[tabs]
[tab=“YABS”]
Yet-Another-Bench-Script
v2024-06-09
GitHub - masonr/yet-another-bench-script: YABS - a simple bash script to estimate Linux server performance using fio, iperf3, & Geekbench
Thu Aug 15 04:32:47 PM KST 2024
Basic System Information:
Uptime : 12 days, 1 hours, 11 minutes
Processor : Intel(R) Xeon(R) CPU E5-2678 v3 @ 2.50GHz
CPU cores : 1 @ 2499.996 MHz
AES-NI :
Enabled
VM-x/AMD-V :
Enabled
RAM : 973.3 MiB
Swap : 0.0 KiB
Disk : 14.7 GiB
Distro : Debian GNU/Linux 12 (bookworm)
Kernel : 6.1.0-22-cloud-amd64
VM Type : KVM
IPv4/IPv6 :
Online /
Offline
IPv4 Network Information:
ISP : Internet Utilities Europe and Asia Limited
ASN : AS214496 Arcueid Network Limited
Host : Internet Utilities Europe and Asia Limited
Country : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
Read | 25.07 MB/s (6.2k) | 341.71 MB/s (5.3k)
Write | 25.09 MB/s (6.2k) | 343.51 MB/s (5.3k)
Total | 50.16 MB/s (12.5k) | 685.23 MB/s (10.7k)
Read | 297.10 MB/s (580) | 290.51 MB/s (283)
Write | 312.88 MB/s (611) | 309.86 MB/s (302)
Total | 609.99 MB/s (1.1k) | 600.38 MB/s (585)
cue elevator music
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 2 min 4 sec
</e></CODE> <e>[/tab]</e></TAB> <TAB name="融合怪"><s>[tab="融合怪"]</s> <CODE><s>
VPS融合怪版本:2024.08.14
Shell项目地址:GitHub - spiritLHLS/ecs: VPS 融合怪服务器测评项目 更推荐使用无环境依赖的Go版本 VPS Fusion Monster Server Test Script – More recommended to use the Go version with no environment dependencies: https://github.com/oneclickvirt/ecs
Go项目地址:GitHub - oneclickvirt/ecs: VPS融合怪服务器测评项目 GO版本 VPS Fusion Monster Server Test GO Version 尽量成为最全能的服务器测评项目,使用 Go 实现,无需任何环境依赖。 Aiming to be the most comprehensive server testing project, implemented in Go with zero environment dependencies.
CPU 型号 : Intel(R) Xeon(R) CPU E5-2678 v3 @ 2.50GHz
CPU 核心数 : 1
CPU 频率 : 2499.996 MHz
CPU 缓存 : L1: 32.00 KB / L2: 256.00 KB / L3: 30.00 MB
AES-NI指令集 :
Enabled
VM-x/AMD-V支持 :
Enabled
内存 : 353.54 MiB / 973.28 MiB
硬盘空间 : 2.22 GiB / 14.66 GiB
启动盘路径 : /dev/vda1
系统在线时间 : 12 days, 1 hour 14 min
负载 : 0.96, 0.46, 0.18
架构 : x86_64 (64 Bit)
内核 : 6.1.0-22-cloud-amd64
TCP加速方式 : bbr
虚拟化架构 : KVM
NAT类型 : Full Cone
IPV4 ASN : AS214496 Arcueid Network Limited
IPV4 位置 : Los Angeles / California / US
1 线程测试(单核)得分: 1/1
1 线程测试(单核)得分: 661 Scores
单线程读测试: 1/1
单线程读测试: 15444.46 MB/s
单线程写测试: 1/1
单线程写测试: 13577.59 MB/s
测试操作 写速度 读速度
100MB-4K Block ->
100MB-4K Block 13.2 MB/s (3214 IOPS, 7.96s) ->
100MB-4K Block 13.2 MB/s (3214 IOPS, 7.96s) 15.9 MB/s (3877 IOPS, 6.60s)
1GB-1M Block ->
1GB-1M Block 716 MB/s (683 IOPS, 1.46s) ->
1GB-1M Block 716 MB/s (683 IOPS, 1.46s) 721 MB/s (687 IOPS, 1.45s)
Running fio test…
