CloudBlast小测
[tabs]
[tab=“YABS”]
Yet-Another-Bench-Script
v2024-06-09
GitHub - masonr/yet-another-bench-script: YABS - a simple bash script to estimate Linux server performance using fio, iperf3, & Geekbench · GitHub
Sun Aug 18 05:07:29 UTC 2024
Basic System Information:
Uptime : 0 days, 19 hours, 18 minutes
Processor : AMD EPYC 7551P 32-Core Processor
CPU cores : 2 @ 1996.249 MHz
AES-NI : :check_mark: Enabled
VM-x/AMD-V : :check_mark: Enabled
RAM : 2.9 GiB
Swap : 0.0 KiB
Disk : 11.8 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-17-amd64
VM Type : KVM
IPv4/IPv6 : :check_mark: Online / :cross_mark: Offline
IPv4 Network Information:
ISP : Fomo Crew Fzco
ASN : AS214730 FOMO CREW FZCO
Host : Fomo Crew Fzco
Country : The Netherlands
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
Read | 29.19 MB/s (7.2k) | 472.58 MB/s (7.3k)
Write | 29.21 MB/s (7.3k) | 475.06 MB/s (7.4k)
Total | 58.41 MB/s (14.6k) | 947.65 MB/s (14.8k)
Read | 766.84 MB/s (1.4k) | 829.41 MB/s (809)
Write | 807.59 MB/s (1.5k) | 884.64 MB/s (863)
Total | 1.57 GB/s (3.0k) | 1.71 GB/s (1.6k)
cue elevator music
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 597
Multi Core | 1140
Full Test | https://browser.geekbench.com/v5/cpu/22789079
YABS completed in 4 min 0 sec
</e></CODE> <e>[/tab]</e></TAB> <TAB name="Geekbench5"><s>[tab="Geekbench5"]</s> <CODE><s>
当前时间:2024-08-18 05:14:36 UTC
净测试时长:2分52秒
Geekbench 5 测试结果
系统信息
Operating System Debian GNU/Linux 11 (bullseye)
Kernel Linux 5.10.0-17-amd64 x86_64
Model QEMU Standard PC (i440FX + PIIX, 1996)
Motherboard N/A
BIOS SeaBIOS rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
处理器信息
Name AMD EPYC 7551P
Topology 1 Processor, 2 Cores
Identifier AuthenticAMD Family 23 Model 1 Stepping 2
Base Frequency 2.00 GHz
L1 Instruction Cache 64.0 KB x 2
L1 Data Cache 64.0 KB x 2
L2 Cache 512 KB x 2
L3 Cache 16.0 MB
内存信息
Size 2.92 GB
单核测试分数:596
多核测试分数:1162
详细结果链接:https://browser.geekbench.com/v5/cpu/22789092
可供参考链接:https://browser.geekbench.com/search?k=v5_cpu&amp;q=AMD%20EPYC%207551P
个人保存链接:https://browser.geekbench.com/v5/cpu/22789092/claim?key=407465
</e></CODE> <e>[/tab]</e></TAB> <TAB name="融合怪"><s>[tab="融合怪"]</s> <CODE><s>
VPS融合怪版本:2024.08.14
Shell项目地址:GitHub - spiritLHLS/ecs: VPS 融合怪服务器测评项目 更推荐使用无环境依赖的Go版本 VPS Fusion Monster Server Test Script – More recommended to use the Go version with no environment dependencies: https://github.com/oneclickvirt/ecs · GitHub
Go项目地址:GitHub - oneclickvirt/ecs: VPS Fusion Monster Server Test GO Version Aiming to be the most comprehensive server testing project, implemented in Go with zero environment dependencies. VPS融合怪服务器测评项目 GO版本 尽量成为最全能的服务器测评项目,使用 Go 实现,无需任何环境依赖。 · GitHub
