Where can ae.kg be hosted and built
Check if your domain is active or under review. If it is under review, you can modify the DNS after approval.
Can only delete, not add
imageactive
The maximum support is for two ns records, you can add it after deleting the incorrect ones. Temporary support for adding Cloudflare’s NS is not available.
No add, right bottom calls red提示
Private chat me your domain name and error information so I can take a look.
Big brother you scared me, I just started talking and couldn’t find
Sent a private message
Same question
cloudfrae temporarily cannot be added
or wait for others. I chose to wait, after all, the bugs need to be fixed and should not be misused
I am prompted to wait for administrator approval
cloudns can host the site, so building a website doesn’t necessarily have to be with CF吧
gcore hosting
he.net is also good
I host it on hostry.com.
You will find that hostry.com requires filling in 4 NS, but the website domain can only enter two NS. In this case, you only need to enter two from the NS records given by hostry.com, usually ns1 and ns2.
Like me, he originally worked, but recently hosting is no longer possible, and Gcore also doesn’t work
gcore, cf seem to be unavailable. Only know that hostry works.
