Hello, I made a toy VPS monitoring panel
I’m a second-hand construction equipment seller, and business has been slow lately. Like a middle-aged man going fishing during a midlife crisis, I’ve started learning about VPS. I’ve got a bunch of VPS instances I’ve collected from various “wool-pulling” deals—Oracle AMD, German hosting, Serv00, various NAT setups, and more. It’s not about being cheap; it’s just that as a middle-aged man with no brothers to drink with and no friends to brag to, even a tiny free-tier VPS can bring joy to my stagnant life.
But these little machines are useless—they can’t do anything and just collect dust. I didn’t even know how to use the LS command at first, so I learned from AI and built a minimalist VPS monitoring panel while studying. This ultra-minimal, lightweight, slightly cyberpunk-styled VPS panel can support all kinds of VPS instances, even NAT or pure IPv6 weak machines, with intelligent backend adaptation to most environments. It lets your VPS get a beautiful monitoring panel with just one click.
Github project address (includes one-click installation script). After installation, the script will directly print your access address (supports both IPv4 and IPv6).
Default username: admin
Default password: 123456
Popodash Minimalist VPS Panel Features
Egg Radar Speed Test (Global Radar) There’s an egg on the homepage that normally displays your VPS hardware info. Click it and it twitches, testing real-time latency to major media platforms so you can instantly see if Google, Netflix, and other services are accessible.
  1. Global Node Latency Testing (Global Radar) I’ve built in 50 nodes across major countries and regions. Click the “easter egg” in the middle of the page to watch a radar animation test your VPS’s latency connecting to data centers worldwide. It has no practical value, but it’s very stress-relieving—pure visual enjoyment.
  2. Nerfed Terminal There’s a command-line window at the bottom of the panel running in a read-only sandbox. I originally wanted to build an SSH tool, but to ensure absolute security, I removed many features, so I named it the “Nerfed Terminal.” You can still type ping, top, neofetch, even rm -rf /. It gives you real visual feedback, but it will never actually delete any files from your server. Perfect for safely showing off.
  3. Chicken Companion When your VPS’s CPU maxes out or memory is about to explode, the backend monitors it in real-time and pops chat bubbles on the UI to complain. Click on the VPS and it randomly triggers different complaints, like (“Boss, memory’s running out!”). I wanted to make it a virtual pet, but the engineering was too much, and many 128MB VPS instances couldn’t handle it, so I gave up.
  4. Telegram Scheduled Reports (Telegram Intel) Just bind a Telegram bot and set the time. Every day it acts like your personal secretary, sending a clean report to your phone with VPS traffic consumption and whether any strange IPs have secretly logged in (SSH audit). You can also send instant reports anytime with a click.
  5. Wool-tier VPS Keep-Alive Many “permanently free” VPS services (like Oracle) have recycling mechanisms: if idle for too long (CPU or memory usage too low), the system deems resources wasted and forcibly recycles them. Popodash has a built-in intelligent “heartbeat keep-alive” function: no need to manually refresh traffic. It maintains that “survival line” with minimal resource consumption (<20MB RAM), ensuring your free instance truly stays “permanently free.”
Which VPS can be installed on?
Popodash has been tested on all kinds of odd environments. Whether it’s free-tier wool-pulling or a VPS you paid for yourself, as long as it’s a Linux system, it basically works every time:
Freebie favorites: Perfectly compatible with Oracle (Always Free), Polish hosting (Zabka/Webmin), German heritage hosting (Euserv IPv6), and the legendary Serv00 (though host status monitoring doesn’t work on Serv00, the panel still runs beautifully).
Value-for-money fighters: Like Cloudcone, RackNerd (RN), BandwagonHost’s various low-spec AMD/Intel VPS instances.
Extreme environment testing: Supports various NAT instances, pure IPv6 VPS, and even those ultra-minimalist 128MB memory VPS.
In short, no matter how quirky your server environment is, just SSH in, copy the code, and press Enter all the way through. I’ve done detailed environment detection (though I can’t guarantee 100% reliability, it basically provides whatever’s missing), so your VPS won’t collect dust anymore.
Popodash requires no heavy dependencies and uses less than 20MB of memory.
It’s a late-night safe harbor—a place where you can check your server status, run radar tests, and watch indicator lights blink in a sandboxed terminal.
Here’s to everyone who finds happiness and fun in owning a small, low-spec server.
Even a weak little VPS deserves a beautiful spirit. Have fun!
Very strong support一下
support this
Is it传说中的 Serv00放探针,就会被封掉吧?传说中的 Serv00 will be banned if they deploy probes?
Is there a demo?
Looks pretty good
serv00 seems not to be able to be placed there
I made a page with oracle bones and Deji’s, computer experience might be better.
Sure, just cannot view hen information
It should be, just arguing that it can be installed​:sweat_smile:
Amazing 从门外到门内 从入门到上手
Pretty cool
strongly recommend
How to apply for this
Thank the great contributor for the share very good
Finnish node with WISE payment
frog
support this