CPU 型号 : AMD EPYC 7551P 32-Core Processor
CPU 核心数 : 2
CPU 频率 : 1996.249 MHz
CPU 缓存 : L1: 256.00 KB / L2: 1.00 MB / L3: 16.00 MB
内存 : 410.73 MiB / 2.92 GiB
硬盘空间 : 1.77 GiB / 11.65 GiB
启动盘路径 : /dev/sda1
系统在线时间 : 0 days, 19 hour 25 min
负载 : 0.82, 0.80, 0.60
系统 : Debian GNU/Linux 11 (bullseye) (x86_64)
架构 : x86_64 (64 Bit)
内核 : 5.10.0-17-amd64
TCP加速方式 : cubic
虚拟化架构 : KVM
NAT类型 : Full Cone
IPV4 ASN : AS214730 FOMO CREW FZCO
IPV4 位置 : Amsterdam / North Holland / NL
1 线程测试(单核)得分: 1/1
1 线程测试(单核)得分: 1225 Scores
2 线程测试(多核)得分: 1/1
2 线程测试(多核)得分: 2475 Scores
单线程读测试: 1/1
单线程读测试: 33020.86 MB/s
单线程写测试: 1/1
单线程写测试: 13150.19 MB/s
测试操作 写速度 读速度
100MB-4K Block ->
100MB-4K Block 17.8 MB/s (4338 IOPS, 5.90s) ->
100MB-4K Block 17.8 MB/s (4338 IOPS, 5.90s) 22.3 MB/s (5438 IOPS, 4.71s)
1GB-1M Block ->
1GB-1M Block 677 MB/s (645 IOPS, 1.55s) ->
1GB-1M Block 677 MB/s (645 IOPS, 1.55s) 1.6 GB/s (1506 IOPS, 0.66s)
Running fio test…
Read | 28.50 MB/s (7.1k) | 442.67 MB/s (6.9k)
Write | 28.53 MB/s (7.1k) | 445.00 MB/s (6.9k)
Total | 57.03 MB/s (14.2k) | 887.68 MB/s (13.8k)
Read | 756.34 MB/s (1.4k) | 863.64 MB/s (843)
Write | 796.52 MB/s (1.5k) | 921.16 MB/s (899)
Total | 1.55 GB/s (3.0k) | 1.78 GB/s (1.7k)
[IPV4]
您的出口IP完整解锁Netflix,支持非自制剧的观看
NF所识别的IP地域信息:荷兰
[IPV6]
您的网络可能没有正常配置IPv6,或者没有IPv6网络接入
[IPV4]
连接方式: Youtube Video Server
视频缓存节点地域: 荷兰阿姆斯特丹(AMS15S45)
[IPV6]
Youtube在您的出口IP所在的国家不提供服务
[IPV4]
当前出口所在地区解锁DisneyPlus
区域:NL 区
[IPV6]
DisneyPlus在您的出口IP所在的国家不提供服务
以下为IPV4网络测试,若无IPV4网络则无输出
Dazn: Yes (Region: NL)
Disney+: Yes (Region: NL)
Netflix: Yes (Region: NL)
YouTube Premium: Yes (Region: AE)
Amazon Prime Video: Yes (Region: NL)
TVBAnywhere+: Yes
Spotify Registration: No
Instagram Licensed Audio: No
OneTrust Region: NL [North Holland]
iQyi Oversea Region: US
Bing Region: NL
YouTube CDN: Amsterdam
Netflix Preferred CDN: Stockholm
ChatGPT: Yes
Google Gemini: Yes (Region: ARE)
Wikipedia Editability: Yes
Steam Currency: EUR
—Forum—
Reddit: Yes
以下为IPV6网络测试,若无IPV6网络则无输出
Tiktok Region: Failed
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
IPV4:
安全得分:
声誉(越高越好): 0 [2]
信任得分(越高越好): 5 [8]
VPN得分(越低越好): 89 [8]
代理得分(越低越好): 100 [8]
社区投票-无害: 0 [2]
社区投票-恶意: 0 [2]
威胁得分(越低越好): 97 [8]
欺诈得分(越低越好): 0 [1 E]
滥用得分(越低越好): 0 [3]
ASN滥用得分(越低越好): 0.002 (Low) [A]
公司滥用得分(越低越好): 0.001 (Low) [A]
威胁级别: low [B]
黑名单记录统计:(有多少黑名单网站有记录):
安全信息:
使用类型: hosting [0 7] unknown [C] business [8 A] DataCenter/WebHosting/Transit [3]
公司类型: hosting [0 7] isp [A]
是否云提供商: Yes [7 D]
是否数据中心: No [5 6 8 C] Yes [0 1 A]
是否移动设备: Yes [E] No [5 A C]
是否代理: No [0 1 4 5 6 7 8 A B C D E]
是否VPN: No [0 1 6 7 A C D E]
是否TorExit: No [1 7 D]
是否Tor出口: No [1 7 D]
是否网络爬虫: No [A B E]
是否匿名: No [1 6 7 8 D]
是否攻击者: No [7 8 D]
是否滥用者: No [7 8 A C D E]
