There are too many images, and my remote desktop connection has low bandwidth, so it’s very slow.\n\nAlso, can the author’s u/ be removed?
It, I poured my heart and soul into it.
I thought it was a bug on my end
Before, opening the post was slow a few days ago, but today it’s very smooth. However, the image sizes displayed are different. It’s suggested to standardize the resolution.
Explosion detected, suggest adding a mode without images, of course, no images on the homepage, recommend no images
The rearrangement of posts is quite good already
I also thought there was a bug
The new topic has low information density, how to change it back or set it
Jame’s好不容易整出的idea,给个面子各位 ![]()
Still prefer the previous one
It looks good, but the information density is too low on mobile devices.\nI suggest adding a switching function which would be much better.
Add switch function (xhj)
Also, can this emoji interface be optimized? It cannot be opened qwq
Get used to it
It can be opened啊
Noted (Attention Amazing!) all preview images on the homepage posts are full-size images
Following best practices to improve user experience and reduce bandwidth costs, these should be replaced with downsampled thumbnails, and preferably in webp format.
Can we choose a mode instead? I’m still习惯之前的选择 “Can we choose the previous mode instead? I’m still习惯之前的选择”
How do I switch it back? I’m not used to this theme.
There’s… on mobile.
Not used to it yet
His meaning was that the UI was too large, and the part on mobile that opens to reply blocked it actually; it can be scrolled.
