How do I set up a website with this domain name? I’m a beginner and want to host it on CF, but the dashboard doesn’t support modifying DNS.
Wait for administrator to update the system
CF hosting is now supported
It should be hosted on cf in a few days
Sure, I understand, but temporarily cannot modify DNS as it is not hosted.
Okay, it seems we still have to wait a few more days ![]()
You can use DNS except Cloudflare’s, but Cloudflare currently does not allow hosting. If you are not allowed to modify, it might be because your domain is still under review.
Sure, I can only use cf.
Cannot add CF’s NS on the panel
I am waiting for cf to build the station…
Cloudflare can already host it, just waiting for you to update the NS records.
It seems that my domain is not enabled
Wait, guys
Now you can modify the NS records, but you cannot modify them to Cloudflare.
Sure, it might be because my domain is not enabled and therefore cannot be used.
Understood
Sir, when I registered my domain, I随意 filled in the DNS. Now I cannot add NS or CNAME. How should I use my domain?
Remove existing NS records and add the correct NS addresses