是否威胁: No [7 8 C D]
是否中继: No [0 7 8 C D]
是否Bogon: No [7 8 A C D]
是否机器人: No [E]
DNS-黑名单: 312(Total_Check) 0(Clean) 6(Blacklisted) 22(Other)
Google搜索可行性:YES
QQ :check_mark: :check_mark: :check_mark: ✘ :check_mark: ✘
163 :check_mark: :check_mark: :check_mark: ✘ :check_mark: ✘
Sohu :check_mark: :check_mark: :check_mark: ✘ :check_mark: ✘
Yandex :check_mark: :check_mark: :check_mark: ✘ :check_mark: ✘
Outlook :check_mark: ✘ :check_mark: ✘ :check_mark: ✘
Office365 :check_mark: ✘ :check_mark: ✘ :check_mark: ✘
MailCOM :check_mark: :check_mark: :check_mark: ✘ :check_mark: ✘
MailRU :check_mark: :check_mark: ✘ ✘ :check_mark: ✘
GMX :check_mark: ✘ :check_mark: ✘ :check_mark: ✘
Sina :check_mark: ✘ :check_mark: ✘ :check_mark: ✘
成都电信 61.139.2.69 电信163 [普通线路]
成都联通 119.6.6.6 联通4837 [普通线路]
成都移动 211.137.96.205 移动CMI [普通线路] 移动CMIN2 [精品线路]
准确线路自行查看详细路由,本测试结果仅作参考
广州电信 58.60.188.222
0.30 ms AS214730 罗马尼亚 布加勒斯特
0.29 ms AS212477 荷兰 北荷兰省 阿姆斯特丹 royalehosting.net
0.48 ms AS212477 英国 英格兰 伦敦 royalehosting.net
0.39 ms AS1299 [TELIANET] 荷兰 arelion.com
0.70 ms AS1299 [ARELION-NET] 瑞典 斯德哥尔摩省 斯德哥尔摩 arelion.com
1.51 ms AS1299 [ARELION-NET] 瑞典 斯德哥尔摩省 斯德哥尔摩 arelion.com
257.95 ms AS4134 [CHINANET-BB] 中国 广东 广州 www.chinatelecom.com.cn 电信
261.26 ms AS4134 [CHINANET-BB] 中国 广东 广州 www.chinatelecom.com.cn
263.49 ms AS4134 中国 广东 深圳 福田区 www.chinatelecom.com.cn 电信
广州联通 210.21.196.6
0.29 ms AS214730 罗马尼亚 布加勒斯特
0.47 ms AS212477 英国 英格兰 伦敦 royalehosting.net
0.33 ms AS1299 [TELIANET] 荷兰 arelion.com
1.74 ms AS1299 [ARELION-NET] 瑞典 斯德哥尔摩省 斯德哥尔摩 arelion.com
7.79 ms AS1299 [ARELION-NET] 德国 黑森州 美因河畔法兰克福 arelion.com
11.38 ms AS1299 [ARELION-NET] 德国 黑森州 美因河畔法兰克福 arelion.com
179.55 ms AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
173.76 ms AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn
175.51 ms AS17816 [UNICOM-GD] 中国 广东 深圳 chinaunicom.cn 联通
182.71 ms AS17623 [APNIC-AP] 中国 广东 深圳 chinaunicom.cn 联通
171.85 ms AS17623 [APNIC-AP] 中国 广东 深圳 宝安区 chinaunicom.cn 联通
广州移动 120.196.165.24
0.24 ms AS214730 罗马尼亚 布加勒斯特
0.29 ms AS212477 英国 英格兰 伦敦 royalehosting.net
3.92 ms AS212477 英国 英格兰 伦敦 royalehosting.net
0.36 ms AS1299 [TELIANET] 荷兰 arelion.com
9.03 ms AS1299 [ARELION-NET] 英国 英格兰 伦敦 arelion.com
7.16 ms AS1299 [ARELION-NET] 英国 英格兰 伦敦 arelion.com
9.49 ms AS1299 [ARELION-NET] 英国 英格兰 伦敦 arelion.com
8.08 ms AS58453 [CMI-INT] 英国 英格兰 伦敦 cmi.chinamobile.com
204.87 ms AS58453 [CMI-INT] 中国 广东 广州 cmi.chinamobile.com
209.85 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
211.28 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
220.31 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
216.08 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
215.98 ms AS56040 [APNIC-AP] 中国 广东 深圳 gd.10086.cn 移动