Read | 25.39 MB/s (6.3k) | 280.45 MB/s (4.3k)
Write | 25.42 MB/s (6.3k) | 281.93 MB/s (4.4k)
Total | 50.81 MB/s (12.7k) | 562.38 MB/s (8.7k)
Read | 241.84 MB/s (472) | 274.48 MB/s (268)
Write | 254.69 MB/s (497) | 292.76 MB/s (285)
Total | 496.54 MB/s (969) | 567.25 MB/s (553)
[IPV4]
您的出口IP完整解锁Netflix,支持非自制剧的观看
NF所识别的IP地域信息:美国
[IPV6]
您的网络可能没有正常配置IPv6,或者没有IPv6网络接入
[IPV4]
连接方式: Youtube Video Server
视频缓存节点地域: 美国 洛杉机(LAX17S56)
[IPV6]
Youtube在您的出口IP所在的国家不提供服务
[IPV4]
当前出口所在地区解锁DisneyPlus
区域:US 区
[IPV6]
DisneyPlus在您的出口IP所在的国家不提供服务
以下为IPV4网络测试,若无IPV4网络则无输出
Dazn: Yes (Region: US)
Disney+: Yes (Region: US)
Netflix: Yes (Region: US)
YouTube Premium: Yes (Region: GB)
Amazon Prime Video: Yes (Region: US)
TVBAnywhere+: Yes
Spotify Registration: Yes (Region: US)
Instagram Licensed Audio: Yes
OneTrust Region: US [California]
iQyi Oversea Region: US
Bing Region: US
YouTube CDN: Los Angeles, CA
Netflix Preferred CDN: Los Angeles, CA
ChatGPT: Yes
Google Gemini: No
Wikipedia Editability: Yes
Steam Currency: USD
—Forum—
Reddit: Yes
以下为IPV6网络测试,若无IPV6网络则无输出
Tiktok Region: 【GB】
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
IPV4:
安全得分:
声誉(越高越好): 0 [2]
信任得分(越高越好): 0 [8]
VPN得分(越低越好): 100 [8]
代理得分(越低越好): 100 [8]
社区投票-无害: 0 [2]
社区投票-恶意: 0 [2]
威胁得分(越低越好): 99 [8]
欺诈得分(越低越好): 0 [1 E]
滥用得分(越低越好): 0 [3]
ASN滥用得分(越低越好): 0 (Very Low) [A]
威胁级别: low [9 B]
黑名单记录统计:(有多少黑名单网站有记录):
安全信息:
使用类型: DataCenter/WebHosting/Transit [3] business [8 A] hosting [0 7] corporate [9] unknown [C]
公司类型: hosting [0 7] business [A]
是否云提供商: Yes [7 D]
是否数据中心: Yes [0 1 A] No [5 6 8 C]
是否移动设备: Yes [E] No [5 A C]
是否代理: No [0 1 4 5 6 7 8 9 A B C D E]
是否VPN: No [0 1 6 7 A C D E]
是否TorExit: No [1 7 D]
是否Tor出口: No [1 7 D]
是否网络爬虫: No [9 A B E]
是否匿名: No [1 6 7 8 D]
是否攻击者: No [7 8 D]
是否滥用者: No [7 8 A C D E]
是否威胁: No [7 8 C D]
是否中继: No [0 7 8 C D]
是否Bogon: No [7 8 A C D]
是否机器人: No [E]
DNS-黑名单: 310(Total_Check) 0(Clean) 6(Blacklisted) 16(Other)
Google搜索可行性:YES
LocalPort
QQ
163
Sohu
Yandex
Gmail
Outlook
Office365
Yahoo
MailCOM
MailRU
AOL
GMX
Sina
北京移动 221.179.155.161 检测不到回程路由节点的IP地址
成都电信 61.139.2.69 电信163 [普通线路]
成都联通 119.6.6.6 联通4837 [普通线路]
成都移动 211.137.96.205 电信163 [普通线路]
准确线路自行查看详细路由,本测试结果仅作参考
广州电信 58.60.188.222
2.98 ms AS214496 英国 伦敦 Harmony Networks, Inc
51.43 ms AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
1.49 ms AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
152.25 ms AS4134 [CHINANET-BB] 中国 广东 广州 www.chinatelecom.com.cn 电信
153.50 ms AS4134 [CHINANET-BB] 中国 广东 广州 www.chinatelecom.com.cn 电信
169.74 ms AS4134 [CHINANET-BB] 中国 广东 广州 www.chinatelecom.com.cn 电信
207.26 ms AS134774 [CHINANET-GD] 中国 广东 深圳 chinatelecom.cn 电信
