🎬 The First Global Open-Source AI Short Play Generator!
\n\n​:laptop: Recommendation: Turn your script into a complete short drama directly, making creation easier than ever.\n\n​:green_circle: Project Key Highlights:\n\n​:white_check_mark: High Speed HD: :high_voltage: One-shot recording every 12 seconds, generating 544×960 HD videos.\n​:white_check_mark: Powerful Model: :brain: Trained on 10 million Hollywood clips.\n​:white_check_mark: Fully Open Source: :unlocked: All code, models, and training methods are open.\n\n​:white_check_mark: Create short dramas with AI and make it happen now!\n\n→ :link: Project Link:\n\nhttps://github.com/SkyworkAI/SkyReels-V1
Short plays are also generated using AI.
After that, true and false became indistinguishable.
The focus is 544×960
WatchPornWithoutTrouble :ac01:
Graphics card not supported :ac01:
It’s just that Huang sells GPUs too expensive, otherwise we could all afford AI~
This looks pretty good!
Script turned into a series of typed words, meaning just typing it out? Wow!
Not bad at all!
It can generate for so long