位置 上传速度 下载速度 延迟 丢包率
该运营商.net的节点列表为空,正在替换为.cn的节点列表。。。--------------------自动更新测速节点列表–本脚本原创--------------------
位置 上传速度 下载速度 延迟 丢包率
总共花费 : 4 分 52 秒
时间 : Sun Aug 18 05:19:47 UTC 2024
短链:
http://hpaste.spiritlhl.net/u/GkWla0.txt
                   IP质量体检报告:89.34.*.*
                bash &lt;(curl -sL IP.Check.Place)
    报告时间:2024-08-18 13:20:41 CST  脚本版本:v2024-07-29
一、基础信息(Maxmind 数据库)
自治系统号: AS214730
组织: Fomo Crew Fzco
坐标: 4°53′51″E, 52°22′33″N
地图: https://check.place/52.3759,4.8975,15,cn
城市: 北荷兰省, 阿姆斯特丹, 1012
使用地: [NL]荷兰, [EU]欧洲
注册地: [RO]罗马尼亚
时区: Europe/Amsterdam
IP类型: 广播IP
二、IP类型属性
使用类型: 机房 机房 商业 机房 机房
公司类型: 机房 机房 商业
三、风险评分
风险等级: 极低 低 中等 高 极高
SCAMALYTICS: 0|低风险
ipapi: 0.10%|低风险
AbuseIPDB: 0|低风险
IPQS: 0|低风险
四、风险因子
地区: [US] [NL] [NL] [US] [NL] [NL] [NL] [NL]
代理: 否 否 否 否 否 否 否 否
Tor: 否 否 否 否 否 否 否 否
VPN: 否 否 否 否 否 无 否 否
服务器: 是 是 是 无 否 否 是 否
滥用: 否 否 否 否 无 否 无 无
机器人: 否 否 无 否 否 无 无 无
五、流媒体及AI服务解锁检测
状态: 解锁 解锁 解锁 解锁 解锁 屏蔽 解锁
地区: [RO] [NL] [NL] [AE] [NL] [NL]
方式: 原生 原生 原生 原生 原生 原生
六、邮局连通性及黑名单检测
本地25端口:阻断
IP地址黑名单数据库: 有效 439 正常 425 已标记 13 黑名单 1
今日IP检测量:144;总检测量:77617。感谢使用xy系列脚本!
报告链接:https://Report.Check.Place/IP/NDGCESOG1.svg
改版地址 GitHub - xykt/RegionRestrictionCheck: A bash script to check the status of your IP on various geo-restricted services. · GitHub
** 测试时间: Sun Aug 18 05:21:34 UTC 2024
** 正在测试IPv4解锁情况
** 您的网络为: Fomo Crew Fzco (89.34..)
Dazn: 原生解锁 Yes (Region: NL)
TikTok: 原生解锁 Yes (Region: RO)
Disney+: 原生解锁 Yes (Region: NL)
Netflix: 原生解锁 Yes (Region: NL)
YouTube Premium: 原生解锁 Yes (Region: AE)
Amazon Prime Video: 原生解锁 Yes (Region: NL)
TVBAnywhere+: 原生解锁 Yes
iQyi Oversea Region: 原生解锁 US
Steam Currency: EUR
ChatGPT: 原生解锁 Yes (Region: NL)
Google Gemini: 原生解锁 Yes (Region: ARE)
Bing Region: NL
Instagram Licensed Audio: ->
—Forum—
Reddit: Yes
===============[ Europe ]==============
Rakuten TV: Yes
SkyShowTime: Yes (Region: NL)
BritBox: Yes
HBO Max: Yes
Setanta Sports: No
SonyLiv: Failed (Network Connection)
Discovery+: Yes (Region: NL)
Paramount+: No
Megogo TV: Failed
—GB—
HotStar: No
Sky Go: Yes
ITV Hub: No
Channel 4: No
Channel 5: No
BBC iPLAYER: No
Acorn TV: Yes
Shudder: No
—FR—
Canal+: Yes
Molotov: No
—DE—
Joyn: No
SKY DE: No
ZDF: No
—NL—
NLZIET: Failed
videoland: Yes
NPO Start Plus: Yes
—ES—
Movistar+: Yes
—IT—
Rai Play: Yes
—CH—
SKY CH: Yes
—RU—
Amediateka: Yes
当前主机不支持IPv6,跳过…
本次测试已结束,感谢使用此脚本
检测脚本当天运行次数: 4; 共计运行次数: 129649
正在测试 https://www.google.com
尝试 1: 261.500000 ms
尝试 2: 266.098000 ms
尝试 3: 261.808000 ms
尝试 4: 259.906000 ms
尝试 5: 259.504000 ms
平均时间: 261.76 ms for https://www.google.com
正在测试 https://www.facebook.com
尝试 1: 333.420000 ms
尝试 2: 332.002000 ms
尝试 3: 346.998000 ms
尝试 4: 312.796000 ms
尝试 5: 318.813000 ms