157.92 ms AS4134 中国 广东 深圳 福田区 www.chinatelecom.com.cn 电信
广州联通 210.21.196.6
4.84 ms AS214496 英国 伦敦 Harmony Networks, Inc
0.99 ms AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
1.52 ms AS174 [COGENT-BONE] 美国 加利福尼亚 洛杉矶 cogentco.com
163.84 ms AS174 美国 加利福尼亚 洛杉矶 cogentco.com
160.99 ms AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
175.46 ms AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
217.09 ms AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
170.43 ms AS17816 [APNIC-AP] 中国 广东 深圳 chinaunicom.cn 联通
172.21 ms AS17623 [APNIC-AP] 中国 广东 深圳 chinaunicom.cn 联通
170.76 ms AS17623 [APNIC-AP] 中国 广东 深圳 宝安区 chinaunicom.cn 联通
广州移动 120.196.165.24
2.74 ms AS214496 英国 伦敦 Harmony Networks, Inc
101.67 ms AS40065 [DATA-CENTRE] 美国 加利福尼亚州 洛杉矶 cnservers.com
10.67 ms AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com
10.59 ms AS58453 [CMI-INT] 美国 加利福尼亚 圣何塞 cmi.chinamobile.com 移动
171.36 ms AS58453 [CMI-INT] 美国 加利福尼亚 旧金山 cmi.chinamobile.com 移动
159.19 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
158.62 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
217.51 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
166.73 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
170.13 ms AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
163.79 ms AS56040 [APNIC-AP] 中国 广东 深圳 gd.10086.cn 移动
位置 上传速度 下载速度 延迟 丢包率
Speedtest.net 97.67 Mbps 97.24 Mbps 6.01 0.0%
洛杉矶 97.68 Mbps 96.77 Mbps 1.06 0.0%
日本东京 101.53 Mbps 113.57 Mbps 99.26 0.7%
联通WuXi 105.82 Mbps 112.45 Mbps 171.25 4.0%
电信Suzhou5G 4.21 Mbps 111.04 Mbps 136.84 NULL
电信Zhenjiang5G 99.20 Mbps 111.35 Mbps 156.50 NULL
该运营商.net的节点列表为空,正在替换为.cn的节点列表。。。
总共花费 : 8 分 28 秒
时间 : Thu Aug 15 16:43:38 KST 2024
短链:
http://hpaste.spiritlhl.net/u/SlZkyo.txt
IP质量体检报告:45.158.*.*
bash <(curl -sL IP.Check.Place)
报告时间:2024-08-15 15:43:44 CST 脚本版本:v2024-07-29
一、基础信息(Maxmind 数据库)
自治系统号: AS214496
组织: Arcueid Network Limited
坐标: 118°14′39″W, 34°3′16″N
地图: https://check.place/34.0544,-118.2441,15,cn
城市: 加州, 洛杉矶, 90060
使用地: [US]美国, [NA]北美洲
注册地: [GB]英国
时区: America/Los_Angeles
IP类型: 广播IP
二、IP类型属性
使用类型: 机房 机房 商业 机房 机房
公司类型: 机房 机房 商业
三、风险评分
风险等级: 极低 低 中等 高 极高
SCAMALYTICS: 0|低风险
ipapi: 0.00%|极低风险
AbuseIPDB: 0|低风险
IPQS: 0|低风险
DB-IP: |低风险
四、风险因子
地区: [US] [US] [US] [GB] [US] [GB] [US] [US]
代理: 否 否 否 否 否 否 否 否
Tor: 否 否 否 否 否 否 否 否
VPN: 否 否 否 否 否 无 否 否
服务器: 是 是 是 无 否 否 是 否
滥用: 否 否 否 否 无 否 无 无
机器人: 否 否 无 否 否 无 无 无
五、流媒体及AI服务解锁检测
状态: 解锁 解锁 解锁 解锁 解锁 解锁 解锁
地区: [GB] [US] [US] [GB] [US] [US] [US]
方式: 原生 原生 原生 原生 原生 原生 原生
六、邮局连通性及黑名单检测
本地25端口:阻断
IP地址黑名单数据库: 有效 439 正常 433 已标记 6 黑名单 0
今日IP检测量:321;总检测量:75052。感谢使用xy系列脚本!
