
威胁级别: low [9 B]
黑名单记录统计:(有多少黑名单网站有记录):
安全信息:
使用类型: hosting [0 7 9] business [8 A] unknown [C] DataCenter/WebHosting/Transit [3]
公司类型: hosting [0 7] business [A]
是否云提供商: Yes [7 D]
是否数据中心: Yes [0 1 5 6 A] No [8 C]
是否移动设备: No [5 A C]
是否代理: No [0 1 4 5 6 7 8 9 A B C D]
是否VPN: Yes [A] No [0 1 6 7 C D]
是否Tor: No [0 1 3 6 7 8 A B C D]
是否Tor出口: No [1 7 D]
是否网络爬虫: No [9 A B]
是否匿名: No [1 6 7 8 D]
是否攻击者: No [7 8 D]
是否滥用者: No [7 8 A C D]
是否威胁: No [7 8 C D]
是否中继: No [0 7 8 C D]
是否Bogon: No [7 8 A C D]
DNS-黑名单: 310(Total_Check) 0(Clean) 4(Blacklisted) 5(Other)
Google搜索可行性:YES
LocalPort ✘
QQ ✘
163 ✘
Sohu ✘
Yandex ✘
Gmail ✘
Outlook ✘ ✘
Office365 ✘ ✘
Yahoo ✘
MailCOM ✘ ✘ ✘ ✘ ✘ ✘
MailRU ✘
AOL ✘
GMX ✘ ✘
Sina ✘ ✘
广州电信 58.60.188.222 检测不到回程路由节点的IP地址
成都电信 61.139.2.69 检测不到回程路由节点的IP地址
成都联通 119.6.6.6 联通4837 [普通线路]
准确线路自行查看详细路由,本测试结果仅作参考
广州电信 58.60.188.222
151.66 ms AS8075 英国, 伦敦, microsoft.com
153.04 ms AS8075 法国, 普罗旺斯-阿尔卑斯-蓝色海岸大区, 马赛, microsoft.com
155.13 ms AS8075 新加坡, microsoft.com
151.19 ms AS8075 新加坡, microsoft.com
201.92 ms AS4134 中国, 广东, 广州, chinatelecom.com.cn, 电信
201.42 ms AS4134 中国, 广东, 深圳, chinatelecom.com.cn, 电信
广州联通 210.21.196.6
150.21 ms AS8075 英国, 伦敦, microsoft.com
151.58 ms AS8075 法国, 法兰西岛大区, 巴黎, microsoft.com
151.54 ms AS8075 法国, 普罗旺斯-阿尔卑斯-蓝色海岸大区, 马赛, microsoft.com
153.28 ms AS8075 新加坡, microsoft.com
149.88 ms AS8075 新加坡, microsoft.com
150.50 ms AS4837 新加坡, chinaunicom.com, 联通
195.35 ms AS4837 中国, 广东, 广州, chinaunicom.com, 联通
197.99 ms AS4837 中国, 广东, 广州, chinaunicom.com, 联通
186.59 ms AS4837 中国, 广东, 广州, chinaunicom.com, 联通
188.35 ms AS17816 中国, 广东, 深圳, chinaunicom.com, 联通
192.13 ms AS17623 中国, 广东, 深圳, chinaunicom.com, 联通
195.39 ms AS17623 中国, 广东, 深圳, chinaunicom.com, 联通
广州移动 120.196.165.24
151.71 ms AS8075 英国, 伦敦, microsoft.com
277.01 ms AS8075 英国, 伦敦, microsoft.com
152.04 ms AS8075 法国, 法兰西岛大区, 巴黎, microsoft.com