平均时间: 328.80 ms for https://www.facebook.com
正在测试 https://www.twitter.com
尝试 1: 135.801000 ms
尝试 2: 130.159000 ms
尝试 3: 129.656000 ms
尝试 4: 129.996000 ms
尝试 5: 130.981000 ms
平均时间: 131.31 ms for https://www.twitter.com
正在测试 https://www.youtube.com
尝试 1: 345.734000 ms
尝试 2: 347.312000 ms
尝试 3: 367.869000 ms
尝试 4: 385.522000 ms
尝试 5: 355.760000 ms
平均时间: 360.43 ms for https://www.youtube.com
正在测试 https://www.netflix.com
尝试 1: 613.135000 ms
尝试 2: 356.532000 ms
尝试 3: 366.614000 ms
尝试 4: 370.743000 ms
尝试 5: 366.037000 ms
平均时间: 414.61 ms for https://www.netflix.com
正在测试 https://chat.openai.com
尝试 1: 241.294000 ms
尝试 2: 238.728000 ms
尝试 3: 243.419000 ms
尝试 4: 242.709000 ms
尝试 5: 246.799000 ms
平均时间: 242.58 ms for https://chat.openai.com
正在测试 https://www.github.com
尝试 1: 41.822000 ms
尝试 2: 44.316000 ms
尝试 3: 44.351000 ms
尝试 4: 38.775000 ms
尝试 5: 43.846000 ms
平均时间: 42.62 ms for https://www.github.com
网站 平均时间(ms)
https://www.google.com 261.76 ms
https://www.facebook.com 328.80 ms
https://www.twitter.com 131.31 ms
https://www.youtube.com 360.43 ms
https://www.netflix.com 414.61 ms
https://chat.openai.com 242.58 ms
https://www.github.com 42.62 ms
Total Avg 254.58 ms
Version : v2024-04-25
Usage : bash <(curl -sL bash.icu/speedtest)
GitHub : GitHub - i-abc/Speedtest: 多功能测速脚本 | Multi-functional speedtest script · GitHub
测速节点 下载/Mbps 上传/Mbps 延迟/ms 抖动/ms
测速次数过多,暂时被限制,请过一段时间后再进行测试
教育网 上海 1 0.06 Mbps 5.29 Mbps 1331.73 ms 16.55 ms
教育网 上海 2 11.12 Mbps 24.47 Mbps 276.09 ms 失败
教育网 辽宁沈阳 0.01 Mbps 3.86 Mbps 244.45 ms 0.83 ms
教育网 江苏南京 1 200.33 Mbps 208.99 Mbps 276.00 ms 失败
系统时间:2024-08-18 05:26:49 UTC
北京时间: 2024-08-18 13:26:49 CST
电信 四川成都 1.70 Mbps 17.00 Mbps 281.00 ms 6.60 ms
电信 江苏苏州 268.00 Mbps 22.10 Mbps 251.40 ms 失败
电信 浙江杭州 23.20 Mbps 98.00 Mbps 217.60 ms 16.80 ms
电信 浙江宁波 5G 6.50 Mbps 0.20 Mbps 232.60 ms 27.20 ms
电信 江苏镇江 5G 120.70 Mbps 107.50 Mbps 230.60 ms 13.60 ms
电信 江苏南京 5G 88.10 Mbps 失败 246.70 ms 7.30 ms
电信 湖南长沙 5G 35.90 Mbps 49.50 Mbps 260.90 ms 9.30 ms
联通 江苏无锡 失败 失败 155.60 ms 14.80 ms
广电 重庆 失败 0.10 Mbps 222.10 ms 42.00 ms
系统时间:2024-08-18 05:37:09 UTC
北京时间: 2024-08-18 13:37:09 CST
</e></CODE> <e>[/tab]</e></TAB> <TAB name="iperf3"><s>[tab="iperf3"]</s> <CODE><s>
[ 5] 0.00-1.00 sec 320 MBytes 2.69 Gbits/sec 0 6.19 MBytes
[ 5] 1.00-2.00 sec 328 MBytes 2.75 Gbits/sec 0 6.19 MBytes
[ 5] 2.00-3.00 sec 327 MBytes 2.74 Gbits/sec 0 6.19 MBytes
[ 5] 3.00-4.00 sec 334 MBytes 2.80 Gbits/sec 0 6.19 MBytes
[ 5] 4.00-5.00 sec 330 MBytes 2.77 Gbits/sec 0 6.19 MBytes
[ 5] 5.00-6.00 sec 326 MBytes 2.73 Gbits/sec 0 6.19 MBytes
[ 5] 6.00-7.00 sec 326 MBytes 2.73 Gbits/sec 0 6.19 MBytes
[ 5] 7.00-8.00 sec 331 MBytes 2.78 Gbits/sec 33 4.33 MBytes
