### 面板页
### 后台页
**友情提示 使用Serv00搭建的好像不支持PNG格式上传 上传后会显示空白不显示图片**
### Serv00图床 `PNG上传空白` 解决办法 复制以下代码 替换到 `config/image_processing.php`
``` PHP
<?php
将JPEG图片转换为WebP格式
function convertToWebp($source, $destination, $quality = 60) {
$info = getimagesize($source);
if ($info[‘mime’] == ‘image/jpeg’) {
$image = imagecreatefromjpeg($source);
} elseif ($info[‘mime’] == ‘image/gif’) {
return false;
} else {
return false;
$width = imagesx($image);
$height = imagesy($image);
$maxWidth = 2500;
$maxHeight = 1600;
if ($width > $maxWidth || $height > $maxHeight) {
$ratio = min($maxWidth / $width, $maxHeight / $height);
$newWidth = round($width * $ratio);
$newHeight = round($height * $ratio);
$newImage = imagecreatetruecolor($newWidth, $newHeight);
imagecopyresampled($newImage, $image, 0, 0, 0, 0, $newWidth, $newHeight, $width, $height);
imagedestroy($image);
$image = $newImage;
$result = imagewebp($image, $destination, $quality);
gc_collect_cycles();
return $result;
使用Imagick将PNG图片转换为WebP格式
function convertPngWithImagick($source, $destination, $quality = 60) {
try {
$image = new Imagick($source);
// 检查是否包含透明通道
if ($image->getImageAlphaChannel()) {
// 设置背景颜色为透明
$image->setImageBackgroundColor(new ImagickPixel('transparent'));
$image->setImageAlphaChannel(Imagick::ALPHACHANNEL_ACTIVATE);
$image = $image->mergeImageLayers(Imagick::LAYERMETHOD_FLATTEN);
$image->setImageFormat('webp');
$image->setImageCompressionQuality($quality);
$width = $image->getImageWidth();
$height = $image->getImageHeight();
$maxWidth = 2500;
$maxHeight = 1600;
$image->resizeImage($newWidth, $newHeight, Imagick::FILTER_LANCZOS, 1);
$result = $image->writeImage($destination);
$image->clear();
$image->destroy();
return $result;
} catch (Exception $e) {
logMessage('Imagick转换PNG失败: ’ . $e->getMessage());
return false;
- 使用Imagick将GIF图片转换为WebP格式
function convertGifToWebp($source, $destination, $quality = 60) {
try {
$image = new Imagick();
$image->readImage($source);
$image = $image->coalesceImages();
foreach ($image as $frame) {
$frame->setImageFormat(‘webp’);
$frame->setImageCompressionQuality($quality);
$image = $image->optimizeImageLayers();
$result = $image->writeImages($destination, true);
$image->clear();
$image->destroy();
return $result;
logMessage('GIF转换WebP失败: ’ . $e->getMessage());
return false;
处理图片压缩
function processImageCompression($fileMimeType, $newFilePath, $newFilePathWithoutExt, $quality) {
$convertSuccess = true;
$finalFilePath = $newFilePath;if ($fileMimeType === ‘image/png’) {
$convertSuccess = convertPngWithImagick($newFilePath, $newFilePathWithoutExt . ‘.webp’, $quality);
if ($convertSuccess) {
$finalFilePath = $newFilePathWithoutExt . ‘.webp’;
unlink($newFilePath);
} elseif ($fileMimeType === ‘image/gif’) {
$convertSuccess = convertGifToWebp($newFilePath, $newFilePathWithoutExt . ‘.webp’, $quality);
} elseif ($fileMimeType !== ‘image/webp’ && $fileMimeType !== ‘image/svg+xml’) {
$convertSuccess = convertToWebp($newFilePath, $newFilePathWithoutExt . ‘.webp’, $quality);
}return [$convertSuccess, $finalFilePath];
### 也可下载 [PixPin](https://pixpinapp.com/) 截图软件试试
### 安装前准备
**[Serv00账号注册](https://www.serv00.com/)**
[PixPro项目地址](https://github.com/JLinMr/PixPro/)
## 安装步骤
注册好Serv00账号打开网页进入到面板端添加域名或者用自己的域名都行,这里我用别的网站注册的二级域名。如下图添加
把里面的A记录解析你托管到CF的域名或者别的地方申请的
按照下图打开域名的权限
点击Save等待成功
创建MySQL数据库(保存账号及地址)
[下载ZIP文件](https://github.com/JLinMr/PixPro/releases/tag/v1.7.6)
上传安装包并解压进入文件管理器
进入public_html文件夹删除其下所有文件
上传安装包到你添加的域名或者Serv00自带域名下
选择你们下载文件的路径上传好如下图
### 和上一步一样
进去后如下图所以我们</s>Shift<e>建一直按着然后点击鼠标左键全选
移动到我们开始创建域名目录下的`public_html`
修改PHP版本 在域名目录下创建一个文本,名为:`.htaccess`
添加PHP版本
**选择`Text Editor` 添加以下代码**
</s><i> </i>AddType application/x-httpd-php81 .php<i> </i><e>
访问你的域名开始安装系统,管理员账户和密码自己设置 ,如果要接入</s>CFR2<e>我们存储选择 </s>S3<e> 下面我会写</s>S3<e>安装方式
点击回到首页就可以上传图片了
### 接入R2 前提 已开通 Cloudflare R2
### 进入到 Cloudflare 面板 找到 R2 右边有一个管理 R2API 令牌点击创建 API令牌 ,创建好后里面有我们需要的访问密钥和机密访问密钥
### 1. 进入到 Cloudflare 面板 找到 R2 点击创建存储桶
### 2. 进入后名称随便写。位置选择亚太地区后点击创建存储桶
### 3. 创建好后点击设置拉到下面看到 R2.dev 子域点击后面的允许访问 , 连接域需要添加你托管到CF上面域名
### 4. 14 步我们安装选择`S3`后看到下图
| 参数 | 值 |
| S3 Region | auto |
| S3 Bucket | 你的存储桶名称 |
| S3 Endpoint | 你的S3API 后面不要加你的存储桶名称 |
| S3 Access Key ID | R2API令牌访问密钥 |
| S3 Access Key Secret | R2API令牌机密访问密钥 |
| S3 自定义域名 | R2.dev 添加的自定义域 或 R2 分配的域名 |
### 5. 点击完成安装即可。这是我们上传好的图片 我下面的域名就是我们 R2 分配的域名
### 6. 我们回到 Cloudflare R2 就会看到刚刚上传的图片