报告链接:https://Report.Check.Place/IP/U0ZNCZW2D.svg
项目地址 GitHub - lmc999/RegionRestrictionCheck: A bash script to check the status of your IP on various geo-restricted services.
改版地址 GitHub - xykt/RegionRestrictionCheck: A bash script to check the status of your IP on various geo-restricted services.
** 测试时间: Thu Aug 15 04:44:27 PM KST 2024
** 正在测试IPv4解锁情况
** 您的网络为: Arcueid Network (45.158..)
Dazn: Unsupport
TikTok: 原生解锁 Yes (Region: GB)
Disney+: No
Netflix: 原生解锁 Yes (Region: US)
YouTube Premium: 原生解锁 Yes (Region: GB)
Amazon Prime Video: 原生解锁 Yes (Region: US)
TVBAnywhere+: Failed
iQyi Oversea Region: 原生解锁 US
Netflix Preferred CDN: Associated with in [Los Angeles, CA ]
Steam Currency: USD
ChatGPT: 原生解锁 Yes (Region: US)
Google Gemini: No
Bing Region: US
Instagram Licensed Audio: ->
—Forum—
Reddit: Yes
===========[ North America ]===========
FOX: No
Hulu: Yes
NFL+: Yes
ESPN+:[Sponsored by Jam] No
MGM+: Failed (Network Connection)
MGM+: Failed
Starz: Failed
Philo: Failed
FXNOW: No
TLC GO: Yes
HBO Max: Yes
Shudder: Yes
BritBox: Yes
Crackle: Failed
CW TV: Yes
A&E TV: Failed
NBA TV: Yes
NBC TV: Yes
Fubo TV: Yes
Tubi TV: Yes
Sling TV: Yes
Pluto TV: Yes
Acorn TV: Yes
SHOWTIME: Yes
encoreTVB: Failed
Discovery+: Yes (Region: US)
Paramount+: Yes
Peacock TV: Yes
Popcornflix: Failed (Network Connection)
Crunchyroll: Yes
KOCOWA: Yes
SonyLiv: Failed (Network Connection)
AMC+: Yes (Region: USA)
—CA—
HotStar: 原生解锁 Yes (Region: US)
CBC Gem: No
Crave: Yes
当前主机不支持IPv6,跳过…
本次测试已结束,感谢使用此脚本
检测脚本当天运行次数: 17; 共计运行次数: 129592
正在测试 https://www.google.com
尝试 1: 142.383000 ms
尝试 2: 152.326000 ms
尝试 3: 146.522000 ms
尝试 4: 137.884000 ms
尝试 5: 117.782000 ms
平均时间: 139.37 ms for https://www.google.com
正在测试 https://www.facebook.com
尝试 1: 220.401000 ms
尝试 2: 208.863000 ms
尝试 3: 201.912000 ms
尝试 4: 224.286000 ms
尝试 5: 264.184000 ms
平均时间: 223.92 ms for https://www.facebook.com
正在测试 https://www.twitter.com
尝试 1: 158.802000 ms
尝试 2: 141.300000 ms
尝试 3: 162.345000 ms
尝试 4: 160.227000 ms
尝试 5: 135.322000 ms
平均时间: 151.59 ms for https://www.twitter.com
正在测试 https://www.youtube.com
尝试 1: 331.956000 ms
尝试 2: 241.062000 ms
尝试 3: 322.689000 ms
尝试 4: 268.191000 ms
尝试 5: 342.400000 ms
平均时间: 301.25 ms for https://www.youtube.com
正在测试 https://www.netflix.com
尝试 1: 546.556000 ms
尝试 2: 542.540000 ms
尝试 3: 586.958000 ms
尝试 4: 6095.275000 ms