[ 5] 8.00-9.00 sec 332 MBytes 2.78 Gbits/sec 0 4.33 MBytes
[ 5] 9.00-10.00 sec 324 MBytes 2.72 Gbits/sec 0 4.33 MBytes
[ 5] 10.00-11.00 sec 327 MBytes 2.74 Gbits/sec 0 4.33 MBytes
[ 5] 11.00-12.00 sec 337 MBytes 2.82 Gbits/sec 0 4.33 MBytes
[ 5] 12.00-13.00 sec 337 MBytes 2.83 Gbits/sec 0 4.33 MBytes
[ 5] 13.00-14.00 sec 347 MBytes 2.91 Gbits/sec 0 4.33 MBytes
[ 5] 14.00-15.00 sec 335 MBytes 2.81 Gbits/sec 0 4.33 MBytes
[ 5] 15.00-16.00 sec 337 MBytes 2.83 Gbits/sec 0 4.33 MBytes
[ 5] 16.00-17.00 sec 337 MBytes 2.82 Gbits/sec 0 4.33 MBytes
[ 5] 17.00-18.00 sec 334 MBytes 2.80 Gbits/sec 60 3.03 MBytes
[ 5] 18.00-19.00 sec 331 MBytes 2.77 Gbits/sec 0 3.03 MBytes
[ 5] 19.00-20.00 sec 270 MBytes 2.26 Gbits/sec 64 2.23 MBytes
[ 5] 20.00-21.00 sec 266 MBytes 2.23 Gbits/sec 0 2.34 MBytes
[ 5] 21.00-22.00 sec 278 MBytes 2.33 Gbits/sec 0 2.42 MBytes
[ 5] 22.00-23.00 sec 286 MBytes 2.40 Gbits/sec 0 2.48 MBytes
[ 5] 23.00-24.00 sec 284 MBytes 2.38 Gbits/sec 0 2.52 MBytes
[ 5] 24.00-25.00 sec 295 MBytes 2.47 Gbits/sec 0 2.59 MBytes
[ 5] 25.00-26.00 sec 302 MBytes 2.53 Gbits/sec 0 2.67 MBytes
[ 5] 26.00-27.00 sec 310 MBytes 2.60 Gbits/sec 0 2.75 MBytes
[ 5] 27.00-28.00 sec 324 MBytes 2.72 Gbits/sec 0 2.83 MBytes
[ 5] 28.00-29.00 sec 313 MBytes 2.63 Gbits/sec 0 2.91 MBytes
[ 5] 29.00-29.88 sec 299 MBytes 2.85 Gbits/sec 0 2.98 MBytes
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-29.88 sec 9.30 GBytes 2.67 Gbits/sec 157 sender
[ 5] 0.00-29.88 sec 0.00 Bytes 0.00 bits/sec receiver
iperf3 测试失败或超时
No:1/9 Traceroute to 中国 深圳 电信 (TCP Mode, Max 30 Hop, IPv4)
NextTrace v1.3.2 2024-07-28T10:50:28Z ea2a6b5
[NextTrace API] preferred API IP - 188.114.96.0 - 278.98ms - Misaka.BER
traceroute to 59.36.216.1, 30 hops max, 52 bytes payload
1 89.34.230.1 AS214730 罗马尼亚 布加勒斯特
0.26 ms
2 45.137.207.46 AS212477 荷兰 北荷兰省 阿姆斯特丹 royalehosting.net
0.29 ms
3 217.119.132.40 AS212477 英国 英格兰 伦敦 royalehosting.net
5.08 ms
4 81.20.69.160 AS2914 荷兰 北荷兰省 阿姆斯特丹 gin.ntt.net
19.48 ms
5 129.250.7.88 AS2914 [NTT-BACKBONE] 荷兰 北荷兰省 阿姆斯特丹 gin.ntt.net
6.61 ms
6 *
7 129.250.3.152 AS2914 [NTT-BACKBONE] 德国 黑森 美因河畔法兰克福 gin.ntt.net
7.52 ms
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 188.114.97.0 - 77.40ms - Misaka.BER
traceroute to 101.226.41.65, 30 hops max, 52 bytes payload
0.27 ms
2 217.119.132.44 AS212477 英国 英格兰 伦敦 royalehosting.net
0.36 ms
3 217.119.132.38 AS212477 英国 英格兰 伦敦 royalehosting.net
0.35 ms
0.36 ms
1.20 ms
6 129.250.3.76 AS2914 [NTT-BACKBONE] 德国 黑森 美因河畔法兰克福 gin.ntt.net
6.52 ms
7 62.115.120.239 AS1299 [ARELION-NET] 英国 英格兰 伦敦 arelion.com
5.58 ms
8 62.115.14.114 AS1299 [ARELION-NET] 英国 英格兰 伦敦 arelion.com
43.83 ms
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 188.114.97.0 - 79.09ms - Misaka.BER