151.64 ms AS8075 法国, 普罗旺斯-阿尔卑斯-蓝色海岸大区, 马赛, microsoft.com
154.50 ms AS8075 新加坡, microsoft.com
149.46 ms AS8075 新加坡, microsoft.com
152.03 ms AS58453 新加坡, chinamobile.com, 移动
185.51 ms AS58453 中国, 香港, chinamobile.com, 移动
192.15 ms AS58453 中国, 广东, 广州, chinamobile.com, 移动
191.11 ms AS9808 中国, 广东, 广州, chinamobile.com, 移动
191.70 ms AS9808 中国, 广东, 广州, chinamobile.com, 移动
191.10 ms AS9808 中国, 广东, 广州, chinamobile.com, 移动
192.54 ms AS9808 中国, 广东, 广州, chinamobile.com, 移动
197.23 ms AS56040 中国, 广东, 深圳, chinamobile.com, 移动
位置 上传速度 下载速度 延迟 丢包率
Speedtest.net 6013.37 Mbps 21845.15 Mbps 0.97 NULL
法兰克福 5179.73 Mbps 11845.54 Mbps 15.23 0.0%
洛杉矶 631.97 Mbps 5676.09 Mbps 135.80 0.0%
联通WuXi 1664.73 Mbps 2857.05 Mbps 216.52 0.0%
联通成都 1483.41 Mbps 1.22 Mbps 235.51 NULL
电信Zhenjiang5G 282.61 Mbps 3967.40 Mbps 219.07 NULL
该运营商.net的节点列表为空,正在替换为.cn的节点列表。。。
总共花费 : 7 分 14 秒
时间 : Wed Jul 31 13:17:13 UTC 2024
IP质量体检报告:172.167.*.*
bash <(curl -sL IP.Check.Place)
报告时间:2024-07-31 21:17:29 CST 脚本版本:v2024-07-29
一、基础信息(Maxmind 数据库)
自治系统号: AS8075
组织: MICROSOFT-CORP-MSN-AS-BLOCK
坐标: °7′11″W, 51°30′27″N
地图: https://check.place/51.5074,-0.1196,15,cn
城市: 英格兰, 伦敦, EC1N
使用地: [GB]英国, [EU]欧洲
注册地: [GB]英国
时区: Europe/London
IP类型: 原生IP
二、IP类型属性
使用类型: 机房 机房 商业 机房 机房
公司类型: 机房 机房 商业
三、风险评分
风险等级: 极低 低 中等 高 极高
SCAMALYTICS: 20|低风险
ipapi: 0.02%|极低风险
AbuseIPDB: 0|低风险
IPQS: 75|可疑IP
DB-IP: |低风险
四、风险因子
地区: [GB] [GB] [GB] [GB] [GB] [GB] [GB] [GB]
代理: 否 否 否 是 否 否 否 否
Tor: 否 否 否 否 否 否 否 否
VPN: 否 是 否 是 否 无 否 否
服务器: 是 是 是 无 否 否 是 是
滥用: 否 否 否 否 无 否 无 无
机器人: 否 否 无 否 否 无 无 无
五、流媒体及AI服务解锁检测
状态: 解锁 屏蔽 解锁 解锁 解锁 屏蔽 解锁
方式: 原生 原生 原生 原生 原生
六、邮局连通性及黑名单检测
本地25端口:阻断
IP地址黑名单数据库: 有效 439 正常 415 已标记 24 黑名单 0
今日IP检测量:478;总检测量:62276。感谢使用xy系列脚本!
报告链接:https://Report.Check.Place/IP/2UNVYRXGH.svg
改版地址 GitHub - xykt/RegionRestrictionCheck: A bash script to check the status of your IP on various geo-restricted services. · GitHub