尝试 5: 562.491000 ms
平均时间: 1666.76 ms for https://www.netflix.com
正在测试 https://chat.openai.com
尝试 1: 151.147000 ms
尝试 2: 135.542000 ms
尝试 3: 100.316000 ms
尝试 4: 103.211000 ms
尝试 5: 122.733000 ms
平均时间: 122.58 ms for https://chat.openai.com
正在测试 https://www.github.com
尝试 1: 134.869000 ms
尝试 2: 124.727000 ms
尝试 3: 131.520000 ms
尝试 4: 127.619000 ms
尝试 5: 132.629000 ms
平均时间: 130.27 ms for https://www.github.com
网站 平均时间(ms)
https://www.google.com 139.37 ms
https://www.facebook.com 223.92 ms
https://www.twitter.com 151.59 ms
https://www.youtube.com 301.25 ms
https://www.netflix.com 1666.76 ms
https://chat.openai.com 122.58 ms
https://www.github.com 130.27 ms
Total Avg 390.82 ms
Version : v2024-04-25
Usage : bash <(curl -sL bash.icu/speedtest)
GitHub : GitHub - i-abc/Speedtest: 多功能测速脚本 | Multi-functional speedtest script
测速节点 下载/Mbps 上传/Mbps 延迟/ms 抖动/ms
最近的测速点 96.82 Mbps 97.57 Mbps 0.71 ms 0.01 ms
电信 江苏苏州 112.74 Mbps 16.25 Mbps 137.43 ms 0.57 ms
电信 浙江杭州 105.93 Mbps 104.29 Mbps 172.80 ms 5.66 ms
电信 浙江宁波 5G 108.41 Mbps 104.97 Mbps 161.60 ms 0.78 ms
电信 江苏镇江 5G 112.15 Mbps 108.30 Mbps 130.90 ms 0.34 ms
电信 江苏南京 5G 108.81 Mbps 7.43 Mbps 132.17 ms 0.57 ms
联通 江苏无锡 108.44 Mbps 105.07 Mbps 170.79 ms 0.09 ms
测速次数过多,暂时被限制,请过一段时间后再进行测试
教育网 上海 1 0.07 Mbps 7.26 Mbps 1194.00 ms 107.39 ms
教育网 上海 2 21.60 Mbps 31.40 Mbps 222.91 ms 0.06 ms
教育网 辽宁沈阳 0.01 Mbps 5.77 Mbps 200.09 ms 0.36 ms
教育网 江苏南京 1 91.26 Mbps 95.87 Mbps 217.09 ms 0.01 ms
教育网 江苏南京 2 30.70 Mbps 13.74 Mbps 228.18 ms 3.41 ms
系统时间:2024-08-15 16:52:16 KST
北京时间: 2024-08-15 15:52:16 CST
电信 四川成都 失败 70.60 Mbps 185.90 ms 2.80 ms
电信 江苏苏州 88.20 Mbps 97.10 Mbps 134.80 ms 15.60 ms
电信 浙江杭州 13.50 Mbps 7.50 Mbps 138.20 ms 14.30 ms
电信 浙江宁波 5G 66.70 Mbps 76.50 Mbps 136.10 ms 9.90 ms
电信 江苏镇江 5G 67.40 Mbps 79.60 Mbps 132.70 ms 10.40 ms
电信 江苏南京 5G 88.00 Mbps 失败 134.80 ms 17.40 ms
移动 陕西西安 5G 98.00 Mbps 90.60 Mbps 184.00 ms 17.90 ms
联通 江苏无锡 失败 失败 172.20 ms 37.80 ms
广电 重庆 失败 0.80 Mbps 209.00 ms 36.50 ms
系统时间:2024-08-15 17:02:25 KST
北京时间: 2024-08-15 16:02:25 CST
</e></CODE> <e>[/tab]</e></TAB> <TAB name="iperf3"><s>[tab="iperf3"]</s> <CODE><s>
[ 5] 0.00-1.00 sec 3.62 MBytes 30.3 Mbits/sec 0 690 KBytes
[ 5] 1.00-2.00 sec 16.1 MBytes 135 Mbits/sec 0 8.82 MBytes
[ 5] 2.00-3.00 sec 20.0 MBytes 168 Mbits/sec 0 8.82 MBytes
[ 5] 3.00-4.00 sec 13.8 MBytes 115 Mbits/sec 1382 1.82 MBytes