traceroute to 220.181.53.1, 30 hops max, 52 bytes payload
0.19 ms
0.28 ms
0.50 ms
4 81.20.69.162 AS2914 荷兰 北荷兰省 阿姆斯特丹 gin.ntt.net
9.91 ms
8.55 ms
6 62.115.137.234 AS1299 [ARELION-NET] 英国 英格兰 伦敦 arelion.com
5.54 ms
6.21 ms
7.66 ms
9 *
10 *
11 202.97.48.245 AS4134 [CHINANET-BB] 中国 北京 www.chinatelecom.com.cn 电信
228.98 ms
12 *
13 36.110.251.74 AS23724 中国 北京 bjtelecom.net 电信
222.33 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
No:4/9 Traceroute to 中国 广州 联通 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 188.114.96.0 - 48.64ms - Misaka.BER
traceroute to 210.21.4.130, 30 hops max, 52 bytes payload
0.24 ms
0.34 ms
0.29 ms
4 213.248.99.30 AS1299 [TELIANET] 荷兰 arelion.com
0.32 ms
5 62.115.136.148 AS1299 [ARELION-NET] 瑞典 斯德哥尔摩省 斯德哥尔摩 arelion.com
0.79 ms
6 62.115.120.241 AS1299 [ARELION-NET] 德国 黑森州 美因河畔法兰克福 arelion.com
7.64 ms
7 *
8 *
9 219.158.15.157 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
166.62 ms
10 219.158.20.161 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
160.05 ms
11 219.158.11.209 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
152.70 ms
12 *
13 219.158.8.113 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
160.36 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 188.114.96.0 - 53.06ms - Misaka.BER
traceroute to 112.65.95.129, 30 hops max, 52 bytes payload
0.28 ms
0.33 ms
0.37 ms
0.35 ms
5 62.115.136.34 AS1299 [ARELION-NET] 瑞典 斯德哥尔摩省 斯德哥尔摩 arelion.com
1.00 ms
6 62.115.137.223 AS1299 [ARELION-NET] 德国 黑森州 美因河畔法兰克福 arelion.com
7.53 ms
7 62.115.132.209 AS1299 [ARELION-NET] 德国 黑森州 美因河畔法兰克福 arelion.com
9.65 ms
8 *
9 219.158.14.81 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
164.13 ms
10 219.158.3.133 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
160.72 ms
11 *
12 *
13 *
14 210.22.66.178 AS17621 [APNIC-AP] 中国 上海 chinaunicom.cn 联通
184.61 ms
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 188.114.96.0 - 77.95ms - Misaka.BER
traceroute to 61.49.140.217, 30 hops max, 52 bytes payload
0.24 ms
0.40 ms
0.61 ms
4 213.248.99.40 AS1299 [TELIANET] 荷兰 arelion.com
0.44 ms
0.73 ms
7.73 ms
7 62.115.132.211 AS1299 [ARELION-NET] 德国 黑森州 美因河畔法兰克福 arelion.com
9.99 ms
8 219.158.43.21 AS4837 [CU169-BACKBONE] 中国 上海 chinaunicom.cn 联通
7.70 ms
9 219.158.6.77 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn
164.64 ms
10 *
11 *
12 219.158.4.37 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
165.00 ms
13 124.64.212.38 AS4808 [UNICOM-BJ] 中国 北京市 大兴 中国联通 联通
205.64 ms
14 61.49.140.217 AS4808 中国 北京 中国联通 联通
185.89 ms
No:7/9 Traceroute to 中国 深圳 移动 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 188.114.97.0 - 75.36ms - Misaka.BER
traceroute to 120.233.53.1, 30 hops max, 52 bytes payload
