Share your thoughts on the forum’s new theme
No issues at all on mobile — full marks!
As for the desktop version of this theme, it’s definitely been improved a lot, but there are still some obvious problems. I’ll just mention the negatives below:
Why display such a huge font and such a big search box on the splash screen? Are you worried I can’t find anything? Honestly, I rarely use search.
Why is this “Featured” section down here even necessary? It just feels random.
What’s the point of this “Join” button here? The screen’s already small, and this button just takes up even more space.
Recommendations are featured posts. Search is still a frequently used action. The third part should be removed.
Change the category from General Discussion to AskNodeLoc
Why does my homepage look different from yours?
Clicking the logo in the top left takes you to the homepage.
Yeah, I clicked the homepage LOGO on the left, and it looks just like the screenshot. I guess it’s probably because I haven’t cleared the cache before.
It’s probably because of the cache.
The desktop version is way too crowded :ac02:
In your screenshot, you clicked on the Topics tab~
Is 720P the display resolution~
Maybe your monitor is on the smaller side—try shrinking the font a bit and see how it looks.
This is how it looks on my end.
I’ve always used the mobile version — feels pretty good.
Yeah, it’s changed a lot. Haha.
If we could replace the small green dot at the end of each post with a bigger blue dot, I think it would look better.
A 24-inch screen isn’t big enough with a 1920×1080 resolution.
You can change the color palette in the preferences.
I was thinking we could remove the third column—it’s too cramped.
Hey, but the auto table of contents is so useful, why remove it?
Oh wait, you mean community members? Never mind then.
What was the theme the forum used before? I really liked it, but I can’t remember which one it was.
It should default to the client being used. The current theme works fine on mobile, but it feels a bit awkward on desktop.