** 测试时间: Wed Jul 31 13:18:05 UTC 2024
** 正在测试IPv4解锁情况
** 您的网络为: Microsoft Azure (172.167..)
Dazn: 原生解锁 Yes (Region: GB)
TikTok: 原生解锁 Yes (Region: GB)
Disney+: No
Netflix: 原生解锁 Yes (Region: GB)
YouTube Premium: 原生解锁 Yes (Region: GB)
Amazon Prime Video: 原生解锁 Yes (Region: GB)
TVBAnywhere+: 原生解锁 Yes
iQyi Oversea Region: 原生解锁 GB
YouTube CDN: Dublin
Netflix Preferred CDN: Associated with [Telxius Cable Argentina S.A.] in [Fortaleza]
Steam Currency: GBP
ChatGPT: 原生解锁 Yes (Region: GB)
Google Gemini: No
Bing Region: GB
Instagram Licensed Audio: ->
—Forum—
Reddit: No
===============[ Europe ]==============
Rakuten TV: Yes
SkyShowTime: No
BritBox: Yes
HBO Max: Yes
Setanta Sports: No
SonyLiv: Failed (Network Connection)
Discovery+: Yes (Region: GB)
Paramount+: Yes
Megogo TV: Failed
—GB—
HotStar: 原生解锁 Yes (Region: GB)
Sky Go: Yes
ITV Hub: Yes
Channel 4: Yes
Channel 5: No
BBC iPLAYER: Yes
Acorn TV: Yes
Shudder: Yes
—FR—
Canal+: Yes
Molotov: No
—DE—
Joyn: No
SKY DE: No
ZDF: No
—NL—
NLZIET: Failed
videoland: No
NPO Start Plus: No
—ES—
Movistar+: No
—IT—
Rai Play: Yes
—CH—
SKY CH: No
—RU—
Amediateka: Yes
当前主机不支持IPv6,跳过…
本次测试已结束,感谢使用此脚本
检测脚本当天运行次数: 15; 共计运行次数: 129134
正在测试 https://www.google.com
尝试 1: 83.888000 ms
尝试 2: 84.198000 ms
尝试 3: 84.753000 ms
尝试 4: 84.793000 ms
尝试 5: 82.536000 ms
平均时间: 84.03 ms for https://www.google.com
正在测试 https://www.facebook.com
尝试 1: 245.689000 ms
尝试 2: 84.756000 ms
尝试 3: 78.313000 ms
尝试 4: 92.124000 ms
尝试 5: 86.975000 ms
平均时间: 117.57 ms for https://www.facebook.com
正在测试 https://www.twitter.com
尝试 1: 154.593000 ms
尝试 2: 152.357000 ms
尝试 3: 152.977000 ms
尝试 4: 147.242000 ms
尝试 5: 163.798000 ms
平均时间: 154.19 ms for https://www.twitter.com
正在测试 https://www.youtube.com
尝试 1: 173.908000 ms
尝试 2: 148.575000 ms
尝试 3: 175.011000 ms
尝试 4: 209.377000 ms
尝试 5: 215.873000 ms
平均时间: 184.54 ms for https://www.youtube.com
正在测试 https://www.netflix.com
尝试 1: 415.883000 ms
尝试 2: 641.227000 ms
尝试 3: 388.889000 ms
尝试 4: 374.732000 ms
尝试 5: 381.990000 ms
平均时间: 440.54 ms for https://www.netflix.com
正在测试 https://chat.openai.com
尝试 1: 64.612000 ms
尝试 2: 67.122000 ms
尝试 3: 61.681000 ms
尝试 4: 80.274000 ms
尝试 5: 64.333000 ms
平均时间: 67.60 ms for https://chat.openai.com
正在测试 https://www.github.com
尝试 1: 60.956000 ms
尝试 2: 53.713000 ms
尝试 3: 48.844000 ms
尝试 4: 43.076000 ms
尝试 5: 50.727000 ms
平均时间: 51.46 ms for https://www.github.com
网站 平均时间(ms)
https://www.google.com 84.03 ms
https://www.facebook.com 117.57 ms
https://www.twitter.com 154.19 ms
https://www.youtube.com 184.54 ms
https://www.netflix.com 440.54 ms