[ 5] 4.00-5.00 sec 12.5 MBytes 105 Mbits/sec 589 2.15 MBytes
[ 5] 5.00-6.00 sec 11.2 MBytes 94.4 Mbits/sec 1225 2.99 MBytes
[ 5] 6.00-7.00 sec 12.5 MBytes 105 Mbits/sec 615 6.47 MBytes
[ 5] 7.00-8.00 sec 10.0 MBytes 83.9 Mbits/sec 1650 6.08 MBytes
[ 5] 8.00-9.00 sec 12.5 MBytes 105 Mbits/sec 873 6.14 MBytes
[ 5] 9.00-10.00 sec 11.2 MBytes 94.4 Mbits/sec 699 2.35 MBytes
[ 5] 10.00-11.00 sec 11.2 MBytes 94.4 Mbits/sec 1260 6.63 MBytes
[ 5] 11.00-12.00 sec 11.2 MBytes 94.4 Mbits/sec 1205 1.98 MBytes
[ 5] 12.00-13.00 sec 11.2 MBytes 94.3 Mbits/sec 874 2.55 MBytes
[ 5] 13.00-14.00 sec 11.2 MBytes 94.4 Mbits/sec 1119 2.07 MBytes
[ 5] 14.00-15.00 sec 11.2 MBytes 94.4 Mbits/sec 1056 2.25 MBytes
[ 5] 15.00-16.00 sec 11.2 MBytes 94.4 Mbits/sec 942 4.85 MBytes
[ 5] 16.00-17.00 sec 11.2 MBytes 94.4 Mbits/sec 651 4.94 MBytes
[ 5] 17.00-18.00 sec 11.2 MBytes 94.4 Mbits/sec 1108 3.62 MBytes
[ 5] 18.00-19.00 sec 11.2 MBytes 94.1 Mbits/sec 1250 3.01 MBytes
[ 5] 19.00-20.00 sec 7.50 MBytes 63.1 Mbits/sec 660 5.26 MBytes
[ 5] 20.00-21.00 sec 15.0 MBytes 126 Mbits/sec 876 1.98 MBytes
[ 5] 21.00-22.00 sec 12.5 MBytes 105 Mbits/sec 604 6.39 MBytes
[ 5] 22.00-23.00 sec 10.0 MBytes 83.9 Mbits/sec 1041 2.43 MBytes
[ 5] 23.00-24.00 sec 7.50 MBytes 62.9 Mbits/sec 2099 5.31 MBytes
[ 5] 24.00-25.00 sec 10.0 MBytes 83.9 Mbits/sec 1212 1.74 MBytes
[ 5] 25.00-26.00 sec 10.0 MBytes 83.9 Mbits/sec 731 2.91 MBytes
[ 5] 26.00-27.00 sec 13.8 MBytes 115 Mbits/sec 1048 2.17 MBytes
[ 5] 27.00-28.00 sec 10.0 MBytes 83.9 Mbits/sec 1065 1.89 MBytes
[ 5] 28.00-29.00 sec 12.5 MBytes 105 Mbits/sec 367 2.19 MBytes
[ 5] 29.00-29.22 sec 2.50 MBytes 96.0 Mbits/sec 418 5.68 MBytes
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-29.22 sec 336 MBytes 96.5 Mbits/sec 26619 sender
[ 5] 0.00-29.22 sec 0.00 Bytes 0.00 bits/sec receiver
iperf3 测试失败或超时
No:1/9 Traceroute to 中国 深圳 电信 (TCP Mode, Max 30 Hop, IPv4)
NextTrace v1.3.2 2024-07-28T10:50:28Z ea2a6b5
[NextTrace API] preferred API IP - 172.67.155.192 - 152.63ms - Misaka.LAX
traceroute to 59.36.216.1, 30 hops max, 52 bytes payload
1 45.158.127.1 AS214496 英国 伦敦 Harmony Networks, Inc
3.85 ms
2 *
3 192.168.77.105 * RFC1918
0.95 ms
4 23.225.225.226 AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
8.57 ms
5 *
6 202.97.83.221 AS4134 [CHINANET-BB] 中国 广东 广州 www.chinatelecom.com.cn 电信