0.19 ms
0.32 ms
6.55 ms
0.37 ms
1.11 ms
7.62 ms
7 62.115.127.7 AS1299 [ARELION-NET] 英国 英格兰 斯劳 arelion.com
7.78 ms
8 62.115.171.223 AS1299 [ARELION-NET] 英国 英格兰 斯劳 CMI-Telia-Cust arelion.com
6.55 ms
9 223.120.10.225 AS58453 [CMI-INT] 英国 英格兰 斯劳 cmi.chinamobile.com 移动
95.41 ms
10 223.120.14.254 AS58453 [CMI-INT] 中国 广东 广州 cmi.chinamobile.com
211.24 ms
11 221.183.92.189 AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
214.68 ms
12 221.183.92.213 AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
295.45 ms
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 188.114.96.0 - 52.75ms - Misaka.BER
traceroute to 183.194.216.129, 30 hops max, 52 bytes payload
1.96 ms
0.29 ms
4.45 ms
0.39 ms
0.90 ms
5.72 ms
7 62.115.112.63 AS1299 [ARELION-NET] 英国 英格兰 斯劳 arelion.com
7.64 ms
8.20 ms
9 223.120.11.57 AS58453 [CMI-INT] 英国 英格兰 伦敦 cmi.chinamobile.com
9.39 ms
10 223.120.16.218 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com 移动
273.91 ms
11 221.183.89.170 AS9808 [CMNET] 中国 上海 回国到达层 chinamobileltd.com 移动
272.54 ms
12 221.183.89.33 AS9808 [CMNET] 中国 上海 chinamobileltd.com 移动
278.77 ms
13 221.183.89.14 AS9808 [CMNET] 中国 上海 chinamobileltd.com 移动
276.91 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 188.114.96.0 - 52.60ms - Misaka.BER
traceroute to 211.136.25.153, 30 hops max, 52 bytes payload
0.22 ms
0.32 ms
0.34 ms
0.44 ms
1.11 ms
6 *
7 62.115.112.244 AS1299 [ARELION-NET] 美国 纽约 纽约 arelion.com
78.42 ms
8 62.115.137.169 AS1299 [ARELION-NET] 美国 加利福尼亚 圣何塞 arelion.com
143.05 ms
9 62.115.171.215 AS1299 [ARELION-NET] 美国 加利福尼亚 圣何塞 Telia-CMI-Peer arelion.com
143.03 ms
10 223.120.6.69 AS58453 [CMI-INT] 美国 加利福尼亚 圣何塞 cmi.chinamobile.com 移动
146.93 ms
11 223.120.22.21 AS58453 [CMI-INT] 中国 北京 cmi.chinamobile.com 移动
247.63 ms
12 221.183.55.102 AS9808 [CMNET] 中国 北京 X-I chinamobileltd.com 移动
231.44 ms
13 221.183.25.201 AS9808 [CMNET] 中国 北京 chinamobileltd.com 移动
229.01 ms
14 *
15 *
16 *
17 211.136.67.166 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
235.26 ms
18 211.136.95.226 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
254.35 ms
19 *
20 *
21 211.136.25.153 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
248.49 ms
[/tab]
[tab=“去程路由”]
[/tab]
[tab=“Ping.pe”]
[/tab]
[tab=“哪吒 ICMP”]
[/tab]
[tab=“其他”]
[/tab]
[/tabs]
完美解锁,2.5Tbs/s无限流防御,超级硬盘。
挺硬的😂10Gbs宽带
感谢@"丰仔"#155
@"Cloudblast"#3978
这个格式怎么奇奇怪怪的,难道TG改格式了?
你这个格式怎么字体这么大?:huaji09:
脚本出问题了?
现在完美了,被TG吃符号了:ac01:
[“CloudBlast\u5c0f\u6d4b\u4e0d\u8bc4”,“CloudBlast\u5c0f\u6d4b”]
是真想不到还能解锁流媒体
我想把博客放上边了
@“削除禁止”#p68440 商家有可能会来哦
@“loll”#p68442 蹲一个:xhj06:
看起来不错
@“James”#p68454 cdn搞好了吗我也申请了:joy:
看起来还行
@“lingdo”#p68461 RAM单线程3w,这个很不错
7551 分数怎么会这么低
@“James”#p68469 我也在好奇这个问题