https://chat.openai.com 67.60 ms
https://www.github.com 51.46 ms
Total Avg 157.13 ms
Version : v2024-04-25
Usage : bash <(curl -sL bash.icu/speedtest)
GitHub : GitHub - i-abc/Speedtest: 多功能测速脚本 | Multi-functional speedtest script · GitHub
测速节点 下载/Mbps 上传/Mbps 延迟/ms 抖动/ms
最近的测速点 8130.09 Mbps 5961.51 Mbps 1.23 ms 0.07 ms
电信 江苏苏州 3569.10 Mbps 374.59 Mbps 221.71 ms 0.10 ms
电信 江苏镇江 5G 3542.81 Mbps 207.51 Mbps 219.27 ms 1.58 ms
电信 江苏南京 5G 2998.49 Mbps 53.73 Mbps 217.85 ms 0.45 ms
联通 江苏无锡 3568.90 Mbps 354.40 Mbps 212.81 ms 0.08 ms
测速次数过多,暂时被限制,请过一段时间后再进行测试
教育网 上海 2 7.88 Mbps 26.81 Mbps 243.27 ms 0.10 ms
教育网 辽宁沈阳 0.01 Mbps 3.85 Mbps 327.73 ms 3.21 ms
教育网 江苏南京 2 17.82 Mbps 9.41 Mbps 306.27 ms 1.63 ms
系统时间:2024-07-31 13:25:06 UTC
北京时间: 2024-07-31 21:25:06 CST
电信 四川成都 8.00 Mbps 4.10 Mbps 228.20 ms 5.90 ms
电信 江苏苏州 105.20 Mbps 91.70 Mbps 216.60 ms 3.20 ms
电信 江苏镇江 5G 104.40 Mbps 26.50 Mbps 220.60 ms 4.30 ms
电信 江苏南京 5G 95.70 Mbps 7.40 Mbps 216.10 ms 3.70 ms
联通 江苏无锡 失败 失败 206.50 ms 4.80 ms
广电 重庆 失败 0.70 Mbps 295.00 ms 7.60 ms
系统时间:2024-07-31 13:34:18 UTC
北京时间: 2024-07-31 21:34:18 CST
</e></CODE> <e>[/tab]</e></TAB> <TAB name="iperf3"><s>[tab="iperf3"]</s> <CODE><s>
[ 5] 0.00-1.00 sec 136 MBytes 1.14 Gbits/sec 168 8.80 MBytes
[ 5] 1.00-2.00 sec 150 MBytes 1.26 Gbits/sec 446 6.78 MBytes
[ 5] 2.00-3.00 sec 149 MBytes 1.25 Gbits/sec 674 6.92 MBytes
[ 5] 3.00-4.00 sec 151 MBytes 1.27 Gbits/sec 0 6.72 MBytes
[ 5] 4.00-5.00 sec 155 MBytes 1.30 Gbits/sec 0 6.85 MBytes
[ 5] 5.00-6.00 sec 156 MBytes 1.31 Gbits/sec 0 6.54 MBytes
[ 5] 6.00-7.00 sec 158 MBytes 1.32 Gbits/sec 0 6.51 MBytes
[ 5] 7.00-8.00 sec 156 MBytes 1.31 Gbits/sec 0 7.15 MBytes
[ 5] 8.00-9.00 sec 158 MBytes 1.32 Gbits/sec 0 6.61 MBytes
[ 5] 9.00-10.00 sec 156 MBytes 1.31 Gbits/sec 0 6.70 MBytes
[ 5] 10.00-11.00 sec 121 MBytes 1.02 Gbits/sec 0 6.91 MBytes
[ 5] 11.00-12.00 sec 156 MBytes 1.31 Gbits/sec 0 6.88 MBytes
[ 5] 12.00-13.00 sec 156 MBytes 1.31 Gbits/sec 0 6.62 MBytes
[ 5] 13.00-14.00 sec 155 MBytes 1.30 Gbits/sec 0 7.07 MBytes
[ 5] 14.00-15.00 sec 152 MBytes 1.28 Gbits/sec 0 7.08 MBytes
[ 5] 15.00-16.00 sec 152 MBytes 1.28 Gbits/sec 0 7.12 MBytes
[ 5] 16.00-17.00 sec 141 MBytes 1.18 Gbits/sec 541 6.81 MBytes
[ 5] 17.00-18.00 sec 151 MBytes 1.27 Gbits/sec 0 7.23 MBytes
[ 5] 18.00-19.00 sec 152 MBytes 1.28 Gbits/sec 0 6.99 MBytes
[ 5] 19.00-20.00 sec 152 MBytes 1.28 Gbits/sec 0 6.98 MBytes
[ 5] 20.00-21.00 sec 152 MBytes 1.28 Gbits/sec 0 6.94 MBytes
[ 5] 21.00-22.00 sec 150 MBytes 1.26 Gbits/sec 478 6.79 MBytes
[ 5] 22.00-23.00 sec 154 MBytes 1.29 Gbits/sec 0 6.83 MBytes