156.59 ms
7 *
8 202.97.93.50 AS4134 [CHINANET-BB] 中国 广东 广州 www.chinatelecom.com.cn
162.78 ms
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 86.39ms - Misaka.LAX
traceroute to 101.226.41.65, 30 hops max, 52 bytes payload
2.19 ms
2 *
3 *
4 *
5 218.30.53.121 AS4134 [CHINANET-US] 美国 加利福尼亚州 洛杉矶 www.chinatelecom.com.cn
10.70 ms
6 *
7 *
8 202.97.85.50 AS4134 [CHINANET-BB] 中国 上海 www.chinatelecom.com.cn 电信
154.57 ms
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 89.45ms - Misaka.LAX
traceroute to 220.181.53.1, 30 hops max, 52 bytes payload
2.36 ms
2 *
3 *
4 23.225.225.217 AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
194.94 ms
5 202.97.52.165 AS4134 [CHINANET-BB] 中国 北京 www.chinatelecom.com.cn 电信
163.50 ms
6 *
7 *
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
No:4/9 Traceroute to 中国 广州 联通 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 104.21.40.176 - 85.00ms - Misaka.LAX
traceroute to 210.21.4.130, 30 hops max, 52 bytes payload
2.23 ms
2 23.224.21.116 AS40065 [DATA-CENTRE] 美国 加利福尼亚州 洛杉矶 cnservers.com
0.69 ms
3 *
4 *
5 128.241.5.9 AS2914 [NTTA-128] 美国 加利福尼亚 洛杉矶 gin.ntt.net
1.01 ms
6 4.69.209.249 AS3356 美国 加利福尼亚 洛杉矶 lumen.com
0.86 ms
7 4.26.1.158 AS3356 美国 加利福尼亚 洛杉矶 Level3-CU-Peer lumen.com
269.86 ms
8 *
9 219.158.96.29 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
240.37 ms
10 *
11 120.86.0.182 AS17816 [APNIC-AP] 中国 广东 广州 chinaunicom.cn 联通
224.63 ms
12 120.86.0.182 AS17816 [APNIC-AP] 中国 广东 广州 chinaunicom.cn 联通
172.39 ms
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 93.78ms - Misaka.LAX
traceroute to 112.65.95.129, 30 hops max, 52 bytes payload
2.29 ms
2 *
3 *
4 *
5 *
6 213.200.124.170 AS3257 [GTT-EU] 美国 加利福尼亚 洛杉矶 gtt.net
1.69 ms
7 62.115.119.91 AS1299 [ARELION-NET] 美国 加利福尼亚 洛杉矶 arelion.com
13.71 ms
8 154.54.5.102 AS174 [COGENT-BONE] 美国 加利福尼亚 圣何塞 cogentco.com
27.09 ms
9 80.239.134.247 AS1299 美国 加利福尼亚 洛杉矶 arelion.com
191.26 ms
10 *
11 219.158.10.25 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn
159.13 ms
12 210.22.66.174 AS17621 [APNIC-AP] 中国 上海 chinaunicom.cn 联通
161.29 ms
13 210.22.66.178 AS17621 [APNIC-AP] 中国 上海 chinaunicom.cn 联通
258.09 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 86.74ms - Misaka.LAX
traceroute to 61.49.140.217, 30 hops max, 52 bytes payload
2.52 ms
2 *
3 *
4 *
5 *
6 *
7 *