[ 5] 23.00-24.00 sec 154 MBytes 1.29 Gbits/sec 0 6.80 MBytes
[ 5] 24.00-25.00 sec 155 MBytes 1.30 Gbits/sec 0 6.55 MBytes
[ 5] 25.00-26.00 sec 158 MBytes 1.32 Gbits/sec 0 6.52 MBytes
[ 5] 26.00-27.00 sec 120 MBytes 1.01 Gbits/sec 0 6.66 MBytes
[ 5] 27.00-28.00 sec 158 MBytes 1.32 Gbits/sec 0 6.65 MBytes
[ 5] 28.00-29.00 sec 158 MBytes 1.32 Gbits/sec 0 6.65 MBytes
[ 5] 29.00-29.90 sec 142 MBytes 1.33 Gbits/sec 0 6.58 MBytes
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-29.90 sec 4.41 GBytes 1.27 Gbits/sec 2307 sender
[ 5] 0.00-29.90 sec 0.00 Bytes 0.00 bits/sec receiver
iperf3 测试失败或超时
ARM 实验性质平台
ISP : Microsoft Azure
服务商 : Microsoft Azure Cloud (uksouth)
国家 : United Kingdom
地址 : London, England (ENG)
IPv4地址 : 172.167.217.26
IPv6地址 : 无 IPv6
IP 性质 : 数据中心
IP 危险性: 20/100(建议小于60分,分数越高说明 IP 可能存在滥用欺诈行为)
[H
No:1/9 Traceroute to 中国 深圳 电信 (TCP Mode, Max 30 Hop, IPv4)
NextTrace v1.3.2 2024-07-28T10:50:28Z ea2a6b5
[NextTrace API] preferred API IP - 172.67.155.192 - 191.07ms - Misaka.BER
traceroute to 59.36.216.1, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
7 104.44.32.26 AS8075 [MSFT] 英国 英格兰 伦敦 microsoft.com
150.05 ms
8 104.44.16.55 AS8075 [MSFT] 英国 英格兰 伦敦 microsoft.com
322.89 ms
9 104.44.29.167 AS8075 [MSFT] 法国 普罗旺斯-阿尔卑斯-蓝色海岸大区 马赛 microsoft.com
149.94 ms
10 *
11 104.44.28.208 AS8075 [MSFT] 新加坡 microsoft.com
150.26 ms
12 104.44.33.124 AS8075 [MSFT] 新加坡 microsoft.com
150.35 ms
13 104.44.239.146 AS8075 [MSFT] 新加坡 microsoft.com
156.17 ms
14 183.91.56.169 AS4134 [APNIC-AP] 新加坡 www.chinatelecom.com.cn 电信
151.24 ms
15 *
16 *
17 *
18 *
19 *
20 119.147.61.6 AS4134 [CHINANET-GD] 中国 广东 深圳 www.chinatelecom.com.cn
205.74 ms
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 88.01ms - Misaka.BER
traceroute to 101.226.41.65, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
7 104.44.32.28 AS8075 [MSFT] 英国 英格兰 伦敦 microsoft.com
267.50 ms
8 104.44.18.196 AS8075 [MSFT] 法国 法兰西岛大区 巴黎 microsoft.com
190.09 ms
9 104.44.18.196 AS8075 [MSFT] 法国 法兰西岛大区 巴黎 microsoft.com
153.35 ms
10 104.44.29.169 AS8075 [MSFT] 法国 普罗旺斯-阿尔卑斯-蓝色海岸大区 马赛 microsoft.com
150.29 ms
11 104.44.28.173 AS8075 [MSFT] 法国 普罗旺斯-阿尔卑斯-蓝色海岸大区 马赛 microsoft.com
149.77 ms
12 *
13 104.44.33.126 AS8075 [MSFT] 新加坡 microsoft.com
150.65 ms
14 *
15 183.91.56.169 AS4134 [APNIC-AP] 新加坡 www.chinatelecom.com.cn 电信
155.64 ms
16 *
17 *
18 202.97.71.37 AS4134 [CHINANET-BB] 中国 上海 www.chinatelecom.com.cn 电信
216.31 ms
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 135.88ms - Misaka.BER
traceroute to 220.181.53.1, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
7 *
8 104.44.16.57 AS8075 [MSFT] 英国 英格兰 伦敦 microsoft.com
246.26 ms
212.02 ms
149.98 ms
11 *
12 104.44.28.208 AS8075 [MSFT] 新加坡 microsoft.com
150.37 ms
152.52 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
No:4/9 Traceroute to 中国 广州 联通 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 104.21.40.176 - 83.72ms - Misaka.BER
traceroute to 210.21.4.130, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
7 104.44.21.109 AS8075 [MSFT] 英国 英格兰 伦敦 microsoft.com
150.62 ms
151.63 ms
9 104.44.7.50 AS8075 [MSFT] 法国 法兰西岛大区 巴黎 microsoft.com
151.77 ms
10 104.44.29.167 AS8075 [MSFT] 法国 普罗旺斯-阿尔卑斯-蓝色海岸大区 马赛 microsoft.com
151.95 ms
11 104.44.28.184 AS8075 [MSFT] 新加坡 microsoft.com
151.69 ms
12 *
13 104.44.33.128 AS8075 [MSFT] 新加坡 microsoft.com
150.02 ms
14 104.44.239.144 AS8075 [MSFT] 新加坡 microsoft.com
152.91 ms
15 219.158.38.213 AS4837 [CU169-BACKBONE] 新加坡 chinaunicom.cn 联通
151.55 ms
16 219.158.21.9 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
192.01 ms
17 219.158.103.25 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
194.42 ms
18 219.158.8.117 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
197.77 ms
19 120.80.169.118 AS17622 [APNIC-AP] 中国 广东 广州 chinaunicom.cn 联通
193.87 ms
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 85.39ms - Misaka.BER
traceroute to 112.65.95.129, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
150.21 ms
8 104.44.7.50 AS8075 [MSFT] 法国 法兰西岛大区 巴黎 microsoft.com
152.27 ms
9 104.44.29.169 AS8075 [MSFT] 法国 普罗旺斯-阿尔卑斯-蓝色海岸大区 马赛 microsoft.com
150.17 ms
152.84 ms
150.47 ms
12 104.44.33.128 AS8075 [MSFT] 新加坡 microsoft.com
151.15 ms
150.02 ms
14 219.158.38.217 AS4837 [CU169-BACKBONE] 新加坡 chinaunicom.cn 联通
149.90 ms
151.30 ms
16 219.158.3.213 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
195.59 ms
17 *
18 219.158.3.125 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
195.69 ms
19 *
20 *
21 210.22.66.178 AS17621 [APNIC-AP] 中国 上海 chinaunicom.cn 联通
220.36 ms
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 80.10ms - Misaka.BER
traceroute to 61.49.140.217, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
150.15 ms
153.66 ms
151.69 ms
10 104.44.28.163 AS8075 [MSFT] 法国 普罗旺斯-阿尔卑斯-蓝色海岸大区 马赛 microsoft.com
150.23 ms
11 *
12 *
151.55 ms
14 219.158.38.213 AS4837 [CU169-BACKBONE] 新加坡 chinaunicom.cn 联通
149.92 ms
15 219.158.3.101 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
196.04 ms
16 219.158.17.93 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
200.28 ms
17 219.158.3.13 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