8 219.158.116.241 AS4837 [CU169-BACKBONE] 中国 上海 chinaunicom.cn 联通
191.97 ms
9 38.120.20.114 AS174 美国 加利福尼亚 圣何塞 cogentco.com
197.29 ms
10 219.158.98.9 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
205.35 ms
11 *
12 *
13 61.49.140.217 AS4808 中国 北京 中国联通 联通
186.09 ms
No:7/9 Traceroute to 中国 深圳 移动 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 172.67.155.192 - 85.76ms - Misaka.LAX
traceroute to 120.233.53.1, 30 hops max, 52 bytes payload
5.16 ms
2 *
3 *
4 23.225.225.230 AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
3.11 ms
5 23.225.120.170 AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
1.19 ms
6 223.120.6.17 AS58453 [CMI-INT] 美国 加利福尼亚 洛杉矶 cmi.chinamobile.com 移动
0.97 ms
7 223.120.16.242 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com
156.90 ms
8 *
9 *
10 221.183.151.189 AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com
156.40 ms
11 *
12 211.136.204.26 AS56040 [CMNET] 中国 广东 广州 gd.10086.cn 移动
158.43 ms
13 211.136.242.182 AS56040 [CMNET] 中国 广东 广州 gd.10086.cn 移动
163.08 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 82.38ms - Misaka.LAX
traceroute to 183.194.216.129, 30 hops max, 52 bytes payload
2.41 ms
2 *
3 *
4 *
5 23.225.225.33 AS40065 [DATA-CENTRE] 美国 加利福尼亚 洛杉矶 cnservers.com
6.90 ms
6 *
7 202.97.74.2 AS4134 [CHINANET-BB] 中国 上海 www.chinatelecom.com.cn 电信
135.07 ms
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 104.21.40.176 - 85.66ms - Misaka.LAX
traceroute to 211.136.25.153, 30 hops max, 52 bytes payload
10.90 ms
2 *
3 *
4 223.119.64.169 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com
1.03 ms
5 223.119.66.213 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com
11.22 ms
6 *
7 223.120.13.50 AS58453 [CMI-INT] 美国 加利福尼亚 旧金山 cmi.chinamobile.com 移动
178.31 ms
8 221.183.25.201 AS9808 [CMNET] 中国 北京 chinamobileltd.com 移动
193.94 ms
9 202.97.17.90 AS4134 [CHINANET-BB] 中国 北京 www.chinatelecom.com.cn 电信
165.70 ms
10 *
11 *
12 *
13 211.136.67.166 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
193.03 ms
14 211.136.63.66 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
169.65 ms
15 *
16 *
17 211.136.25.153 AS56048 [CMNET] 中国 北京 bj.10086.cn 移动
195.38 ms
[/tab]
[tab=“去程路由”]
[/tab]
[tab=“Ping.pe”]
[/tab]
[tab=“哪吒 ICMP”]
[upl-image-preview url=https://s.rmimg.com/2024-08-18/1723917634-838353-image.png]
[/tab]
[tab=“其他”]
[/tab]
[/tabs]