191.78 ms
18 219.158.3.13 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
188.72 ms
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 61.49.140.217 AS4808 中国 北京 中国联通 联通
229.25 ms
No:7/9 Traceroute to 中国 深圳 移动 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 172.67.155.192 - 90.10ms - Misaka.BER
traceroute to 120.233.53.1, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
7 *
150.72 ms
151.45 ms
10 *
150.51 ms
12 104.44.28.184 AS8075 [MSFT] 新加坡 microsoft.com
158.68 ms
150.75 ms
14 223.119.81.113 AS58453 [CMI-INT] 新加坡 CMI-SG-PoP cmi.chinamobile.com 移动
151.91 ms
15 223.120.22.133 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com 移动
181.13 ms
16 *
17 223.120.22.202 AS58453 [CMI-INT] 中国 广东 广州 cmi.chinamobile.com
190.58 ms
18 221.183.92.205 AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
193.78 ms
19 221.183.92.205 AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
196.64 ms
20 *
21 *
22 211.136.242.170 AS56040 [CMNET] 中国 广东 广州 gd.10086.cn 移动
206.14 ms
23 211.136.242.174 AS56040 [CMNET] 中国 广东 广州 gd.10086.cn 移动
203.66 ms
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 81.54ms - Misaka.BER
traceroute to 183.194.216.129, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
7 104.44.21.97 AS8075 [MSFT] 英国 英格兰 伦敦 microsoft.com
150.37 ms
151.84 ms
151.50 ms
10 *
150.33 ms
150.48 ms
13 104.44.239.144 AS8075 [MSFT] 新加坡 microsoft.com
150.29 ms
158.35 ms
15 *
16 223.120.2.109 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com 移动
187.01 ms
17 223.120.3.182 AS58453 [CMI-INT] 中国 上海 cmi.chinamobile.com 移动
248.86 ms
18 221.183.89.69 AS9808 [CMNET] 中国 上海 chinamobileltd.com 移动
231.15 ms
19 221.183.89.10 AS9808 [CMNET] 中国 上海 chinamobileltd.com 移动
230.05 ms
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 79.86ms - Misaka.BER
traceroute to 211.136.25.153, 30 hops max, 52 bytes payload
1 *
2 *
3 *
4 *
5 *
6 *
7 *
151.43 ms
150.59 ms
10 *
151.42 ms
12 *
150.59 ms
151.29 ms
15 223.119.81.113 AS58453 [CMI-INT] 新加坡 CMI-SG-PoP cmi.chinamobile.com 移动
154.19 ms
16 *
17 *
18 221.183.55.102 AS9808 [CMNET] 中国 北京 X-I chinamobileltd.com 移动
258.96 ms
19 221.183.25.201 AS9808 [CMNET] 中国 北京 chinamobileltd.com 移动
247.94 ms
20 *
21 *
22 *
23 211.136.63.66 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
246.64 ms
24 211.136.95.226 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
246.58 ms
25 *
26 *
27 211.136.25.153 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
246.02 ms
[/tab]
[tab=“去程路由”]
[/tab]
[tab=“Ping.pe”]
[/tab]
[tab=“哪吒 ICMP”]
[/tab]
[tab=“其他”]
[/tab]
[/tabs]
